Question about MSI Computers & Internet
Problem booting when I press the power botton the system does not turn on the power led glows on and off no fans run
  • 22 Answers
Check the motherboard.. Somethings problem with your motherboard.
Posted on Sep 20, 2008
Why is my Power button LED glowing but my system not booting up at all? No fans ... nothing. Is my PSU dead ALREADY?
Try another PS and check all of your connections. If still nothing and no fans are running something could be wrong with your mo bo.
Aug 05, 2015 | Computers & Internet
Tip
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
My computer is not working....i am stuck in windows system32 drivers disk.sys when i try the safe mode...and the installation stops and just turn into black... can anyone help me ragarding this problem?...
If computer does not start normally, use this checklist to identify specific symptoms and take the recommended corrective actions to resolve the problems.Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge
  1. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.
Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook.
  • Check AC adapter wiring and power connection to the notebook.
  • Connect a different AC power adapter and remove battery, then restart notebook.
  • Connect a different battery and disconnect AC power adapter, then restart notebook.
  • If there is no power available at the notebook, contact HP to purchase a replacement battery or AC adapter.
Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing.
  • Count number of blinking LEDs or beeping tones to help with diagnostics testing.
  • Contact HP for technical assistance. There are no other user-initiated troubleshooting actions until error codes are resolved.
Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure.
  • Connect an external monitor to check if the problem is the built-in LCD display or graphics card.
  • Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset .
  • If memory or hard drive components were replaced, reinstall original components.
  • Remove memory modules and replace one-at-a-time.
  • Remove and reseat hard drive.
  • If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test .
  • On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics .
  • If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition.
    Note: All programs and data are destroyed during recovery.
Symptom 4: Computer may display an error message on a black screen during startup or boot
  • Search www.microsoft.com for terms in error message.
  • Search www.hp.com for terms in error message.
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
  • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
    • Select Disable automatic restart on system failure to view error message.
    • Run Repair Your Computer .
    • Run Last Known Good Configuration .
    • Select Boot into Safe Mode and then select Run a Microsoft system restore .
    • Select Boot into Safe Mode and then select Uninstall recently installed programs .
    • Select Boot into Safe Mode and then run Windows Update .
Symptom 6: Computer displays the Windows logo screen and stops respondingIf no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
  • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
  • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
Oct 11, 2011 | Computers & Internet
What will i do to my hp mini notebook it has a power but it cannot booth
Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards.Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge.Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition Symptom 4: Computer may display an error message on a black screen during startup or boot Search www.microsoft.com for terms in error message Search www.hp.com for terms in error message
  • Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
    Symptom 6: Computer displays the Windows logo screen and stops responding If no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
    Oct 09, 2011 | HP Mini 1000 Netbook
    Does not boot up, fans start, internet plugs light, clicks on and off.....seems this is a common problem for these machines, what is the fix?
    Instructions
    1. When you press the Power button to start the boot process, the LED lights glow while the computer verifies that there is sufficient electrical power to activate the hardware.
      Effect & Solution: When you press the power button, the LED lights on the computer do not glow or the LEDs blink briefly and then stop. There is no sound of the fan or hard drive spinning, and the screen remains blank. The computer will not start if there is insufficient battery or AC adapter power.
    2. The BIOS queries various hardware components used for the startup boot process.
      Effect & Solution: When you press the power button, the LEDs glow but there is no fan or hard drive sound. The LEDs may glow briefly and then go out.
      Or
      The LED lights blink, stop, and then blink a second or third time, but there is no sound from the computer and the screen remains blank. The sequence of the blinking lights indicates a specific error code.
      Or
      A series of beeping tones is heard. The sequence of beeping tones indicate a specific error code.
      If a hardware component has recently been replaced, or if the PC has been jarred or shaken, there may be a loose connection to the memory chips or hard drive which prevents the computer from starting.
    3. The BIOS loads the basic input (keyboard) and output (advanced LEDs / display screen / boot drives) devices into memory.
      Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, but then the boot process stops and a black screen - with an error message - displays.
      The boot check has detected a communication error or conflict with a hardware component that must be corrected.
    4. The BIOS loads the Windows operating system and starts the services that allow low-level control of all of the background operations.
      Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, the HP or Compaq Logo displays on a black screen, but then the boot process stops and a blue screen - with an error message - displays.
      The boot check has detected a hardware driver error or a software conflict that must be corrected.
    5. Control is transferred to the Windows loader to initiate the display of the advanced settings in the Windows environment.
      The Windows logo displays during this step.
      Effect & Solution: When you press the power button, the computer performs all the steps in the boot process, but after the Windows Logo displays, the moving Windows progress bar or the rotating cursor stops moving and the boot process stops.
