Question about Asko Washing Machines
I am unable to get my wash cycle to start. The machine is new. All the hook-ups are good. The water leaves the house pipes but does not seem to get going in the machine. The programing panel sayswash cycle started, and I hear a hum, but nothing happens. The model is Asko W6903
  • 725 Answers
Call for service asko usa...
Posted on Sep 20, 2008
I have godrej gda 902 water is not getting drain after its first cycle of process can any one tell me what might be the problem
The drainage pipe is blocked up. this is a common problem amongst washing machines. People forget to check the pockets before a wash and dirt and fibers start to get stuck inside of the pipes and soon it is blocked and will not drain or drains very slowly.
Solution is to take the machine outside and unhook the drainage pipe. most of the time the blockage is there and is easily removed.
If not, hook the machine up outside and when the drainage cycle is suppose to start try to see if the blockage can be removed by spraying high pressure water up where the pipe has been disconnected. The resulting push of water from both sides may be enough to breakup the materials blocking the pipe.
Apr 24, 2014 | Washing Machines
Mah7500aww
what it sounds like is the drain from your house wher the washing machine drain hose hooks into is daraining slow so after it spins and pumps the water out the pump shuts off but the drain hose is syphoning the water back into the machine,theres probally lint built up in your drain pipe
Jul 09, 2008 | Maytag Neptune MAH7500WH Front Load Washer
The machine won't sart. the code seems to be an L , followed by an F duet GHW9150POW the timer sounds to be running & cycle sset to cold/cold w/ only cold water hooked up. cycles briefly through...
If that is a new unit the hot water has to be hooked up as it will take in a small amount of hot water even on the cold cycle. whirlpool strarted this a while back due to energy use..try hot water let me know.....good luck.........
Jan 31, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine seems to work just fine, but right at the beginning of the drainage cycle, the water comes flowing up the tube as it should but quite a bit of it ends up on the floor. It's like the...
A properly clear outlet pipe should be able to cope with the output of a washing machine. If not it is partially blocked. try hooking the outlet pipe over the side of the laundry sink, If this works......leave it that way until you figure out who is going to unblock the outlet pipe.
Oct 20, 2009 | Kenmore 44102 Front Load Washer
The pump on the Bosch WFB 2000 front loading washing machine doesnt seem to be pumping all the water out, it leaves about 40mm of water in the drum. It though pumps and seems to be working, as it does pump...
  1. Check the filter is clean.
  2. Check that the outlet pipe is completely clear of debris and soap / detergent scum.
If this does not cure the problem then it may be there is soimething trapped in the water pump or thst the pump is actually defective which will mean a new pump is required.
To keep the machine clean of waste build up and to keep any bad odors away
  1. Remove all items from the washer.
  2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
  3. Close the washer door and dispenser drawer.
  4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
  5. Press Start and allow cycle to complete.
  6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
  7. Repeat the cleaning procedure monthly
Sep 12, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washing maching won't rinse in cold water
hi is this hot and cold water piped machine? ie two connections on rear of machine for hot and cold pipes ? if so are your pipes connected properly on machine and the water supplies? if cold supply is connected to hot supply then wash inlet allows water in washer then washes in cold? but when rinse is due? the elec valve that has hot water pipe connected?? is failing to open allowing water flow of hot on rinse so advise recheck pipes for flow of water from both? when disconnected from machine if flow ok then possible valve blocked/faulty hope you can understand above? if you can give more info on your machine it would help to offer a remedy?
Nov 01, 2008 | Hotpoint Washing Machines
Blocked drain
Is there still water in the machine or have you bailed it out? Some units have a serviceable water pump, meaning you can take the bottom of the pump off and clear gunk that has plugged it up. When you manually turn the dial to spin cycle, does it spin and push any water out even a tiny amount at a time? If not, take a large bucket and then place it on the floor next to the machine and place the drain hose in it. The bucket needs to be lower than the water level in the machine. When you do this, does it drain? If so this would solve the issue of whether or not the pipes are plugged. If in both cases either on spin or with the hose lower than water level, if it only drains a tiny stream then you do have a plugged line and you would need to disconnect the hoses from the pump under the machine and clear the plug. Be prepared for a lot of water to come out when you take the hose off of the pump. The plug is most likely in the hose coming out the bottom of the tank going to the water pump. This item has the hose leaving the machine going to the house drain. The other large hose goes up to the bottom of the tank. Good luck and let me know if you need more help.
Feb 03, 2008 | Creda W100FW Front Load Washer
Hotpoint Aquarius WF100 Fabric Cond not rinsing thru & PreWash lite flashing
this sounds like cold water supply not getting to the machine, test the supply from the house is working, is the machine buzzing slightly when it should be filling, if so the fault is the house supply to the washer, if the supply to the washer is fine, check the cold water solenoid for open circuit, thats about all it could be, if it worked fine before, if i have helped rate me please
Sep 18, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
114 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
