Question about HP Deskjet F340 All-In-One Printer
Scanner,printer,copier What is the name of the cord that goes from a hp all in one copier,scanner and printer and where can you get one?
We need to download this printer on a vista but the disc is only for microsoft xp and 2000 and 98
Posted on Sep 20, 2008
How can i resolve an hp 3210 error 0xc18a0206?.
try this it worked for me unplug power cord from printer and electrical outlet wait 30 seconds hold in help and ok buttons while reconnecting power cord. continue holding buttons until screen turns black turn printer on and continue this helped me
Apr 25, 2016 | HP Photosmart 3210 All-in-One Printer...
How to solve scanner error 22 in HP laser jet 1213mfp
Perform a power reset.
Press the Power button to turn on the printer.
With the printer turned on , disconnect the power cord from the rear of the printer.
Wait at least 30 seconds. Reconnect the power cord to the rear of the printer.
update the firmware by download from this link: HP LaserJet Pro M1213nf Multifunction Printer Drivers
Jan 20, 2015 | HP Office Equipment & Supplies
My hp printer supply cord is blinking, but printer will not turn on
The printer has a network cord and a power cord. Maybe the power cord is not connected?
Aug 06, 2014 | HP OfficeJet 6310 All-in-One Printer...
Connecting my HP Officejet 4315v All-in-One Printer.Fax.Scanner.Copier with a phone modem in order to use the fax machine
The power cable goes in the socket on the far left. The phone line goes into the port named 1-LINE and runs to the wall. 2-EXT is for you to connect you phone or fax machine if you so wish.
If it is your first time installing the printer I would take a moment to go through the setup as mentioned in the manual here. It seem the USB port should be connected at a specific point during installation.
Hope this helps.
Sep 14, 2012 | HP Officejet 4315v All-In-One InkJet...
I need to find a cord that goes into my HP deskjet scanner/copier
You want a USB printer cable. You can get it at any store that sells electronics or printer supplies.
I added a link to the users setup manual so you can see what you need.
HP F340 users guide
Mar 19, 2009 | HP Deskjet F340 All-In-One Printer
52 Scanner error
52 scanner error means yoy got got an error with the scan assy, it could be many problems. If it not helps with turn off /turn on, try reset the printer. Turn off power press and hold * and #, turn on power, wait 20 sec and release the buttons. If printer not goes to ready, disconnect power cord when printer initialize and turn off power switch. reconnect power cord and turn on power switch. If you get the printer to ready state, upgrade firmware.
Oct 15, 2008 | HP LaserJet 2840 Printer
Scanner failure
1. Check scanner light by trying to make a copy.
Caution: do not look directly in the light
3. Perform a power cycly
* Unplug the power cord from the product while its still on
* Plug the power cord back again after 30 seconds
4. Perform a semi-full reset
* Press and hold # and 6 while plugging the power cord
* Do not release the button unless the printer would say reset
5 If you still have the problem replace your printer
Aug 12, 2008 | HP OfficeJet D135 All-In-One InkJet...
HP officejet D135 scanner and copyer
Hi..
if the scanner bulb is not moving, then its an hardware problem.
We can try by resetting the printer.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK/ENTER and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Please let me know after resetting.
Thank U!!
Feb 10, 2008 | HP OfficeJet D135 All-In-One InkJet...
Scanner problem of hp laserjet 3030 all in one
Try unplugging the cord to the printer and wait a few seconds and re-plug the cord again , print what ya have to print again/hope this helps .
Dec 01, 2007 | HP ScanJet 3200C Flatbed Scanner
51 people viewed this question
Seeker5211
Seeker5211
