Question about Maytag MAH6700AWW Neptune Front-Load Washer
Strong mold smell inside washer
My washer is 2 years old and now has a strong moldy smell inside. I have tried bleach, vinegar, afresh, smellywasher.com powder with no results. I previously use liquid HE detergent but recently switched to powder. I wipe out rubber gasket and door after each washing. Odor is so strong you can smell it when you walk into the laundry room. Rubber seal clean with no residue, smell is from deep inside washer.
  • Anonymous Sep 21, 2008
    The smell is horrible when I wash a load of jeans or dark clothes. I use HE detergent only, but still get the smell. I have run the bleach solution suggestion in the owners manual, but the smell is still there. Have recurring problems with the pump going out. Noticed when the machine goes to spin not all the dirty water is going out before clean water is going in, result, nasty clothes that aren't rinsed clean of the dirty water. This is a problem with these machines even if the manufacturer doesn't want to admit it. Had the high end Whirlpool front load which did the same thing. Thought buying a Maytag would be a step up, boy, was I fooled. I haven't seen this clean out solution you are talking about, where can you get it?
If only I had read the reviews 1st , I have the same problem with my washer , I just purchased it last month , it was working fine , the appliance store I bought it from didn't bother to put the use and care guide in it like they said before they shipped it to me , so I figure well I'll just download it and print it , I did download it and forgot to print it , I didn't do any laundry for a few days ....the day I thought well laundry if piling up better do some . Little did I know , as soon as I opened up the door to the washer (wham!!!) hit with the god awful smell of mold or mildew (ugh) . So I got on my computer and read some reviews on this matter , found out about affresh and smellywasher , thought to myself , well I don't live in a major city where aval. nor did I want to wait for the mail to arrive , so I took the matter into my own hands there has to be a solution to this I thought , those companys can't be the only one to come up with a solution to this major problem I see growing all over it seems .
So I did print the use and care guide , thinking , hmmm well I didn't know I was suppose to shut off the water supply after a days washing , suppose to use 1 cup of bleach to 2 cups of water to refresh the inside drum , so thats what I did , think it worked , heck no.....hmmm what else could I possibly do to get the smell out , tried running straight bleach with hot water , in a full cycle , didn't work , thought well I just bought this darn thing , and I am not about to give up on this matter , went to bed , with a sick stomach cause of the days battle with the washing machine , ugh , Good Morning , today is a new day and I have a game plan , use everything possible and that is safe to get rid of that smell , used baking soda and vinigar , didnt work , hmm thought , well they did mention about the build up on the inside drum . so I went to the one and only local store we have and looked at what products were aval. there were no dishwasher powder that I read about that might work , found some clorox hard surface spray , some lime away and some rubbing alcohol , took the products home and sat in front of my washer and thought well , it's worth a try , something is going down and it's either me from being sick or the washers bad smell and for damn sure it wasn't going to be me , ( not after being sick from the night before) so I rubbed the washer rim with the rubbing alchol you know where the bad smell seems to be coming from waited for it to dry , sprayed it with the clorox hard surface cleaner waited for about 5 mins. wiped it off dry , used about a half a cup of the lime away in 2 cycles of hot water and ran a cycle of just hot/cold water by itself and .......drum roll.....it worked no smelly washer , I knew it wasn't going to be goin down , hahaha hope you enjoyed and hope this helps you.......
Posted on Oct 07, 2008
    Novelist:
    Champion:
  • 261 Answers
Powder is tuff on a front loader, liquid is the way to go. One solution is to use a ratio of 2 Tbls of soap to 1 Tbls of softener as this machine uses 70% less water and this makes the solution of soap much stronger causing a build in the back bottom of the tub. Every one I have rebuilt has had to be scrapped out because of excess soap, liquid or powder. This stuff turns black and is awful. I usually use washer magic only and knowing that one use will not remove even 3 years of build up but is a process of reversing the junk. So I will by one from Walmart for about 4 bucks and pour the contents into the machine will empty of clothes and water and let it sit over night to start breaking the stuff down, then in the morning I will run hot water in the closet sink to the machine so when I start the cycle the water is hot. So after soaking you want hot water with a heavy agitation plus a second rinse and that will remove half of the junk. I usually do this every month on my top loader because of hard water and my clothes do smell much better for it
Posted on Sep 20, 2008
  • John Robbins
    John Robbins Oct 15, 2008
    The problem with this is that the material used to seal the bearings and the door become brittle from from strong alkalines and some acids, if used caution must persist to use the smallest amount. I understand this frustration and have seen owners use everything, usually down the road is premature seal failure recognized by Maytag and not covered under a normal warranty. Although these can be used eventually the seals will fail or corrosion will pit the spider holding the basket to the spindle.
