My rca surround sound system keeps shuting down after 5 to 10 min saying protect shutdown i have checked all the wires none are touching cant figure out what the problem is
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 56 Answers
Or you are using more speakers than the system can load, or one or more of the speakers went down with the impedance values. That is, the problems basically is the nominal or specified impedance for the amp are between 8 to 16 ohms, if you got connected one or more speakers with less than that value, then the final amplification circuitry is working on a high current and therefore more internal heat, this the moment when it goes to a "protection function"
Posted on Sep 20, 2008
My ht-z31 dvd surround sound turns on and immidiatly says protect and shuts down. what do i do?
the protect means a circuit overload check that you dont have any wires for your speakers touching or backwardly installed if those are all fine you may have blown a fuse inside the receiver.
May 07, 2011 | Samsung 1000W 5.1-Ch. Home Theater System...
I need to make my speakers wires longer for my RCA surround sound
If your speaker have wires that are hooked directly to the speakers and there is no terminal, you will have to splice new wire onto the existing ones. Be carefull and use crimp connectors, available at Radio Shack, these connectors are best because they will keep the speaker wires from touching and damaging your unit.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Aug 18, 2010 | RCA RS1289 5-Cd Changer Mini Systemwith...
How do you hook up rca surround sound system to rca tv for sound
I can not figure out how to wire my 46" lcd rca tv to my rca surround sound.
May 21, 2010 | RCA L32HD31 32 in. LCD HDTV
Why protect pops up when i turn my surround then sound very low
Sounds like you have a short in 1 of your speaker wires.Make sure none of them are touching each other at the back of the unit.
Jan 11, 2010 | Samsung Audio Players & Recorders
It keeps on wanting to shut off like it is overheating but yet it is not hot...(Samsung DVD home theater system HT-TX72)
Check you speaker connection first and make sure none of the wires are touching another terminal. The unit might be going into protect mode. If so it should display the words protect on the display before shuting down. Try removing one speaker at a time while turning on the unit after each speaker is removed at a time, to see if it shuts down on you. When and if it stays on then the previous speaker you took off is defective.. If none of this works then you might have a bad Preamp circuit or main amplifier output problem. Disconnect everything from the unit and turn it on, to see if it shuts down on its own, if so then there is a problem with the internal parts of the unit itself.
Nov 30, 2009 | Audio Players & Recorders
Samsung 5-Disc 1200-Watt Home Theater Surround Sound System My Home Theatre System is keeps shutting down by its self. before it shuts down the screen says protection mode and then shuts down. i have...
If the unit shuts down almost immediately without sound, you have an electronic failure of the audio amplifier.
However if you must play the unit up above quiet background levels, you likely have a shorted speaker wire. With home theater systems, you have the luxury of trying different surround modes and speaker level settings. It's not unusual, for example, to have a loose wire strand going to the center speaker. In stereo, the system works fine. As soon as you switch to a surround mode, the amplifier senses the short and shuts down to protect itself.
Check those wires really close - I bet you'll find it there.
May 15, 2008 | Audio Players & Recorders
Surround sound keeps shuting off
the system go to protect mode in case of trouble in output stage(power output component and cords and speakers.
try to connect each speaker one by one until you find the bad one change cord first for the bad one and check if not working you must change speaker itself.if all above does not solve the problem you must pass your sony to service center
Mar 23, 2008 | Sony HT-DDW700 System
Proscan 32LA30Q & Surround sound
Make sure that your patch cables are cumming from the audio line OUT of the TV to the audio line IN on the surround amp. A common mistake on hook up is usually the problem.
Jan 14, 2008 | Proscan 32LA30Q Television
Denon surround saying protect on display
Make sure none of your speaker wires are touching, this will cause it to shut down instantly.
Oct 15, 2007 | Denon DHT500SD System
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
