Question about LG WM-2277HW Front Load Washer
LG WM-2277HW I noticed that my washer's light was not turning off-I keep the door open after my last load to dry it out. I noticed that the washer would not turn on. I unplugged it and plugged it back in and I was able to do another load of wash but again the light stayed on and it would not start again. I unplugged it and plugged it back in and it did turn back on. Now in the mean time, when it is plugged in, the light is on the whole time. Is there a reset bottom? No code appears on the screen. Please help?
  • Anonymous Nov 03, 2008
    I have the same problem.. My light stays on and the chime will chime every 8 or 9 minutes. I have to unplug my washer to shut the light off. Not happy about this.
  • 489 Answers
It sounds like a problem with the control board.  You will need to have the unit checked out by a qualified LG technician and possibly replace the board.
Posted on Sep 29, 2008
  • 210 Answers
SOURCE: LG WM-2277HW Front Load Washer not working with ce showing
CE is an error stating that you have a problem with you board or possibly the stator on your unit. Either way your going to need service. You can ohm out your stator to see if it is the problem.
Check the back harness, maybe it has come loose, remove the back panel and it is the blue connector.
Sgt 48
Posted on Jun 08, 2008
  • 489 Answers
SOURCE: Problems with LG WM-2277HW Front Load Washer
It is a rare problem but I've seen it happen.  The only way to resolve this issue immediately is to remove the top of the washer to gain access to the dispenser.  The dispenser can be disassembled by unsnapping the top section where the hoses are connected.  Once the top section is lifted, you can safely pull the drawer out.  Not sure what happened but more than likely the water dispenser has warped downward causing it to jam the drawer.  Recommend replacing the dispenser to resolve this problem.
Posted on Jul 24, 2008
  • 12 Answers
SOURCE: LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Posted on Oct 24, 2009
  • 1531 Answers
SOURCE: LG WM-2277HW Front Load Washer. I am trying to remove the big nut
the best way is to have some one hold the drum from the front and turn the nut. it can also be done sometimes by turning the drum in the opposite direction and then pop it with the wrench. not the best way but it works.or you can hold the stator assy with one hand and tap your wrench with a hammer.i hope thia was helpful,would like to here how things worked out.
Posted on Jan 22, 2010
heatman101
  • 43501 Answers
SOURCE: LG WM-2277HW will stop at the rinse cycle and
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 01, 2010
Lg wm2688 drum light won't turn off
its happerning some time after used dry option,,,becouse this iscondensation dry systterm,,all the humidity become water power connetion getting wet,, afetr some time its will gose off....
Apr 13, 2014 | LG WM-2277HW Front Load Washer
I have had my LG front loading washer for over 5 years. I always leave it open to air dry after I am finished, usually for one to two hours. This past week I have noticed a mildew smell coming from inside...
you might want to try cleaning the washer using 1 cup of Clorox bleach, run it through the white or sanitary cycle, unless your machie has a clean washer cycle like mine does. Hope this helps.
Jul 11, 2011 | LG WM-2277HW Front Load Washer
Jan 22, 2010 | LG WM-2277HW Front Load Washer
Oct 24, 2009 | LG WM-2277HW Front Load Washer
Moldy, mildew odor from washer
after using washer leave the door open, this lets it dry and no mold to develope.as with any wash machine, feel fry to leave the door open all the time, even slightly
Jun 20, 2009 | LG WM-2277HW Front Load Washer
TROMM LG WM-2277HW
You may have a broken door latch switch that doesn't tell the computer that the door is actually closed.  Before you actually replace the latch switch, make sure the wire connectors are securely attached to the latch assembly.
Sep 14, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
305 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
