SOURCE: mitsubishi 50 in vs-5043
Needs convergence circuit O/h==replace convergence IC's & any damaged/over-heated resistors.re-align as needed.
SOURCE: red and green distortion
The convergence Ic needs to be replaced. I am not sure which STK number is used in that model as I dont have Info on the VZ6 chassis. But you can get a replacemeny IC with free instalation instructions at the following link.
http://servicemanuals.vstore.ca/
SOURCE: TV Won't Stay On...
fuse do not blow for no reason, th reason thy are blowing is he convrgence iC"s are going bad.
SOURCE: mitsubishi vs-50800
take a look at the gun at theback of TV. if you don't see the beam. it is definitely the HV. I don't know it is worth fixing it. then, there may be something else is going too.
I did it once it is just not worth the time and money.
SOURCE: MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
