I have a Panasonic Toughbook CF 52 and my wireless has been disabled, how do I enable it again?
  • bgrayson Sep 20, 2008
    If it's not showing...could it have been hidden or removed completely?
    Problem Solver:
  • 40 Answers
Windows xp.
Open up "control panel" then open up "network connections" then your wireless device should be there. If it is disabled it should say.
Windows vista
Open up control panel then open up "Network and Sharing Center" then click "manage network connections" should show there.
Posted on Sep 20, 2008
  • Tenny321 Sep 20, 2008
    1. Right-click My Computer then select Properties
    2. Select the Hardware tab
    3. Click the Device Manager button
    4. Under Network Adapters if there is a wireless item there with a red x or yellow ! then you have a problem.
    Try to delete that and then restart
    If that does not work then go to your computer makers website and click support or drivers, then seach for your model and then download the wireless drivers.
How to disable mouse pad double tap
On all Panasonic Toughbook models, if the Touchpad driver is
properly installed then you can disable the "TAPPING" feature.
Check under device manager. If the driver says PS2 Mouse,
then you need to locate your touchpad driver. Otherwise
locate the advanced setting under MOUSE under the control
panel and find "TAPPING" and un-check to disable feature.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
May 10, 2014 | Panasonic Toughbook CF-52 (CF-52ELNBDAM)...
Panasonic Toughbook CF-52Mxxxx Qualcomm HS-USB driver cannot be found by CSA.
See if you can see the Qualcomm HS-USB driver in Control panel>device manager. From there you can click update drivers and manually search for a driver. This way you do not need to use an EXE file.
Feb 11, 2014 | Panasonic Toughbook 52 Notebook -...
How do i enable touchscreen on panasonic toughbook cf 30ctqazbm
The first thing I would try on any Panasonic Toughbook with touchscreen would be to enter the BIOS upon start-up by pressing the "F2" function key. When you are in the BIOS, there is a setting on the 2nd screen tab "Main" which says "Touchscreen:". This should be set to "Enable" instead of Disable. Then you press the "F10" function key and the message: "Save configuration changes and exit now?". Press "Yes" and the toughbook will reboot and your Touchscreen will be enabled at the BIOS level.
Good Luck!
Regards from Richard, Montreal based Panasonic Canada Authorized Toughbook Dealer since 1989.
Dec 27, 2012 | Panasonic Toughbook CF-30 Notebook
Cf-30 disable touchscreen
On all Panasonic Toughbook Notebooks,
you must get into the BIOS by pressing
the F2 Function key when you turn on the
Toughbook as it is booting. Press F2 repeatedly.
This must be done in the 1-2 seconds before
Windows starts to load. Then you will see
Touchscreen usually on the 2nd page with the
word "Enable". Simply select enable and press
"Enter" and the choice between enable and disable
will appear. Then select "Disable" with the cursor
and then press Enter. Finally you need to
"Save and Exit" the changes in the BIOS.
That is it. Good Luck to you.
Regards,
Nov 13, 2012 | Panasonic Toughbook CF-30 Notebook
How can I enable wireless for none wireless module of CF-R8?
I suggest staying away from BIOS flashing. Last thing you want is a brick.
In Win 7 - Go to Start > Control Panel > Network and Internet > Network and Sharing > Manage network connections. Enable the wireless card.
In XP - Go to Start > Control Panel > Network Connections. Enable the wireless card.
Oct 14, 2012 | Panasonic Toughbook CF-R8 Core 2 Duo...
Can not enable wireless on toughbook cf-52 "radio is off"
Most Panasonic Toughbooks have a Physical On-Off
Wireless Switch Built-In. I belive the one on the CF-52
is located on the front right-hand side hidden behind
the handle. It is a small switch and you must slide it
to the right side (On) as opposed to the left side (Off).
Most modern Toughbooks also have a Wireless Switch
Utility which may be required. If so, you can find the driver at:
http://pc-dl.panasonic.co.jp/dl/search?q=&button=&dc%5B%5D=002001&p1=&p2=&oc=&lang=
That is it. Good Luck.
Regards,
Oct 07, 2012 | Panasonic Toughbook CF52 Notebook
Keyboard is stuck in numeric mode. Can't type
On the Panasonic Toughbook CF-51 there is a key located on the top right next to the F12 function key called "NumLk" or Num Lock.
Press this key once and the embedded numeric keypad is enabled.
Press it a second time and it is disabled.
How do you know if it is enabled or disabled?
Simple: Observe the LED above the keyboard. If the second light with the square symbol and the number "1" is lit up, then the NumLock is enabled. If that LED is not lit up it is disabled.
Good Luck.
From Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
Oct 02, 2009 | Panasonic Toughbook CF-51 Notebook
Wireless connectivity
possible reasons that it is "off"
Physical switch on outside of case that has a turn on and turn off function. Make sure this is turned on.
Go to network places and find the connection that says wireless (or something similiar), it should say Enabled, if not then enable it.
Jun 21, 2009 | Panasonic Toughbook CF-51 Notebook
Instructions to replace the LCD screen on a Panasonic CF-52 Toug
Trying this link to see if you can get this information.
Its Panasonic's website, toughbook section
Also try this link.
Mar 19, 2009 | Panasonic Toughbook 52 Notebook...
Keyboard installation for CF-52 toughbook
Here you , this is a step by step disassembly guide with pictures
Its for a Toughbook CF-50 but it should be similar as theres not too much difference in the model number
http://www.machinaelectronics.com/store/library/article.cfm?f=key_type_k17
Jan 04, 2009 | Panasonic ToughBook 52 Notebook
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
