Question about Sansui Televison & Video
I have a SANSUI DVD/VCR Combo,and cannot record from VCR to dvd.Itcomesup with disc error. Can you help?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 56 Answers
1.- Check the type of DVD that the recorder accepts, usually id DVD-R (minus R).
2.- Make shure is a DVD recorder.
3.- Internally, the DVD combo comes with a software that don't alow to copy VHS original movies, is a kind of codification that is with the information content in each movie.
Posted on Sep 20, 2008
Why doesn't a -dvd recorded on sansui not playback on another dvd player
Sounds like the disc needs to be finalised to close the session...put the disc in and look for this in the disc option menu's
Feb 11, 2012 | Sansui VRDVD4005 DVD Player/VCR
Can the sansui vcr/dvd combo record vcr tapes to a dvd?
No, the DVD section only plays DVDs, to record VCR tapes to DVD you need a ripping device that digitalize audio and video (convert step) and then transfer to DVD specifications this data to disk (record step). The easiest way to do this is using a USB video capture adapter connected to your PC with a DVD recorder drive installed, the software to do this commonly comes as a bonus in the setup disk of the adapter.
Mar 17, 2011 | Sansui VRDVD4001 DVD Player/VCR
I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have...
I have a phillips magnavox Problem with the Philips Magnavox MWR20V6 DVD Recorder / VCR Combo I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have cleaned the lens with a disc cleaner and still didnt help,same thing is happening. i am also using the same type of disc that I have been since day 1. Can you help??
Mar 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I would like to make a copy from my video tape to a DVD How do I do it?
Turn on the TV and set it to the video source to be able to easily see the menus as you set up the dubbing process. Put the source tape you want to record in the VCR. (Copy protected tapes will not be dubbed.) If you want to avoid dubbing from the DVD to the VHS tape, remove the erase protection tab from the cassette. Put a compatible recordable disc (non-finalized disc, unprotected disc) in the recorder and make sure there is sufficient available capacity on the disc.
Press Rec Mode/Speed to set the speed (SP, LP, SLP, or XP). Press DVD/VCR and set the unit to VCR mode. Confirm the mode with the indicator light on the unit. Press Dubbing and the mode should switch to DVD automatically. Select Yes (with the left/right arrows) and press Enter to start the duplication. The unit should indicate the VCR playback, dub and DVD recording are in progress. Press Stop to halt the dubbing process or it will stop when the unit reached the end of the tape or the disc is full.
The dubbing button is only on the remote control; if your original remote isn't working make sure that your replacement remote has the feature. Remotes.com often has exact or substitute remotes with the matching features. Search just by the model number not the brand.
BTW: the manual is available here: http://www.managemylife.com/mmh/owner_manuals/26967/SANSUI-DVD-VCR-Combo-L0311311?brand_name_search=sansui+VRDVD4005 .
I hope this helps.
Nov 11, 2010 | Sansui VRDVD4005 DVD Player/VCR
Sony RDR-VX530 DVD Recorder / VCR Combo - cannot format DVD+R
is it possible to record dvd+r?
is this machine not only dvd-R
Apr 07, 2010 | Sony RDR-VX530 DVD Recorder/VCR
Cannot format a dvd-rw disc or record to the disc.
Unless you posted this question in the wrong category, you can't use the Sansui VRDVD4000 to record to DVD. It is a DVD player only, not a DVD burner. It will play and record VHS tapes, but with DVDs it will only play them.
To record to a DVD, you would need a DVD burner. Many modern computers include a DVD burner, so maybe either your computer or someone you know's computer has a DVD burner.
Dec 30, 2009 | Sansui VRDVD4000 DVD Player/VCR
I have a 2004 sansui 13 in screen tv vcr combo no manual. How do you program the vcr to record?
MAIN MENU ON THE COMBO ,,UNDER SETUP ,,SET UR CLOCK ,,AND YOU SHOULD FIND IT ALL THERE
May 15, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Cannot record on DVD-RW disc
Somtimes if you change brands of dvds will help!
Dec 13, 2008 | Emerson EWR20V4 DVD Recorder/VCR
DVD PLAYS CD'S BUT WONT PLAY DVD'S
Aquarius0128 there are two things to consider here.. dvd's recorded on a computer need to be closed/finalized after you have recorded onto them in order to be used on a stand alone player.. they will play ok on original recorder because of the design of these machines finalizing prepares the structure of the disc so it can be recognised by other players as a dvd video disc.. you will usually see a 'finalize disc' option in your recording program
Second issue is this.. even if finalized an older (or even some modern) stand alone players will not recognise a recorded disc made on a computer or even if it can there are different formats DVD+R DVD-R and even DVD-RAM and DVD-RW (the two latter ones are rarely recognised outside a computer)
Jan 29, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Televison & Video Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