      An error message may display on a screen with the Windows logo. In some instances, there is no specific error message.
      Or
      A black screen appears and the computer attempts to restart.
      The Windows self-check has detected a software conflict that must be corrected.
    Jan 09, 2011 | Gateway GT4016 Desktop PC
    3 beep sound
    If a PC suddenly fails to boot properly, you should perform a hard reset as the first action. Performing the hard reset will correct many problems. If the computer still does not start properly, select your symptom from the list below to guide you to the recommended corrective actions.
    1. Disconnect all peripheral devices and remove all USB devices and SD media cards. You want to test the computer not the accessories!
    2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain all residual power and restore default startup settings.
    3. Reconnect the AC power adapter (but do not insert the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a fan or other moving parts turning.
    4. If the computer does not start, the LED lights do not glow, and the display is black, you can perform one or more of the following actions to resolve the no power issue.
      • Verify the computer is receiving power from the AC adapter . Verify that the AC adapter is not damaged and is connected correctly to a working wall outlet plug. Verify AC power is connected to the system board by examining the AC adapter, wiring, and pin connection for damage. The keyboard LEDs will glow when AC power is connected to the system board. Damaged components, like the AC adapter or the pin in the power connector, may require an HP-certified repair.
      • Use a different AC power adapter . If you have access to a different AC adapter or power pack that is designed for the computer, connect it to the notebook and try to start the computer. If you own or have access to more than one notebook, verify that you are using the adapter which belongs to the notebook. CAUTION: Using a power adapter that does not meet the power requirements or has the wrong type of connector may damage the computer. On newer notebook models, connecting the wrong adapter to the notebook may cause the power LED lights to blink but not power the computer.
      • Remove the battery and boot on AC power only . A discharged or defective battery may prevent the AC adapter from supplying enough power to start the computer. To verify that power from the AC adapter is available for PC; remove the battery, connect AC power adapter, and press power button. If available, try using a different AC adapter, that is rated for the PC, and repeat this test.
      • Remove the AC adapter and boot on battery power only . A defective AC adapter may not charge the battery and prevent the computer from booting on battery power only. To verify battery power available for the PC; connect AC power adapter, allow battery to charge for 30 minutes or more, disconnect the power adapter and press power button. If available, try using a fully charged battery, of the same type, from another computer and repeat this test.
        • If LEDS do not glow and the fan or hard drive do not spin, battery may need to be replaced.
        • If tests of both the battery and the AC adapter fail, there may be a problem with system board requiring service by HP.
        • If LEDs glow and PC boots, the AC adapter may need to be replaced.
        • If LEDs glow, but PC does not boot go to LEDs glow, fan is heard, but display is black or blank section.
    Nov 21, 2010 | HP Compaq d530c PC Desktop
    When i press the power botton on my pc the LED lights glow but the system take like 1 hour to start booting and it doesn't complete the booting process
    there is some OS installation problem,try reinstalling the OS or fix the BIOS by flashing(updating) it.do the flashing from the providers site only, bcoz if u dwnld it from other source u may b infecting ur BIOS with a virus
    Jan 13, 2010 | HP Pavilion dv1000 Notebook
    Actually my system is having the problem like motherboard led is glowing powersupply fan processor fan spinning but when we remove memory there is no beeps from the board so what can be the problem please...
    The motherboard LED is supposed to glow, indicating that the board is residually powered, after disconnection
    of external power and as a warning of this condition so that you will not further disconnect or connect any
    peripherals until the charge on the power retention capacitor is properly dissipated.
    The Power Supply and Processor Fans should only run while power is applied, and if the Processor fan is always running at a high, possibly noisy, velocity, additional Processor Cooling may be necessary by means of a higher efficiency heat dissipation system.
    If you remove memory from the board, the system should not initiate, as memory has little or nothing to do with
    the problems you cite, but everything to do with the proper initiation of your system.
    Buy a larger Processor Fan Assembly and those symptoms you cite which actually are problems should cure
    themselves, while those symptoms you cite which are not problems will still not be problems.
    Apr 18, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
    Thinkcentre M55 8806 power on off problem
    May be your computer motherboard wires connection get loose or getting moisture in wires. Or there may be some earthing problem in ur power switch. First, check the wires connection & tighten up properly. if problem persists, check the earthing by power tester. Check you RAM if it is properly tight in the jack.
    Dec 26, 2008 | Computers & Internet
    Computers & Internet Logo
    127 people viewed this question
    Top MSI Computers & Internet Experts
    vsri9
    Alun Cox
    David
    David
    Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
