I have a problem, I hope you can assist me Fisher & Paykel washing machine Pride 5.5 smart drive 9 Printed circuit on main circuit board has a problem,fuse keeps blowing circuit board number 426471D--copy write 1998
    Brigadier General:
  • 6,966 Answers
The fuse blowing is significant. If you could possible post back the rating of the fuse, then possibly we can narrow down the suspects. The idea being, it the Amps of the fuse is rated high, then It signifies that there is a short in the circuitry big enough to draw excessive current such as the electrical components and blow that fuse. If however the fuse rating is rather low, then the short is on a lower load such as the electronics.
Hope this be of initial help/idea. Pls post back on the rating of the fuse that blows, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 20, 2008
  • 2,071 Answers
Check for short circuit like bridging foriegn metals to the other parts,or faulty wirings.Check the diode for short circuit in the power supply this is the common caused of short circuit and also check the capacitor for short circuit also.
hope it may may help you ;
Regards,
VOTIT
    Genius:
  • 2,035 Answers
There's short in the wiring you need to check the wiring of the machine changes wires being short ,or there could under rated fuse please check the fuse and put correct rated fuse use the service manual to get fuse rating ......
Good luck...
    Brigadier General:
  • 5,158 Answers
Any obvious burnt components and the round can type capacitors .... do any feel rounded on the top... make sure the power is OFF first
    Guru:
  • 558 Answers
Hi Norm33,
The often found cause of this problem is the door interlock. There is a safety feature to stop any operation while the door is open. If this becomes faulty, the washer may still not work even when the door is closed. Check that when closing the door, the catch is activating the switch. To test the switch, first make sure the WASHER IS NOT PLUGGED IN, then use an electrician's meter to test the resistance across the switch. You should put the two electrodes on the contacts at the back of the switch. When the door is closed, the resistance reading should read a very low value.
Another possible cause for this is a fault on the timer. You should inspect the connecting wires for any sign of burnt plastic or charring on the spade connectors. You will need to replace the timer if this is the problem. Please dont forget to rank me.
Regards
ELLIN
Cold water not pulling into Fisher & Paykel 5.5kg Smart Drive Pride.
Either the cold water inlet solenoid has failed or there is a fault with the electronic control module, Unfortunately the only way to find out is to replace the cold water solenoid and see if it works, if it doesn't then the electronic control board is faulty.
Mar 16, 2017 | Fisher Washing Machines
Fisher & Paykel smart drive
Turn machine OFF on the front panel. Hold down the Water Temp Down button and press the POWER button. Release buttons. You are in Diagnostic mode.With your service sheet ,Diagnostic chart will explain where the error lights pattern and the path to your solution are.My advice is this....there is a known problem with the wire harness connectors,and the contact that is made at the point of connection.One at a time remove each connector starting at your main control board ,some where there is a loose connection.
Jun 08, 2008 | Washing Machines
Fisher
shorted water pump will take out the control ... new fuse added with New controls
Jun 17, 2013 | Washing Machines
Fisher and Paykel Kelvinator Pride 5.5 Smart Drive 9
You need to read the error code
and tell me what lights are on
Aug 17, 2012 | Fisher Paykel Eco IWL16
Fisher & paykel smart drive 9 mw059au no power
Most of the faults are pump related.
check the Ohms reading on pump should be 33- 35
If readings are less change your pump.
Jul 28, 2012 | Fisher and Paykel Washing Machines
Washing machine cuts out
The pump is over heating and cutting power.
Mar 30, 2012 | Fisher and Paykel Washing Machines
Fisher and paykel Smart Drive 9, pride 5.5 turns on by itself and beeps
Probably a bad controller. Note the lights that are illuminated and call F/P.
Jul 02, 2009 | Fisher and Paykel GWL11 Top Load Washer
I have a Fisher & Paykel Smart Drive 9 - 6.5kg top load washing machine...model# GW609AU. Will not fill at startup, only short bursts, then shuts down. Can this model be reset?
Can only be reset by unplugging... Sounds like a bad controller or poor connection. Try different water temps, it same problem will need to call a Technician. F/P can tell you who is authorized to fix it. 888.936.7872
Jun 23, 2009 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Washing Machines Logo
270 people viewed this question
Top Washing Machines Experts
