Question about KitchenAid Architect KBRA20ERSS Bottom Freezer Refrigerator
Fridge is not running at all
Lights are on both top and bottom, but the fridge it's just not running! Why is that? Is there a switch somewhere?
    Novelist:
    Champion:
  • 261 Answers
If you dont here the fan there is two answers. Either your temp switch or the cheap frigidaire compressor that is in your wonderful fridge is dead. No offence but it is true frigidaire is bottom end for compressors and I hope I am wrong and they put a whirlpool or ge in there and a temp switch is at fault.
Posted on Sep 20, 2008
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
Tip
Lights on one side fridge not cooling.
mine fridge Viking VCBB363L Bottom Freezer Refrigerator.
Took a cell phone camera in video mode and put it in the fridge to see if the light was going out when the door was closed.
Turns out. it wasn't.
This causes the lghts on the left to go out. However, the light on the right stays on and warms up the fridge.
Solution.
Top section air grill. 5 1/4 hex screws.. remove the grill you'll notice door's light switch on right side. a steel spring attached to the switch. When fridge's hinge arm closes the arm pushes on this guy and pushing in the switch button and shuts off the lights.
you can move this with your finger.
In my case switch has a little purple button.
take two pair of 3 in needle nose pliers and CAREFULLY hold center of spring and bend the end nearest you to the left.
You don't have to go crazy Just a bit.
then get you camera ready and check out your work.
Results after you've succeded, replace your parts, and notice after 10 minutes the lights all come on, the alrms stop and the fridge cools normally.
and you saved 200.00
on Jun 24, 2008 | Viking VCBB363L Bottom Freezer...
Lights wont turn off on fridge
You have a short to ground somewhere.
Nov 24, 2012 | Kenmore Refrigerators
How to take doors off Bosch Exxcel KGH39A07GB
I've just had to do this - a real pain, and you would think that Bosch would include it in the instructions or somewhere on their website!
You have to put the fridge/freezer on its back (putting a cushion or something like that at the top to make sure the back doesn't get damanged). Starting at the bottom, unscrew the three bolts holding the bottom door in place, then the middle hinge between the fridge and freezer, and then the screws at the top holding the fridge door in place. Then reverse everything round (you may have to make holes where there are dimples on the top of the freezer door/bottom of the fridge door). Good luck!
Sep 19, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
Water on shelves in fridge and running down backwall of fridge
The drain from fridge/freezer down to evaporator pan in bottom of the unit is most likely plugged somewhere
Jul 02, 2009 | Smeg FR300SE 1 Top Freezer Refrigerator
Hotpoint FFA71 fridge and freezer suddenly stopped working
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
Jun 30, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
KitchenAid Architect KBRA20ERSS Bottom Freezer Refrigerator Logo
126 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
rugby prop
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
