Question about Belkin Computers & Internet
Belkin MIMO FSD 9630 - wireless router with 2 connections. working fine then last night we lost connection. An orange light is on the router - don't know what caused the problem but would like to fix it so that we can access the internet again.
  • trish53 Sep 20, 2008
    Thanks - I have powercycled (again, but this time it worked) and pressed the re-set button; I don't have an orange light, but I still cannot access the internet.
    Further suggestions?
    I have a belkin MIMO FSD 9630; I no longer have an orange light... but I still cannot access the internet. Any solutions?
    Master:
  • 441 Answers
You need to reconfigure the router since you reset it. If you have a cable internet use the MAC clone feature of the router, and if DSL, know if your have a username and password with your ISP.
I suggest you contact Belkin tech support so they can walk you through the process of reconfiguring the router
Posted on Sep 20, 2008
    Genius:
  • 1,550 Answers
  • You might have a corrupt TCP/IP stack. Try uninstalling/reinstalling TCP/IP via control panel -> Network Connections -> right click on your LAN connection, select TCP/IP and uninstall it.
  • Download the latest version of belkin in drivers from the website via connecting to internet via ethernet cable (wait are you able to connect to internet via cable if yes proceed further)
  • Belkin on some products might let you use either thier own software of windows WiFi connection software to use your wireless connection.
  • To ensure that it is fault of the belkin device, connect via the Ethernet cable to your router and see if your computer can get an IP address and maintain the internet session.
  • NIS if working properly will automatically recognize that you are trying to connect to a network and ask what kind of connection/ profile you are using example : Home / away / Office
Thanks for using Fixya
SAM ANDERSON
    Brigadier General:
  • 6,966 Answers
If I may add after the reset...
To my knowledge, the Belkin MIMO FSD 9630 is a combination modem/router. With this in mind, it needs to be determined if Internet is available even before the input to the modem side. If the 2wire system is bundled with a telephone, try checking if you have a dialtone, if it is a dedicated data line, it would be needed to contact your ISP.
Of course the alternative is as the other posted, you have a defective Belkin FSD9630.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    President:
  • 1,263 Answers
When you reset the router you lost the proxy settings so the computer doesn't interface with the router. use your install cd for the router and go through the steps again. this will re-establish the connection to the network. when you go into your network connections menu make sure that your router is the default device. if it is a key coded network ( secure) re-enter the key code on the selected network. if it is unsecure you should be able to just click on that avaible network and the connection should be re-establish... please rate the solution....thanks
  • 1,800 Answers
Try now to configure it type
1/192.168.1.1
2/admin admin default username and password
3/chek the set up see any connections rerfers to the one that u ve
4/ use the manual to enter the configuration
rate me so i can help u further
    Sergeant:
  • 264 Answers
After powercycling the Router. You should also restart the computers. The best way to do is. Turn of the
Also if there is any modem connected to the Before Router, you need to Turn off that.
Than you need to turn off the Router and both the computers
Than Turn on the Modem (If any) Wait for 2 mins till it stabalizes.
Than Turn on the Router . Wait two minutes till it stabilizes.
Than turn on the computers one by one.
You should be able to work fine on your network than
All the Best
Sammy
  • Sameer Kashyap Sep 21, 2008
    As it was working before on the same computer, than you should try System Restore on computer.
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    After you've decided to use System Restore to
    revert your system to a previous state, start the System Restore Wizard and
    follow the prompts. To use the System Restore Wizard, make sure you're logged
    on as an administrator, and then follow these steps:
    1. Click Start, point to All
    Programs
    , point to Accessories, point to System Tools, and
    then click System Restore.
    2. On the Welcome screen, click Restore my
    computer to an earlier time
    , and then click Next.
    3. On the Select a Restore Point page,
    select the date from the calendar that shows the point you'd like to restore
    to, as shown below, and then click Next.
    Note: - ****Select a date when everything was
    working fine****
    4. On the Confirm Restore Point Selection
    page, verify that the correct restore point is chosen, and then close any open
    programs.
    5. Click Next if you are ready to
    proceed or click Back to change the restore point.
    6. The computer will shut down automatically
    and reboot. On reboot, you'll see the Restoration Complete page, and
    then click OK.
    You may always undo the System Restore OR
    choose another restore point after checking your system. To do the same just
    open System Restore and make the appropriate choice, you'll have an additional
    task; Undo my last restoration, on the System Restore Welcome page.
    Caution: - Whenever you do a system restore remember that you'll
    have to reinstall any programs that were installed after the restore point
    selected.
  • Belkin Master
  • 6,487 Answers
First thing to do here is to reset the router, to reset iot Press and hold the reset button for 15 seconds while the power is ON, then fater that unplug the power for 5 seconds then plug it back in, if you still have the setup CD just run it again and that should reconfigure the router back if still not working better contact Belkin support to so one of their tech can walk you through with that process in checking the router...
Hope that helps..........
  • Mark Gil
    Mark Gil Sep 20, 2008
    It seems that the router is bad already , because if its still in good condition after you reset and reconfigure it that should be working fine now, so the enxt step here is to contact Belkin support for this concern.........
    Problem Solver:
  • 40 Answers
Try to power cycle the modem and router. this will not delete any settings it will just restart the device.
Can a belkin network card f5d7050 work with a belkin g plus mimo router
As MIMO is compatible with all wireless g products there shouldn't be any issues at all....
so some questions:
  • do you have other wireless devices working with the router? if so can you duplicate their settings for this n/w card?
  • have you set security on the router?
  • what are you using to connect to the network the windows interface (assuming it's PC not MAC based) or the Belkin one?
i have a linksys g n/w card attached to my MIMO router & it's fine so I'm sure that this is solvable!
Sep 06, 2010 | Belkin F5D9050 Wireless G Plus MIMO USB...
Belkin Wireless G Plus MIMO router - connectivity problem
  • this problem can be ISP releted they may have some issues on the ADSL line connection
Aug 10, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
The light with the globe is constantly blinking
If you tell me the version number of your Belkin mimo wireless router , i will fix this issue.Any Routers issue contactme,, i will help you out. copy and paste this URL to your Browser http://techhobbies.blogspot.com
Feb 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cannot mae my belkin wireless router secure
type in http://192.168.2.1 in start>run>
you will get the interface which say Router set up page
>click on security under wireless extream left
>if you have password enter click submit (if not) live password blank click submit
>select the security type
>creat the password
>apply changes
>cloce the belkin page
> and connect the wireless computer to the secured network
Feb 20, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Lost password into router need reset
Use the reset button near where the AC adapter plugs in. Hold it in for at least ten seconds. This should set it back to factory, allowing you to set another password.
Jan 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Internet connection to ps3
i had a problem similar to this. i just switched the router off then back on again and it worked and i haven't had a problem since
Jul 05, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
New belkin router not working properly
Word of advise, Belkin is terrible.... any kind of device I have gotten from them never worked properly, ether that or they have some extremely weird way on how to operate them. Yes they are cheaper but there is a reason for that. Go for a linksys router.
May 04, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
111 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
