Question about IBM ThinkPad T23 2647 Notebook
How to repair ibm thinkpad t23 laptop screen no light
  • farmoooooooo Sep 25, 2008
    the screen hibernates
  • 4 Answers
Yes you have no backlight. The screen is all dark but in the back you can barly see it. You inverter is bad on you thinkpad. You need to replace it. I have a IBM thinkpad 600e and i got one for $9.95 so they can be cheap. They are located under the lcd. When you open it up it is there or can see that it is attached to the light dimmer swicth so you will know that is it. Thats your problem
Posted on Nov 25, 2008
  • 846 Answers
There is a possibility it is your backlight because the laptop is probably older than 3 years, then you have to replace the ccfl lamb of the screen. It is a difficult repair but it can be done, if you look for guides online you will find something. I work for company that does Laptop repair in NYC and we do this repair frequently.
Posted on Apr 24, 2009
Mouse pointer quit working om my IBM Thinkpad T23 laptop. What can I do to fix it? Joyce
Posted on Oct 06, 2008
SOURCE: No video on Ibm Thinkpad T23
hi
i also have a t23, and i have messed around with the display a lot...
there are several things to consider:
1) your operating system. i would assume you are using windows xp, and that you dont get video even before the OS starts up in the first place, but its just something to consider: i have heard of some video bugs with the t23 under linux
2) you should check to see if the laptop display and the video out problems are related in the first place. to be honest, i dont know why they would or would not be related. the display not work because a) its just plain broken (although in this case there are usually some somewhat obvious cracks) b) the ribbon cable from the display to the motherboard could have ripped (they do so very easily). if the ribbon cable is ripped in its usual place, you MIGHT just not have a backlight. make sure that there is nothing on the screen, not just a normal display extremely dark. if theres definitely no picture, then you have to take the laptop most of the way apart, but you can start with just the screen casing. its fairly easy to figure out how to take apart, but you might want to look it up. behind the screen casing you can see the ribbon cable and whether or not its ripped. oh, but before you do that, try turning the led light on thats built into the top of the screen. its also part of the ribbon cable. you can do this by pressing the fn key and page down or something next to the brightness buttons. if that doesnt work then your ribbon cable is either ripped, or of course it could just be a motherboard problem in which case all of what ive said is fairly useless information. if you want you can also take off the keyboard and top casing from the screws in the bottom and look at where the ribbon cable (and maybe the video out too) meets the motherboard, just in case theres an obvious problem or disconnect. it probably wont be very obvious. however, if you do discover fairly surely that it is the ribbon cable, then you can get them for very cheap. search "ibm thinkpad lcd video cable t23"
hope i could be of some help
Posted on Mar 30, 2008
ginko
  • 19396 Answers
SOURCE: Display drivers for IBM Thinkpad t23
Drivers for Vista are not available.
You can find all drivers for Windows XP{ and older clicking below:
IBM Thinkpad Driver Download models T22, T23
Direct link below:
T23 Video driver, v12.90.90
Posted on Mar 03, 2009
Geekman
  • 32281 Answers
SOURCE: Laptop screen goes black, no backlite
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 08, 2009
  • 93 Answers
SOURCE: i need vga driver for my IBM Thinkpad T23 notebook
Use this link http://www.lenovo.com/support/
1- Select your Product - Notebook and Handhelds
2- Select family - Thinkpad T23
3- Select Your type
4- Select your Model
5- Select your Operating system
And Download and Install
Have a nice day...
Posted on May 19, 2009
  • 20 Answers
SOURCE: I have a Ibm thinkpad T23, I need a recovery cd
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
jodiki1
Posted on Jan 03, 2010
I cant find the wifi switch on my IBM thinkpad T23 2647
try press Fn+F5 or refer to the manual.
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/62p9631.pdf
Dec 29, 2012 | IBM ThinkPad T23 2647 Notebook
T23 Ibm laptop no video
Hello !
Test with an external monitor. If it works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Hope this helps.
May 08, 2010 | IBM ThinkPad T23 2647 Notebook
ThinkPad T23 white screen
1. your issue may be a bad hard, a damaged or loose flex cable to the LCD screen, a defective CPU (central processing unit, a cmos battery that needs replacement ( this is the battery that retains the information for the motherboard), a bad power supply regulator on the mother board.
2. this is just a few of the issue that have caused a white screen.
3. Laptops are mostly disposable and are usually good for 2to 3 years of service depending on the care taken.
Your friend probably thought he was helping by giving this to you to see if you could use it or part it out.
Not worth the work unless you are into PC repair or project work.
2.
Mar 03, 2010 | IBM ThinkPad T23 2647 Notebook
Direct link below:
Mar 03, 2009 | IBM ThinkPad T23 Notebook
When you power up the t23 2647 its vry very dark
Your inverter circuit board or its connectors/cables to display are fault. You should better take your laptop for repair.
Jan 13, 2009 | IBM ThinkPad T23 2647 Notebook
I need ibm thinkpad t23 vga drive
Direct link to Video driver below:
Dec 22, 2008 | IBM ThinkPad T23 Notebook
Motherboard IBM T23 THINKPAD
Double check to see if you got everything on the board connected properly.
Jul 04, 2008 | IBM ThinkPad T23 2647 Notebook
White screen Ibm t 23
Have you tried switching the LCD monitor from teh good thinkpad to the ones with white screens? Sometimes its the actuall LCD.
Mar 16, 2008 | IBM ThinkPad T23 2647 Notebook
IBM ThinkPad T23 2647 Notebook Logo
752 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
