Question about Electrical Supplies
Generator shutting down after 1.5 of run time
I have a 4500 watt generator with a briggs and straton 8 hp vanguard ohv engine. After an hour and half teh generator shuts down on its own. I changed the fuel filter and oil and it didn't change anything.
  • triking Sep 25, 2008
    I have an 19 HP 10000W Generac. It does the same thing ... it will start now and only run 10 sec. to 2 min. I have tried disconnecting the wire that goes from the oil switch to the circuit boards...but still no luck. What wire do you disable to keep it running?
I had the same problem with a simular generator. I took it to a repair shop who told me it was the "low oil sensor". They fixed it and it lasted another 1.5 hours. I told my-self I would monitor the oil and cut the "low oil sensor" electronic line. It has laster 12 years as a backup generator running at least 200 hours per year. I still have it but have switched to a larger generator. If you, or whoever uses it, can watch the oil level, then cut this line, it will be fine. This sensor is for those who are not able to measure oil level !!!
Posted on Sep 21, 2008
I have a 16hp v twin on a prusserwasher that bogs down under load
Check for intake leaks. restricted fuel line. air cleaner anf fuel filter.
Jun 14, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Vanguard Briggs & Stratton won't shut down
Your kill wire from the switch to the coil is bad,disconnected or connections dirty...or switch is bad...try disconnecting the kill wire on the coil and using a jumper ground the coil directly to the engine or frame it should shut down if it does it is the wire or switch do the same at the switch if it shuts down it is the switch..if not the wire has a break..good luck..
Feb 04, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
I have a B & S vanguard 20 H.P. vert. shaft, 8 years old on Simplicty tractor. Keeps fouling plugs. Clean or replace plugs and it runs fine for about 1/2 an hour then starts to miss, blacksmoke, and...
Anti-foul plug adapters might be a temporary solution (treats the symptom and not the cause).
Personally, I would take it to a good, reputable, small engine repair shop that has verifiable references, and have them repair it.
Aug 03, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I am considering purchasing a used Exmark with a 23 HP Vanguard engine (~70 hours on the engine). I've not been too pleased with Briggs (have one on my John Deere garden tractor - hot natured and...
yep its a briggs and normaly there very good ploders
if your john deere spluters and back fires it needs a good looking at check the valves first,,,a hand full of bolts and the heads off and if your carfull you can still use the same head gasket again,,,also check the carb there very finiky and need to be kept clean the air filter is a joke,,,but clean it anyhow and they like new plugs,,,every ten years or so? iv worked on 100s of brigss and stratons/vanguard. there good engines but there ploders not sprinters there ok in a tractor but no good in a tank there to darn slow
Mar 27, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs 14 HP Vanguard runs well until PTO is engaged
First thing u might want to check is the governor--Make sure the spring and linkage is hooked up properly and the governor is moving freely.
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
I have a potable generator that will not turn's a 16.5 briggs vanguard v-twin motor.i replaced the coils and the diode wiring assembly.i fill the diode assembly might be that possible?
Are you saying the engine will not turn off? The engine shut down uses a ground on the ignition circuit to shut down. This kills the circuit that provides the spark for the engine to run. See if you can trace the circuit for the shut down and check the ground connection.
Mar 09, 2009 | Briggs & Stratton 8,000 Watt 16 Hp...
Electrical Supplies Logo
515 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
