Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Display p1 THE MACHINE display p1. and there's a lot foam. thanks .john
  • 640 Answers
Look inside the dishwasher and pull out the top screen,stick your head in and look down you will see 2 probes,the one to the left is the sump probe which detects the water level,the probe to the right is the wash tank temperature probe.Clean the left probe with a s.o.s pad and see if this solves your problem,let me know----also are you deliming the machine?
Posted on Oct 08, 2008
How to bleed the air out of line on a 5975e john deere tractor
if it got run low on fuel and now the pump is air bound , carefully loosten the #1 injector line , and attempt to start machine, notice I didn't say remove , fuel there is very high pressure and you don't want that shooting around , drips is all u want to show , you will notice foam at fitting this is the air coming out of line , once foam stops , stop engine and retighten fitting , don't tighten while running too dangerous !!
Jul 27, 2016 | John Deere Garden
Why won't my baby lock ellure plus read my USB stick....I copied a pattern from the internet ...it seems to have read the pattern but when I put it in the sewing machine it comes up P1/P1
You downloaded a toyota dst file. The babylock will embroider the design but it wont display the design or any picture or attributes. It will sew it, but try on scrap fabric first to be sure.
Aug 12, 2013 | Baby Lock Sewing Machines
I have a polar wind portable air conditioner/dehumidifier/fan with swing louvers model # MPN4-12CRN1-BH8 I cannot get the protection code P1 to go away do you have any suggestions? When I first plug it in...
Check the back of the manual that came with it. I find two things for a P1 Error.
Midea AC "R" Series Error Display = P1
Error Code Definition = Over voltage or too under voltage protection
On a portable unit
P1 or H8 - Water reservoir is full.
Oct 22, 2017 | Heating & Cooling
Hobart am-15 ml-130038 displaying p1 error
I replaced the probe temp according to error code P1 but the display still shows error P1. Is there any suggestion for further troubleshooting?
Nov 08, 2011 | Hobart 29 in. AM15-1 Free-Standing...
Describe your 9100 Next Generation Remanufactured Treadmill Problem display shows waxer disconected ???
Dear Sir:
I will help you inmediately.
1) Display does not illuminate
when machine is powered
on.
Insufficient power source.
Plug treadmill into a dedicated amp circuit.
2) Loose 10 pin connection at
display console or wax/lift
control board.
Check all electrical connections for proper
attachment.
3)Damaged main harness wire
connection.
4)Replace wire harness.
Faulty display console or Wax/
Lift Board.
Verify if 8VDC is present at P1 pin, 3-4 and
12VDC at P1 pin 9.
a)If yes, replace Display Console.
b) If no, replace Wax/Lift Board. See How To...
Replace Wax/Lift PCB.
Use VOM digital (Voltimeter)
Hoping that you can resolve, if you need some extra help, please reach me.
blessing.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 13, 2011 | Life Fitness 9100 Next Generation...
My Haier HW-C1460TVE-U washing m/c keeps giving (CLrF) ERROR Code
Anyway, my machine shows an error code "clrf". I just spoke to someone at Comet, and apparently this means there is too much foam in the machine. The machine will then refill with water and try to rinse it out, but if after that the machine still has too much foam in, then it will stop the cycle. Hence why my clothes are still wet (although I'd not realised they weren't rinsed properly either!).
I have not been using excessive amounts of washing powder, and usually use powder tablets or the liquid tablet sort, so they are a set amount and I don't do anything daft like stick 6 tablets in! I find it ridiculous that this would cause a problem with the washing machine, as I've used them perfectly fine with other washing machines.
Anyway, the advice from Comet was to keep trying different washing powders until i find one that foams less.
Jan 07, 2010 | Haier Washing Machines
Dishwasher keeps displaying c3
If you open a sidepanel and look at the bottom of the machine you see a brown device with a piece of white foam,this is the leak prevention system.
Push foam down and the error code should be cleared.
Make sure you there's no water left on the bottom of machine
If problem still persists, let me know.
Thanks for using "Fixya".
Jun 17, 2009 | AEG Dishwashers
Pink letters/wrong display driver
Make sure that the cable from mainboard to display is firmly seated. It probably got partially disconnected when you had the machine open to replace the battery.
Apr 03, 2009 | Compaq Evo N600c Notebook
CLogged Titanium
Love to go over the problem with you. Give me a call at 866-408-9438.
Ask for john.
Cerini Coffee Services
Authorized Gaggia Service center
Oct 14, 2007 | Gaggia Titanium Espresso Machine
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
513 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