    Thanks SearsTechToo
I AM ALWAYS GETTING MOLD INSIDE THE LG FRONT LOADER. THE RUBBER SEAL IS ALWAYS MOLDY
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. If the growth is very high then try and leave the door open for 4-5 hours and let it dry and then spray the bleach+water (3:1) mixture on the seal. Let it dry for another 2-3 hours. You may need to change the seal in case of extreme growth of mold. Hope this helps...
Daniel
Aug 30, 2010 | LG WM-2077C Front Load Washer
Top loader smells like mold. Maytag washer canot rid the moldy smell. Spray with bleach and after a day it smells bad again
you must use liqid soap ? what you need to do is add 1 gallon viniger to a small load all hot water let wash 4 a min or 2 let stand over night start back up and you should be good to go when you put in your soap when washer adgit. or swith to powder
Feb 14, 2010 | Maytag Washing Machines
There is a moldy smell....I have ran a load with no clothes and just bleach and it smelled ok for a week and now smells again
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub/basket, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Oct 24, 2009 | GE WSXH208A Front Load Washer
Moldy smell always tried bleach and vinegar. Use
You need to replace the rubber gasket around the front of the door. This gasket holds moisture and over time molds. Give us a call or email us and we;ll be sure to get the correct gasket out to you right away. We hope this helps and we hope to hear back from you real soon.
Oct 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front loader smells like stale cigarettes during cycle
Make sure that you are using high efficiency (he) detergent. Pour 2 cups of vinegar in the tub and fill the detergent tray with vinegar. Run it on the hottest, longest cycle. You can also use a Front load cleaner such as Afresh, made by Whirpool. I think that Tide makes one too. Vinegar is usually readily available. At the end of washing for the day, leave the door to the washer slightly open so that fresh air can get in and dry it out keeping moldy, milduey smell down. If it mildews, use a rag and bleach water to clean the boot seal. Hope this helps.
Apr 02, 2009 | Kenmore HE2 Plus Front Load Washer
Moldy smell in front load kenmore washer
forget the vinegar, theres a product www.affresh.com this will help. you also MUST USE HE( high efficency) DETERGENt. reccomneded amount is 2-3 tablespoons. regular detergent, and too much fabric softener is possibly adding to the moldy/musty smell..
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Mold & Smelly in Washer
Wash on hottest and longest cycle with regular laundry soap and a bottle of vinegar. After cycle, wash again with soap on hottest/longest cycle. This will clean your washer like new.
Nov 21, 2008 | LG WM-2277HW Front Load Washer
Thanks for your suggestion about looking in the lip of the seal. I found one of my three year old granddaughters socks. Also, the seal for very dirty so I mixed a 50% solution and 50% solution of chlorox and used an old towel rag to wipe and wash throughly around the lip seal.
I noted that the aluminum ring inside the washer had also accumulated a lot of dirt. With one hand and fingers I held the wet cholorx towel inside the ring and with the other hand spun the tub around several turns until I had removed all the dirt and grime.
It did have a moldy smell. I'll let you know if this fixed the problem.
dundat45
Jul 19, 2008 | Whirlpool GHW9100L Front Load Washer
The bin stinks like mold
Have had machine for 6 years.  Mold is an issue.  Occatioinally I clean out the drawer and behind the grey rubber seal with vinegar.  After a load is washed, I dry off seal and leave door slightly open.  Occationally I also wash a load of nothing but bleach.   Hope this helps.
Dec 30, 2007 | Kenmore Elite 45986 Front Load Washer
Shepherd, Finkelman, Miller & Shah, LLC, is currently investigating defects and other problems in certain front-loading washing machines manufactured and/or sold by Whirlpool, Kenmore, and LG Electronics, including Kenmore Elite HE3 front load washers, Whirlpool Duet front load washers and LG Tromm, LG XL and other LG model front load washers, which result in the growth of mold/mildew in the machines and which can cause the staining of clothes and other problems.
On August 29, 2007, SFMS filed a Complaint against Sears Holding Corp. involving its Kenmore HE, HE2, HE3, HE4, HE5 and other front-loading automatic washers. If you own a front-loading washing machine that is manufactured by any of the above-mentioned companies and are experiencing the growth of mold/mildew in the machine, visit the following website: www.frontloadwasherclassaction.com
Dec 18, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
437 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
