Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Refrigerator Door Refrigerator side door will not close tight. Is there an adjustment?
  • 943 Answers
Hi thanks for the question i would first try to raise the front of fridfe to the point where door closes by itself if left open look at the liner where the shelves are if the shelf is all cracked that could cause this problem thanks the appliance doc
Posted on Sep 22, 2008
The refrigerator door (not the freezer door) does not close.
Is it closing flush when pushed up or is it not making good contact all around? 2 things can be wrong, the surround needs to be cleaned on the door and fridge and if it still doesn' stick you will need to replace. You can adjust the door slightly at the hinges but only if its loose should you need to. If its tight then it has not shifted and i would focus on the surround clening/replacing first
Oct 02, 2009 | Samsung RS2630SH Side by Side Refrigerator
Refrigerator door won't close tight
check and make sure unit level than feel around door to make sure seal had not popped loose and is bulging,finally if you have to adjust door will need help door heavy with door closed as far as it goes you need to loosen the upper hinge and lower slightly move door till flush and closed re-tighten lower first than top check door swing and readjust again it necessary
Sep 27, 2009 | Jenn-Air JCD2389G Side by Side...
Top freezer door does not close tight
Sounds like the top hinge is loose. If the hinge has a cover, remove it then hold the door in the correct position and tighen the hinge screws.
Aug 31, 2009 | GE GTS22KBP Top Freezer Refrigerator
Frigidaire FRT17G4BW9 doors not staying closed
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Kitchen Aid Superba - door needs adjustment
there is two bolts oin the very front of the unit behind the kickplate the oiu can turn clock wise until there is a slight tile toward the back of the unit so that the cams on the doors will have a little bit of gravity to helop them stay shut.
Mar 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator door not closing tightly
HI. thanks for your question. sometimes you put a lot of heavy jars in the door shelves . so i would raise the front of the fridge to help it close better. thanks
Oct 15, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
Leveling refrigerator
you might lower the front ones to get it level thats the only sloution i can come up with
Aug 04, 2008 | Maytag MSD2656G Side by Side Refrigerator
Refidgerator
Check for possible products keeping door from fully closing, Check level of refrigerator and possibly raise the front adjusters found at bottom front near each corner.
May 02, 2008 | Frigidaire FRS3R5EMB Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
118 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
