Question about Brother LS-2125 Mechanical Sewing Machine
How do you thread the bottom stich on a brother sewing machine?
  • 21 Answers
Most of the newer machines have a drop in bobbin that the bobbin turns anti clockwise if it is in correctly lower your needle foot and it should pull up the thread.
Posted on Sep 21, 2008
When iam stiching the bobbin thread is not interlocking with the pool thread ,the straight stich is not stiching properly
Do you have thread in your bobbin?
Is your needle fully inserted in the needle bar?
Is it the right needle for the machine?
Is your needle damaged, bent or dull?
Jul 26, 2012 | Singer 7470 Computerized Sewing Machine
While sewing, I am getting skip stiches from the top and lot of thread is accumulating at the bottom, as a result it's getting stuck. Please advice. Thanks
I suspect the thread has not passed through the tension discs correctly. Try re-threading and remember to raise the pressure foot when you thread. Or try cleaning the tension discs as there may be stray bits of thread stuck there.
Apr 03, 2011 | Brother Sewing Machines
HI, I haven't used the brother 2125 sewing machine for months. There was no stiches coming out after I started it this morning. I tried many times. The motor is fine, threads from up and the bottom are...
Totally rethread your machine and insert a new needle, you may have a bent needle. Your thread may be tangled, and your bobbin may not be inserted right. If, you don't have your manual go to brother-usa.com and download a manual for free. It should answer all of your questions
Sep 12, 2010 | Brother LS-2125 Mechanical Sewing Machine
Top stitche is to tight and bottom stitche is to loose
Meaning you have adjusted the tension for the top thread as well as the bobbin?
Use two distinct colors of thread - one for the top and one for the bottom.
Thread the machine with the presser foot up.
The two threads should meet in the middle of the stitch with neither obvious on the opposite side of the seam.
Set the top thread tension to 4 and adjust the bobbin as needed.
May 01, 2010 | Brother CS6000i Computerized Sewing...
Tension is gone loopy stiches both top and bottom.
Lift the presser foot when you thread the machine and this should resolve the problem.
When the foot is up, the tension is open and can accept the thread as it should.
When the foot is down, the tension can control the flow of thread according to the setting you have selected.
Feb 19, 2010 | Brother LS-1217 Mechanical Sewing Machine
Appearence of loop and no zigzag stich on ls-2125i brother
The loopy stitching is usually do to threading the machine with the presser foot down.
Raise the presser foot and re-thread or pull about 8" of thread through the needle and see if the loopy stitches go away.
This may also be the issue with the zig-zag stitch.
When the machine is threaded with the presser foot down, the tension is closed and the thread cannot enter as it should for the tension to control the flow of thread to the needle. The thread then feeds too fast and the stitching is distorted.
Feb 17, 2010 | Brother LS-2125 Mechanical Sewing Machine
The top stiches are overlaying and the bottom stitch is loose
Remove the thread from the machine.
Raise the presser foot.
Turn the handwheel until the take-up lever is at it's highest position.
Set the upper tension to 5.
Re-thread the machine.
Oct 01, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother 925D - threads do not lock
threads do not overlock stich
Aug 11, 2008 | Brother 925D Serger
Stiching
It sounds like a thread tension problem. Find the knob for the tension and play around with it (look for instructions in the manual). If that doesnt work it might be the bobbin thread thats too lose in which case I would take it to the store or a repair service and have them show you how to do it.
Jan 05, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
50 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
