Question about Dell Latitude D800 Notebook
Dell Latitude D800- Keyboard and mouse stop working when undocked.
I have a USB keyboard and mouse jacked in to the docking station at work. However, after performing a complete shutdown, then undocking and taking laptop home, I boot at home and the on-board keyboard, touchpanel pointer, as well as the little pointer nipple between the G&H keys are completely non responsive. Same with any external input device I might plug directly into the laptop's onboard USB ports.
I am able to hit F2 during bios initialization but I see no bios settings that might be helpful.
If I let it boot up without launching bios setup, then Once windows starts, when it is just a plain screen while windows is still loading, the onboard pointer works for a brief period, but then freezes just before the "Insert Card or Press CTL=Alt-Delete to Login" welcome message appears. At that point all input devices are dead. It seems that Dell and Bios are kicking things off right, but that Windows is deciding it doesn't want to talk to any input devices.
Any ideas?
  • jvetterick Sep 20, 2008
    Just to clarify, everything works fine when docked at work. Problem only comes up when laptop is run away from "momma".
  • rmblefsh Jan 18, 2009
    I'm having the same issue when using my KVM switch. I cannot get my keyboard and onboard pointers back at all.
    Master:
  • 474 Answers
First update any drivers for your dell.
www.support.dell.com
Is the dock a dell dock, or a universal Dock?
the drivers may need updating.
Some times when you plug a dock in, and turn it on, they will load them into the drivers and when you unplug it, it gets confused and when you boot it up it has to re-install the original drivers and does this while its booting.
This happens alot with the GX620 desktops. If you pull a USB keyboard out while its off and plug it back into a different USB port and tun it on. It wont work right away.
We end up having to let it sit at the login screen for a while till it reloads the drivers to the new USB port.
You will know if yours is doing this as the Hard drive light will be flickering and running.
Try booting it up and letting it load windows and waiting a few minutes.
Posted on Feb 04, 2009
Dell latitude d800 not switching on ?
I may have addressed this question earlier. If your Dell shows absolutely no sign of life... no LEDs, no nothing and you know for certain the battery and/or power adapter is good then...
If you have access to a docking station (ANY Dell dock that will mate with the bottom connector on your D800), put the D800 in the dock and use the power button on the docking station.
If the laptop powers up, you may have a simply problem with the laptop "Press to turn on" button.
ABOVE THE LAPTOP KEYBOARD...
Use a small flat screwdriver blade to remove the Center Control Cover (just beneath the display/cover hinge and above the F1-F12 keys). Locate the cover's flat ribbon cable connector above the Page Up key. Pull off and carefully reinstall. Try the power button now. If it works, put everything back together. Otherwise seek profession help.
May 02, 2014 | Dell Latitude D800 Notebook
Dell Latitude E6410 : Mouse & ext. Keyboard lost when putting back into docking station
Go to the Control Panel in your start menu whilst the PC is in the dock,disconnect the things you want it to detect, then click on "Add a device" and connect them one by one :)
Aug 16, 2012 | Dell Latitude E6410 Notebook PC - Intel...
Acer EzDock
Try updating all the drivers, including the one for the docking station, from the acer website.
Jul 26, 2010 | Acer EZDock (LC.D0303.005) Docking...
Dell latitude D410 wont boot up when hooked to docking station can not use keyboard or mouse
Sounds like a compatibility issue between your Dell and the Docking station. I would say make sure the software for your docking station is installed properly, and update the software before connecting again.
Jul 10, 2010 | Dell Latitude D410 Notebook
Keyboard not working on one side of switch
the GCS632U has keyboard and mouse emulation that may not function correctly with docking stations. To ensure the KVM it self is working correctly I would suggest plugging the single USB from the KVM directly into the laptop and see if you have the same keyboard problem. This will at least tell you if the KVM is working properly or not.
May 16, 2010 | IOGear GCS632U 2-port KVM Switch
Cursor tend to go spastic when I touch the keyboard on my Dell
hi,
I had this problem and it was solved by turning off the touchpad in the bios,
Pressing the f10 ? or f2 ? during startup will get you into the bios
are you sure the mouse is ok ?
Regards
GeWiz.
Dec 10, 2009 | Dell Latitude D800 Notebook
Dell D630 Docking Station
First option if using Windows XP is to undock the system then delete the Docked hardware profile in Device Manager, Hardware Tab, Hardware Profiles. Once deleted, power off, dock the system, boot, Profile recreated.
Jun 28, 2009 | Dell Latitude D600 Notebook
D630 docked , ext mouse & kybd not responding
If the docking station has power:
Make sure power is off for both the laptop and the docking station. Plug your keyboard and mouse into the docking station. Dock the D630 to the docking station and then power on docking station. This should then turn on your D630. Your D630 should detect the keyboard and mouse.
If the docking station has no power:
Verify that the power cord, AC adaptor, etc. is plugged in. If the items listed seem to be in order,
there may be a problem with the power going into the docking station. (AC adaptor?)
support.dell.com will have the specific details for your D630 and your docking station, et al.
Please let me know if you have success in this.
Binary Bob
Nov 27, 2008 | Dell Latitude D600 Notebook
USB ports in docking station stopped working suddenly
I was having the same problem - the USB ports seemed to have stopped working so I could not use the mouse, keyboard, or printer, even though the monitors and power could still operate through the docking station. Finally, I just unplugged the docking station for 30 seconds, plugged it back in, and everything resumed working. I was surprised it was that simple, but it's working for the moment.
Aug 27, 2008 | IBM (250410U) Docking Station for ThinkPad
Docking Station problem
You can try to update any system utilities drivers and docking station drivers. However, I found that with IBM and Gateway, when you remove a running machine from the docking station they tend to glitch just a bit and when you redock them they have issues. Your issue is the docking station attachments, I've also seen issues with the monitor only, mouse only and keyboard on the laptop, all not working. I've had a couple that if I used the "safely remove hardware" then they would work when removed then redocked, but not all machines give the safely remove hardware option with the docking station. If yours does, try that. If it doesn't and there are no driver updates or the updates don't work, then, unfortunately, I'm afraid you'll just have to live with restarting after every redock. One other thing you might try is, after redocking, do a hardware search. It may find the attachments. I know this is also a pain, but it may be easier than rebooting every time.
Jul 09, 2008 | IBM ThinkPad X61 PC Notebook
Dell Latitude D800 Notebook Logo
1,177 people viewed this question
Alun Cox
