Question about Brother IntelliFAX 2800 Laser Fax
Black lines when using copier
Black thick lines come thru in the copies
  • Anonymous Feb 05, 2009
    thick black lines will not go away no matter what i do
    Genius:
  • 2,120 Answers
Lift up the document feeder and look for wite-out on the small glass.
If there is a sliding blue tab on the toner cartridge, move it back and forth 10 times. (cleans the charge wire)
Physically look at he drum, it should have no toner on it.
Posted on Sep 20, 2008
1 black line at the end of paper
if u take copy from adf scanner then clean the scanner glass. if the line is coming on print & copy both then check drum is there any line
Dec 19, 2012 | Sharp AR-5316 Advanced Digital Imager...
Thick black line appears 1/2 way across image when scanning
Try to wipe the scanner bed/glass with a soft cloth. If problem continues and the thick black line also appears when making a copy, it could be hardware problem. Then you will need to contact Lexmark technical support for additional assistance.
Apr 24, 2011 | Lexmark X1270 All-In-One InkJet Printer
Thick black line in all copies on sharp arm 162e
Dear,
when drum clean blade is weak then strongly can not clean toner,so thick black line in all copies.
Solve: Replace clean blade or service.If your copier drum life is zero,you can change it.
Nov 16, 2009 | Sharp AR-M162 All-In-One Laser Printer
Thick Black line
This issue occurs if the scanner lamp is not getting enough voltage.
make sure that the printer isn't connected to a surge protector,
also you may try making a copy of any document.
this will be a hardware test, a reset of the printer might resolve the concern.
since the reset requires technical supervision,
revert back for further clarifications.
Ronald
HP AIO Support.
Jun 13, 2009 | Lexmark P3150 All-In-One InkJet Printer
Thick black line
clean the roller and the catridge reel
Jun 11, 2009 | HP Photosmart 2575 All-In-One InkJet...
Thick black line through page when copying or scanning
Sounds like part of your scanner is not functioning and reading black all the time. Probably best to return it for a replacement.
Steve
Feb 25, 2009 | Lexmark X4875 All-In-One InkJet Printer
Sharp AR-207 copier puts .5 inch black line across entire bottom of copy
does the line only show up when making copies from the adf or both when you put it on the glass. if only when thru the adf the **** glass is dirty. that is the glass that is only about an inch wide. be carefull of the two pieces of tape that are on both the front and back of that glass they fall off easly.
Oct 18, 2008 | Sharp AR-207 Copier
Thick verticle line on copies and scans
Sounds like the issue is with the scanner bulb. May not be moving across or warming up to full capacity.
Make sure the scanner is plugged in directly to the wall and not into a surge protector or a power strip. If problem is still there and you are in warranty you will need to replace the unit. If OOW then you should call and see if you can repair or upgrade the unit at a discounted price. If you want to speak to someone in English tell them you want mac support - they are in Canada.
Jun 01, 2008 | HP OfficeJet 6310 All-in-One Printer...
Black lines on copies when run thru fax feeder
There is a thin strip of glass that you will see when you lift the top feeder. There is most likely white-out on it.
When you use the top feeder, it doesn't use the large glass, it only 'rolls' the original document over this small strip of glass.
Jan 18, 2008 | HP LaserJet 2840 Printer
Black lines at bottom of copies
a simple solution would be to check the drum. Also try cleaning the charge cortron wire. Need more info about the copier. Are you using the document feeder or the making copies of the platen glass?
Dec 13, 2007 | Office Equipment & Supplies
Brother IntelliFAX 2800 Laser Fax Logo
308 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
