Question about HP Computers & Internet
My computer wont boot NTLDR shows - HP Computers & Internet
    Problem Solver:
  • 40 Answers
Have fix this problem. I used this site to fix it
http://www.tinyempire.com/shortnotes/files/ntldr_missing.htm
Good luck
Posted on Sep 20, 2008
When uploading windows 7 I get a message: Can't load windows at this time because of a hardware configuration problem or I get missing NTLDR how do i fix this?
First make sure there are no Disks in any of the drives CD , Floppy and Usb
Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS.
Corrupt NTLDR and NTDETECT.COM file.
Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32
New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CDROM First verify that no FLOPPY DISKS or CD is in the computer, unless you are attempting to boot from a diskette Test all power and data leads that attach to your hard drive including IDE,SATA if ita flat 40 pin ribbon type it will be the first to fail. The leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty Make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
also When NTLDR is missing from your operating system it means that there is a problem with your boot loader, a bootstrap process that begins when you turn on the computer. A missing NTLDR means that your computer cannot boot to the operating system. This issue is only a problem on computers running Windows XP or previous operating systems as Windows 7 and Vista don't utilize NTLDR. Fixing the missing NTLDR is relatively easy so long as you have your installation disc.
Locate your Windows XP/2000 installation disc and place it in your CD/DVD ROM drive. If you don't have this disk, then you cannot proceed further. Restart your computer. When the computer restarts press any key on your keyboard when you are prompted, "Press any key to enter setup." Most computers are configured to boot to another device other than a hard drive. Since the Windows XP/2000 installation disk is bootable, you should see the prompt. However, if you don't see the prompt you may need to change your boot priority in your BIOS. To do so, enter the system BIOS by following the onscreen instructions upon startup. Then navigate to the Boot Priority menu and modify another device, such as a CD-ROM to boot prior to the hard drive. Then reboot your computer. After you have pressed any key, the Windows XP/2000 setup screen will appear. After loading, press the "R" key to repair the Windows installation. The screen will appear black. The computer requests which installation you would like to log in. Generally speaking, press "1" and "Enter." If you have more than one hard drive or more than one partition, the procedure may be different. You must know which hard drive or partition your Windows operating system is installed in. You are subsequently prompted for a password. If you haven't set up one up, you can just leave the query blank and press "Enter." The phrase "c:\WINDOWS>" and a blinking cursor subsequently appear. Type "copy d:\i386\ntldr c:\windows" (without quotes), where "D" is the letter of your CD/DVD ROM drive (your optical drive may be different, especially if you have more than one). Eject the CD from the drive and type "Exit" (without quotes) to restart your computer. The NTLDR file will be copied from the installation disc to your hard drive.
or If you've started your Windows XP computer and you see an error message to the effect that the "NTLDR" file is missing or corrupted, you've probably also noticed that the computer refuses to boot any further. This is because the NTLDR file is an integral part of the boot process and needs to be restored before the boot process can proceed normally.
Insert your Windows XP disc into your computer. Restart the computer and press any key on your keyboard when the message prompting you to do so appears. Press the "R" key to open the Recovery Console and then press "1" and "Enter" in order to select your operating system. Type in your Administrator password (if needed) and press "Enter." Type "copy d:\i386\ntldr c:\" and press "Enter" and then type "copy d:\i386\ntdetect.com c:\" and press "Enter." Restart your computer and let it boot up normally. Since the NTLDR is freshly restored, the computer boots up properly. b> b>
Mar 02, 2013 | Dell Dimension 3000 PC Desktop
After system recovery using recovery discs of "PowerSpec" error message "NTLDR is compressed PressCtrl Alt Del to restart" appears .How to fix it
When NTLDR is missing from your operating system it means that there is a problem with your boot loader, a bootstrap process that begins when you turn on the computer. A missing NTLDR means that your computer cannot boot to the operating system. This issue is only a problem on computers running Windows XP or previous operating systems as Windows 7 and Vista don't utilize NTLDR. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD ROM First verify that no Floppy Diskette or CD is in the computer, unless you are attempting to boot from a diskette. Fixing the missing NTLDR is relatively easy so long as you have your installation disc.
Insert your Windows XP disc into your computer. Restart the computer and press any key on your keyboard when the message prompting you to do so appears. Press the "R" key to open the Recovery Console and then press "1" and "Enter" in order to select your operating system. Type in your Administrator password (if needed) and press "Enter." Type "copy d:\i386\ntldr c:\" and press "Enter" and then type "copy d:\i386\ntdetect.com c:\" and press "Enter." Restart your computer and let it boot up normally. Since the NTLDR is freshly restored, the computer boots up properly. Hope this helps.
Jan 16, 2013 | Computers & Internet
Error message "NTLDR is compressed" how to fix it
Jan 16, 2013 | Micro Electronics PowerSpec 6236 PC...
How do fix Hp compaq d530 ''NTDLR missing''
First make sure there are no disks in any of the drives cd floppy and usb Computer is booting from a non-bootable source.
also
or
Hope this helps.
Dec 03, 2012 | Computers & Internet
Dell Dimension 5150 desktop will not boot into windows xp home. I disconnected everything except hdd, keyboard and mouse. Same problem...will not boot into windows xp home. Did the recovery console...
Im sure the boot sector is a mess. If the cd wont fix the boot sector you may have to copy all his personal files from dos and restore the computer to factory settings.
Aug 25, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Ntldr missing
Thats the boot loader, youll have to do a system recovery using a disc that came with the computer. if you dont have a disc then u may be able to download a iso disk image from the gateway site.
Jan 20, 2010 | Gateway GT5220 PC Desktop
NTLDR is compressed -- on my emachine laptop -- I seem to be in a vicious circle here.
You can try to fix the NTLDR compressed issue by repairing it using the Windows XP OS Installation Disc
1. Restart your computer, make sure that the boot priority is on the DVD/CD Rom drive
2. Press any key to boot from CD...
3. When the Welcome setup shows up press "R" to go to Recovery console
4. Press 1 to choose the drive where the OS is installed, or a different number if your computer is configured for multibooting
5. Just press enter for the password, but if you have administrator password type in your password.
6. Type this command without quotes "attrib -c ntldr"
7. Restart your computer and it should fix the problem, if not, tell me what happen
Jan 01, 2010 | E-Machines eMachines Desktop PC
NTLDR is missing
Reference number: CH000465
NTLDR is Missing. Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
You can go to these sites to view solutions (to much to post here) Very easy to understand:
http://www.computerhope.com/issues/ch000465.htm
May 22, 2009 | E-Machines eMachines Desktop PC
What is NTLDR
NT Loader (NTLDR) is a small piece of software loaded from the boot sector of your primary hard drive that helps your operating system start.
If you have multiple operating systems installed and properly configured, NTLDR will show a boot menu when your PC starts, allowing you to choose which operating system to start.
Thanks for using FIxya
SAM ANDERSON
Oct 04, 2008 | HP e-PC 42 PC Desktop
I receive an NTLDR error at boot up.
dude just copy the ntldr on other pc or windows....slave ur master drive on other pc that has windows then on other pc click my computer then tools then folder option then view then click show hidden files then uncheck hide protecting operating system...then back to my computer drive C: then all hide files will be seen then copy the NTLDR there into your harddisk put it in Drive C:
Sep 01, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
