Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool gold Conquest side by side refrigerator-- water dispenser doesn't work but ice dispenser does.
Fridge is only 4 1/2 years old.
  • 126 Answers
WHAT IS THE PROBLEM WITH YOUR FRIDGE
MOHAMED
Posted on Sep 20, 2008
  • 3 Answers
There are three possible causes; 1) bad water valve 2) bad circuit boards. 3) water line clogged. You can check the valve by: Unplug power to refrigerator. Make a connection which can plug into the (120vac) wall outlet on one side and clips on the other. Attach clips to the ice maker valve soleniod (located on lower back side of fridgerator). DO NOT PLUG IN OUTLETat this time!! On the backside of the frig, there is a water line going up to the ice maker. Disconnect @ the quick disconnect. With the water line coming from the valve pointing into a bucket, plug in the power cable to the soleniod tempory. If water comes out, valve is ok, if no water replace valve. If water came out, reconnect water line to quick disconnect. Plug soleniod in briefly and unplug. Check ice tray for water. If no ice, water line to ice maker is clogged or frozen. If water is in ice tray, then one of the IR circuit pcb's (located in the freezer) are bad. All parts can be purchased and installed easily and in a timely manner. If water line is clogged, using an air compressor a great way to clean the line out.
Posted on Sep 26, 2012
Whirlpool Refrigerator water leak through Ice dispenser
You need to remove the ice maker and open the front carefully. It has small micro switches inside it and it sounds like one that opens the water control valve is stuck in the on position. Be careful not to loose the arm spring and how that goes back together as you take it apart. Sea Breeze
Sep 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frost in fridge
you have a defrost problem call service
Mar 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
I get no water or Ice
Usually this problem can be remedied by replacing the water supply valve that is under the back of the unit. IF replacing the valves does not fix the problem then there is not power getting to the valves to turn them on/off at the appropriate times.
Nov 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Conquest IceMaker
HAVE YOU CHECKED YOUR WATER VALVE LOCATED AT THE BACK BOTTOM RIGHT OF THE APPLIANCE THAT MIGHT BE THE CAUSE OF THE ICE MAKER NOT WORKING.LET ME KNOW IF YOU REQUIR FURTHER ASSISTANCE.GOODLUCK.MOHAMED
Sep 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice and water dispenser
Has someone pressed the lock button on the front of the fridge just above the dispenser, next to the crushed & not crushed ice button, if so there is also an unlock button next to it.
Jan 04, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
886 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
