Question about Panasonic Microwave Ovens
The inside enamel in one corner has come off and I am wondering if it is save to use, or am I getting radation from it
  • Panasonic Master
  • 8,930 Answers
Microwave ovens do not produce ionizing radiation. The only risk from leakage is burns.
If the damage is not fixed, it can arc and char, and eventually burn a hole in the chassis, and damage the magnetron.
It's better to fix this early and it's simple. It will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Posted on Sep 26, 2008
I have a Goodmans Microwave ME20W in perfect order except someone has misused it and the paint under the rotating plate is blistered causing the oven to crackle in use. There is also one small area of...
Yes they can be cleaned. prepared and painted with enamel paint.
The reason the paint comes off is usually due to condensation as the oven is left with the door closed after use.
Mar 14, 2011 | Microwave Ovens
When i turn the microwave on it has electrical short it is like there is something metal inside and everything still works what causes the electical flash
The interior of the microwave is insulated with an industrial white enamel paint to prevent the magnetron from arcing on the inside, some of the enamel has worn off exposing metal,or the magnetron is shorting, either way this is very unsafe to use and should be checked quickly, and left unplugged in the process.
Mar 11, 2011 | Frigidaire PLMV169DC Microwave Oven
Unit sparking near door corner
That is likely to be the Wave Guide Cover that need to be replaced. It is held in with either a plastic clip or a single screw and are available through your local repair dealer.
Jan 19, 2011 | Amana Microwave Ovens
My range top has got burns n it and I am wondering what can be done about it
what type of range top top is it??
is it Glass -- get a new razor blade
is it a baked on enamel coating,. you can try a preparation and high temperature spray paint
there may be other options, but you have to be more clear -- your post was under microwaves, not stoves -- so I am just shooting int he dark without specifics...
thanks
Best regards
Ck
Jan 05, 2011 | Microwave Ovens
The inside of my micro wave has discolored and has some rust spots right through the paint. Can I use a high gloss enamel spray paint to cover this or do I need a special kind of paint for this...
Not regular enamel paint.
The area may first have to be sanded smooth, but it should at least be cleaned and dried thoroughly.
Oct 01, 2010 | Microwave Ovens
Ive cooked a pot and the enamel has popped off ,can they be re enamelled
there is no safe or affordable way to resurface a popped enamel coating on cookware. Sorry to be the bearer of dire news.
Best regards,
Farmerbear at FixYa.com
Sep 11, 2010 | Microwave Ovens
Flash in oven
The flash is usually caused by metal either being placed inside of micro or the interior surface might have chipped enamel exposing the metal underneath. Make sure no metal materials are placed inside while using and that the interior surface is in good condition.
Dec 08, 2009 | DCS MO-24-SS Microwave Oven
Paint chipping of the inside of door of my sylvania microwave . There is bare metal under the paint .You can see how this is an issue.The warrenty numbers in the product manual are all disconnected...
well apart from replacing the door if clean the old paint away then you can paint the door with an enamel paint the colour of your door but it must enamel paint or microwave paint gd luck
Oct 06, 2009 | Microwave Ovens
A little metal is showing at the inside roof of the microwave.
Rub down with fine wet & dry ,paint with Humbrol enamel to match.
Sep 28, 2008 | Microwave Ovens
Non-Stick surface peeling off inside microwave.
Normally you can strip and sand the old paint, get it squeaky clean, and use appliance paint. Yes indeed it is a heat-resistant enamel. You can get it from appliance parts stores, Wal-Mart, or home centers, etc. BUT if it's under warranty I would call GE Customer Relations with your model and serial numbers. They're at 1-800-386-1215 (8-6 ET) and I would also suggest you ask them for a referral to a GE-authorized servide center in your area. Good luck. I appreciate your thoughtful rating of this answer.
Jan 29, 2007 | GE JES1231 Microwave Oven
Microwave Ovens Logo
52 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
