Question about NEC MultiSync MT830 Multimedia Projector
How to reset Time clock on NEC MT830+ Projector
My NEC MT830+ projector automatic shut down - stop working after service of 2100 hours - the Status and Power LED is on. After then, I replace a new lamp unit for this unit and I don't have remote control to reset time clock - The projector still stops working. Can someone please help me out of this situation
  • Anonymous Feb 21, 2009
    my nec830+projector status light continues to flash and not powering up
  • shdiffff Apr 12, 2009
    i have a nec mt830+ as soon as it is turn on it goes to stanby,because the clock inside reach the aproximative working hours of a projector Lamp life... this is what i have to do to fix the problem,but i need the remote control and i dont have it...
    6. After you install a new lamp, select the lamp Usage icon and press and hold
    the "Power On" button on the remote control for ten seconds to reset the
    lamp time clock to zero.
    NOTE:
    If resetting the lamp clock back to zero after 2100 hours of service,
    press the "Power Off" (not "Power On") button on the remote control for ten
    seconds
Change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
seconds
Posted on Apr 12, 2009
I replaced the lamp on my NEC LT280, but am unable to reset the lamp so that the projector works again.
Whe the lamp exceeds 2100 hours (up to 3100 hours in ECO mode) of service, the projector cannot turn onand the menu is not displayed. If this happens, press the HELP button on the remote for 10 seconds to reset the lamp clock back to zero. When the lamp clock is reset to zero, the LAMP indicator goes out.
Here is the URL for the User Manual:
http://www.necdisplay.com/documents/UserManuals/LT380_user_manual.pdf
Dec 14, 2014 | NEC LT280 LCD Projector
VT595 LCD Won't come on. Power light orange Status red Blincks Once every sec or so.
If the lamp life has exceded its safe working limit, it will probably go into a permanent standby mode, I used to have an NEC MT830, I had to hold down the off button for 20 seconds to reset the lamp life, maybe it will be something similar. If you have your manual, it may give instructions, if not there will be a downloadable manual on the NEC website.
Good luck
Aug 09, 2011 | NEC VT595 LCD Projector
Cant clear lamp usage hours warning after replacing bulb on model NEC LT 157
Try holding the off button down for 20 seconds, it may be the on button. I had an NEC MT830 which had a standby function once it had reached and exceeded the lamp life safe limit. Once this had happened it wouldn't come out of stanby uinless the lamplife was reset. Your user manual should have the correct method of reset
Good luck, hope I was of assistance
Jul 14, 2011 | NEC LT157 Projector Lamp Module (50021668)...
My nec projecter lamp status is just red on and not working any idea
Usually the unit will go into permanant standby if the lamp life exceedes its safe limit. I had the MT830/1030. To reset it I had to press the off button down for upto 20seconds which resets the lamplife. If not the off button it was the on button.
Good luck
Jun 12, 2011 | NEC (MTLAMP820/1020) Projector Lamp for...
I have a NEC mt1055 and the unit just had new bulb put in here and it has the power and standby light come on and the fan doesn't turn on here and the standby light is yellow and status is red
The NEC’s work on a reducing time basis, they count the hours that they have been operational and refer to this as the life of the bulb – 1600 hours. When the 1600 hours has been reached the projector shuts itself down into standby mode never to be restarted even after changing the bulb / filters. This is because the unit needs to be reset, which needs to be done as follows (not included in any of the bulb replacement instructions):-
  • Plug Projector in so it is in standby mode – Orange light lit, Red status light lit (not flashing)
  • Using the remote control, hold down the power off button for 30-45 seconds
  • This will reset the status button, removing the red light
  • Power up the projector and select Menu
  • Select Projector Options
  • Select Set-up – a number of tabs will appear called pages
  • Arrow across the pages (MT850 is Page 5) until an option called “RESET LAMP HOURS” is shown
  • Move onto this option and press enter on the projector itself, confirm that you want to reset the counter
  • Projector is now back to life
This works for all NEC projectors, the page number may be different though where the “RESET LAMP HOURS” option resides.
Oct 07, 2009 | NEC MT850, MT1050, MT1055, MT1056...
Preylahong NEC MT830+need help to reset new lamp
After replacing lamp in MT-830(NEC) press and hold "on" button for 10 seconds to reset lamp hours. If projector has beyond 2100 hours press the "off" button for 10 second.
May 01, 2008 | Office Equipment & Supplies
Blinking status light
Replacing the lamp with an old one was helpful for me. Good news: the projector itself not faulty. Bad news: I have two projectors with the same issue at the same time (the lamps were replaced also at the same time) after only 400 hours of running.
Apr 01, 2008 | NEC VT47 Multimedia Projector
NEC VT47 Blink Sequence but not comming up.
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Feb 08, 2008 | NEC VT47 Multimedia Projector
Status light blinking red
Oct 23, 2007 | NEC VT47 Multimedia Projector
Problem with NEC Multisync MT830
Check to see if the fan is running on the bottom of the unit. If it senses no rpm from the fan, if will shut down to protect the unit.
Jun 26, 2007 | NEC MultiSync MT830 Multimedia Projector
NEC MultiSync MT830 Multimedia Projector Logo
1,152 people viewed this question
Top NEC Office Equipment & Supplies Experts
Electro Med Services...
Jaime Hernandez
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
