Question about Dryers
Dryer really squeals - Dryers
    Novelist:
    Champion:
  • 261 Answers
Ok this is a really broad question, Kenmore will squeal when a belt tensioner or motor bearing is out, a frigidaire or small kenmore with control panel above the door and serial number starting with x will squeal when the bearing is out on the drum or the motor. This is a general cover on dryer noise with a model like Kenmore series 80 I can give solutions ok?
Posted on Sep 20, 2008
Really Bad Squeeky Noise
It could be a squeal from the dryer belt. It could be from a belt that has gotten loose, like you hear on a car sometimes when it first starts up, but usually they don't get loose. They just break. Maybe something has gotten jammed between the dryer drum and the interior of the dryer making it hard for the belt to turn the drum and so it is squealing. Does the drum turn by hand without too much force and without squealing?
Feb 10, 2014 | Siemens WTXD5300US Electric Dryer
My dryer makes a squealing sound when running. I believe it's the belt on the tensioner pulley, but I have no idea how to get to the darn thing.
There is no easy way, but its more time consuming really. I'm not familiar with your particular dryer, but you''ll need to remove the top and front casing of your dryer and remove the drum to get to the pulley. Sometimes you can get to it via a compartment on the rear of the dryer as well. Also listen to make sure the squealing isn't coming from the drum bearings on the rear of the drum.
Apr 27, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
My dryer is squealing very loud when it is on.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Apr 07, 2010 | Frigidaire Dryers
Really loud whirring/squealing noise
Yes, It is still safe but very annoying...
The source is probably the guide rollers for the drum or the belt tensioner pulley. To know for sure you will need to pull the dryer apart and turn it by hand slowly and see where the noise is coming from...
Heatman101
Mar 03, 2010 | Whirlpool Dryers
Squeals like a pig
Worn belt or not enogh tension on the belt(s). Remove the old belt(s) clean all the wheels and pully where the belt(s) go around with a rag and soap. Make sure the wheels are really clean and dry then install new belt(s).
May 22, 2009 | Maytag Dryers
Maytag gas dryer squealing
Hi, this is a belt issue. make sure the tension on the belt/motor is sufficient. adjust to specs. if the belt is fine, this will be bad bearings in the roller assembly.
Replace the rollers in this case.
May 21, 2009 | Maytag Dryers
Maytag Atlantis Dryer squeals
Try Repairclinic.com for help and parts. You are going to need heat resistant grease, and probably snap ring pliers.
Feb 28, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
263 people viewed this question
Top Dryers Experts
