Question about Kitchen Ranges
Ignitors won't stop sparking
My wife was cleaning the stove and and the ignitors keep on going off (sparking and making clicking noise). When I turn the knobs I can still get each burner to light. The best solution I could find was from fixitnow.com which suggested: "Do the burners spark continuously no matter which burner is turned on? If so, replace the spark module." I may try that if I can find one, otherwise can you think of anything else? Thanks
  • Samwise10 Sep 21, 2008
    We ended up unplugging the stove and waiting a day or two while everything dried out and now it is working fine again.
  • kiddlish Jan 07, 2009
    I have the same problem unless I turn on the grill.  The problem actually stopped for a day or so after a pretty good cleaning.  As a temporary remedy we turn off at the circuit breaker while it's not being used.
    I'm getting nervous after reading a website called" Why Thermadors ****". Post after post of disheartening recurring problems , miserable customer service, and thousands of wasted dollars make me wonder if this is just the beginning.
  • 23 Answers
If your ignitors on the burners continue to click after cleaning it is because they are wet. The spark module is not sensing the flame is on therefore still telling it to click. Just leave all burners on high for 20 minutes until they dry out and stop clicking. The clicking is not dangerous. Just annoying. If they continue to click you may have some grease residue or cleaning residue on the ignitors. Take a piece of sandpaper, nail filer and file the tips of the ignitors where it has metal above the porcelain white part. Good luck.
Posted on Sep 04, 2009
Electronic ignitors won't stop clicking
Pull the burner caps, etc off the stove and completely dry the area ..Be sure to inspect each ignitor contact for cleanliness as well. If the ignitors have soapy buildup or water, around them, they can act like this.
You should be able to pull the burner caps and flame diffusers off and clean with a paper towel, and if needed, a light scouring sponge. Be careful not to scratch the surfaces, but scour the top of the ignitors carefully if you need to clean them.
Jul 31, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Ignitors keep firing by themselves after my aunt cleaned the stove
Hi davemoo2, I would make sure that the all the burners are put together correctly .. next check to see if a selector switch may be pushed in or shorted . also check the that the ingitors are know grounded out.. let me know what you find out... kraxytech
Sep 21, 2007 | Frigidaire GLGF382DQ Gas Kitchen Range
Stove top burner ignitors will not turn off
This tip I wrote to help people with the problem of the spark not shutting off...the clicking non-stop is a common problem.
Gas Range2_bing.gif Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 30, 2010 | KitchenAid KGST307 Gas Kitchen Range
heatman101
Apr 30, 2010 | Avanti DG-20CW-1 Gas Kitchen Range
Viking gas stove top ignitors sparking incorrectly
all ignitors spark at the same time no matter which burner is turned on. If you are having trouble with one burner not lighting try cleaning around the ignitor with a small screw driver so the spark has a good path to ground.
Mar 19, 2010 | Viking Kitchen Ranges
Clicking ignitors
Take a hair dryer and dry the spark switches located on the end of each gas valve.
Sometimes when cleaning they get wet and do the clicking thing.
If that does not correct the problem you will have to replace the bad switch.
Mar 19, 2009 | DCS RGT-305 Gas Kitchen Range
Stove Top Ignition will not turn off
all ignitors lite thats the way the stove works thats a safty feature..but im thinking your question is they wont go off,,if thats the case replace spark module...if not im here onthejob
Dec 04, 2008 | Whirlpool SF367 Gas Kitchen Range
Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago After she did the major cleaning of the stove I used the oven and it worked fine. I lit a burner (Probably front?) and the left...
Apparently there was a water spill around the burner control knob and in the burner itself; We ran the burner to create heat and then turned it off and let the water dry out and evaporate from the burner and igniter area.
May 26, 2008 | Kitchen Ranges
Spark ignitor won't stop clicking
Dry the ignitors and see if that works. If not, then get new ignitors.
Apr 14, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
If they ignitors worked properly before you aunt cleaned them, the problem could be with the way they were cleaned and what they were cleaned with. Please tell me how she cleaned them and with what. Also, had she cleaned them before without incurring any problems, or was this the first time she had cleaned them?
Dec 03, 2007 | DCS RGS-486GD Gas Kitchen Range
Kitchen Ranges Logo
875 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
