Question about Maytag Atlantis MDG6400AW Gas Dryer
Maytag Atlantis MDG6400AWW does not stop on auto-dry. Heats fine and timer was replaced to no avail. Time Dry works.
4-prong thermo? I couldn't find any moisture sensor in the drum or in the lint area. Any help is truly appreciated as I have replaced the igniter since it wasn't heating and then this auto-dry not stopping issue pops up and the timer was not the issue. =(
Thanks!
  • jchow Sep 20, 2008
    I think it maybe the multi-temp gas thermostat.
    The unit doesn't show any display for error codes that I can think of. =(
Jchow: I am trying to fix the same problem with the auto-dry on this model. If you have found the solution, could you please post it ?
Posted on Feb 22, 2009
  • 2,071 Answers
Click below for gas dryer troubleshooting;
http://www.acmehowto.com/howto/appliance/dryer/diaggdryer.php
Hope it may helps you;
Regards,
VOTIT
Posted on Sep 20, 2008
    Brigadier General:
  • 5,158 Answers
Any error codes ?
Robert
Maytag atlantis dryer wont shut off. changed the timer and it still wont move.
send the model number.if this is electric try this.put it on air fluff and start it,if it has heat your element is bad,it's grounding out,part of the element is touching the metal case around the element.if it just did this on auto i would say change the cycling thermostat but on timed dry it just counts down like a clock.i saw this once and the element was bad,grounding out.it was tricky i thought it was the timer also.
Nov 27, 2017 | Maytag Dryers
Why doesn't the timer count down? The dryer runs & heats but the Timer doesn't move. I replaced the Timer block but nothing changed. Is this related to a bad sensor?
go bak to 4 prong. why did u change it out? souns lik this isa 220 unit and not a 110? chk the book that came with the unit. lol.
Jul 22, 2014 | Maytag Dryers
My Maytag MDG6400AWW timer does not advance in the Auto mode. The clothes will dry but it will spin and spin for hours until you open the door. In timer mode everything appears to work normally
sounds like it is not sensing the temperature, which is the thermostat, here is a website that will help you out, #6 dryers basic, Good Luck Tim:
http://www.applianceaid.com/general.html#timers
Nov 27, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDG6400AWW, timer stopped working
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag DE 412
Does sound like the timer, although the clock is moving, the contact for the heater element is burned out inside the timer, you probably have used this timed dry for your normal day to day use and worn out the contact, new timer required.
May 25, 2008 | Maytag PYE2300AY Electric Dryer
Maytag Atlantis MDG6400AW Gas Dryer Logo
394 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
