Question about Archos 604 Digital Media Player
Archos 604 video file won't play on PC, only plays on archos 604
I recorded three video files on my Archos 604 today, one right after the other, all using the exact same video line input, from the exact same video camera. All three video files play well on my Archos 604, but when I copy the three video files to my PC (using the Archos 604 as an external hard drive), the first video file plays well, but the 2nd and 3rd video files won't play on my PC. When I try to play the 2nd & 3rd video (.avi) files on my PC, the video playing software shows the following message: "copy protected video file can only be played by the original recording device".
I then recorded two more video files with my Archos 604, with the same video camera input, and these video files play well on my PC, with no problems.
I did NOT change any settings in my Archos 604 between these recordings.
How do I:
1. Enable these files to play on my PC; and
2. How do I make sure this doesn't happen again.
Thanks!
Kevin
KevinHines@aol.com
  • Jsintime2001 May 07, 2009
    I am having the same problem, in converting my old VHS-C cassettes into a digital format using my Archos 605. My best guess so far is that the tapes i am using have an embedded copy protection, as when i get to a certain spot in the video, 7:35 minutes in on one in particular, the archos stops recording, starts a new file, and then resumes recording. The first file is viewable on the PC, while the second is completely copy protected and unviewable, although there is audio.
    I've tried using an in-line device that claims to remove all copy protection signals including 'Macrovision". The problem persists.
5 Suggested Answers
bizzyb0t
  • 26 Answers
SOURCE: no power going into my archos 604
If the unit was dropped, you may have to replace the battery. The batteries for those units are lithium-ion-polymer and are somewhat fragile when dropped. The other possible reason it is not working is that the shock form the drop has "bricked" or killed your unit's internal circuitry. I would also try charging it with another USB connection as the USB connection you are using may not be powerful enough to charge the unit. For more detailed help you can try the forums at ArchosFans.com There are many technical experts concerning Archos Units at that forum.
Posted on Oct 12, 2007
SOURCE: Buttons are stuck!! (Archos 604 - no wifi) PLEASE HELP
i have te same problem with the >> << X and menu buttons
Posted on Jun 15, 2008
SOURCE: Archos 604 will not restart
i had this problem recently when charging on the DVR docking station, i switched it off, took the battery off, left it for a shirt time then pressed the reset, it took a few attempts but eventually it restarted
Posted on Aug 29, 2008
SOURCE: I can't play all AVI's on my Archos 605
Yeah you need to go to the archos website and buy the cinema plug in (£14.99) if you want to play all. the only other option is to convert the avi files that you cant play. Also if you want to play any mpeg4 files and quite a few other files with different audio codecs you need the podcast plug in (again £14.99). This is the only way to be able to play everything on your archos without converting the files - it's a bit of a rip off as each set of plugins is specifically downloaded for a product key so you cant even get one from someone else - believe me I have tried for days to get them free!
Hope that helps!
Posted on Nov 26, 2008
SOURCE: Archos 704 Wifi - does not play AVI file until its full lentgh
I had the same issue.
The size of the AVI cannot exceed 1gb or the end of the movie will never play.
I had a movie that was 1,7gb. 2 hrs and 15 seconds.
The Archos recognized this as a 1.7gb file and 2:00:15 long.
As soon as the movie started, the time line bar at the bottom of the screen went from 2:00:15 to 1:10:25. Basically, it cut off the last 50 minutes of the movie.
I simply divide the movie into 1gb chunks.
I decrypt the DVD to the computer
Use Nero Recode to convert it to and MP4. Divide the movie into 1gb chunks and Maximize the Volume.
Use SUPER to convert it to an AVI / MPEG-4 / MP3.
Copy this to the Video folder of the Archos.
This is simply something that Archos does not want to admit is an issue. They want you to purchase the Cinema plugin.
Posted on Jan 29, 2009
How do I play .wmv on my archos 70?
Following the instructions on this site you should be able to convert your .wmv files to ones that will play on the Archos. http://www.riverpast.com/en/support/tutorials/convert/wmv/archos_video.php
Feb 28, 2011 | Computers & Internet
Downloading of dvd on to arcos 7
I use this software to copy DVD for my PSP, works great.
http://www.123copydvd.com/
Jul 12, 2010 | Archos 7 Digital Media Player
Copying Video from archos 605 wifi to computer
I think the Archos 605 has a 2gb file limit, so the only option would be to split the avi.
Search on Google for an avi splitter - there are some free ones out there.
May 06, 2009 | Archos 605 WiFi Digital Media Player
Archos recording corrupted when battery died
There is no solution to this problem i am sorry but you will have to record it over i asked the Archos company themselves and their is no solution
Feb 09, 2009 | Archos 605 WiFi Digital Media Player
Archos 105 video
If you google realplayer converter you should find plenty of programs to do it for you.
Mar 20, 2008 | Archos 604 WiFi Digital Media Player
Archos 604 wifi
why dont u try to upgrade the firmware?
Jan 27, 2008 | Archos 604 WiFi Digital Media Player
Archos 605 WiFi "Cannot play video! Please Check"...
This problem seems to occur when the device overheats. It doesn't make a whole lot of sense, but all my videos set at 720 by 480 wont play when the device is left running for a long period of time. The smaller video files, however, still play. I think it deals with the amount of system resources required for such files to play. If you turn the device off completely by going to menu, power, and turn off device, and leave it sit for 30 minutes, all files should play properly when you turn it back on.
As a suggestion, DO NOT leave your Archos powered on and on the dvr station. This causes the device to constantly run, and if you havent noticed the Archos operates at an extremely high temperature.
Jan 09, 2008 | Archos 605 WiFi Digital Media Player
Downlaoding movies
Once you have downloaded the file to your PC simply connect your archos to your pc using USB cable provided, select PC hard drive mode, and simply copy or drag and drop from one destination to the other. Your Archos usually appears as J:Archos604WiFi if you have a built in card reader if not it may appear as an earlier letter in the alphabet.
Dec 27, 2007 | Archos 604 WiFi Digital Media Player
Archos 604 Digital Media Player Logo
509 people viewed this question
Top Archos Audio Players & Recorders Experts
Justin
Justin
George Hoggarth
Level 1 Expert
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
