Question about Dryers
Whirlpool Dryer Model LER88620PW0
I am looking to find a detailed diagram of how and where to attach the tension pulley in a Whirlpool Dryer Model LER88620PW0. The one in my dryer has come loose and I cannot tell where it goes back to or how to secure it.
  • 5,911 Answers
Go to repairclinic.com and click on the "Repair Help" link in the left column of the page. On the next page under the "Special Features" section there's a link entitled "Dryer Belt Diagrams". There are two diagrams listed under Whirpool (H and K). Since you stated that the tension pulley came loose in your dryer, I suspect you need to look at diagram "H". Diagram "K" has a tension spring and is fixed in place. I hope this helps you. Let me know if you have questions.
Posted on Sep 20, 2008
Whirlpool dryer model WED5500XW heats up but drum will not spin. Belt is still on the drum. Any ideas what to look for
Hello Betty Lue Sydnor...
Great question! Better detail...
The Belt is still on... it is either your drive pulley or the tension pulley... has come loose.
If you watch the attached video... all will come clear...
This looks to be a fairly cumbersome job... but if you snap pictures
as you go you will be able to put everything exactly back where it needs to be to work...
Watch these videos.
http://www.appliancepartspros.com/whirlpool-dryer-repair-kit-4392067-ap3109602.html#autoplay
Idler Pulley with Tri Ring and Gasket
Whirlpool 661570V Drive Belt PartSelect
Aug 17, 2016 | Whirlpool Dryers
My nephew took my dryer apart to replace the belt and cannot figure out how to re-attach the idler on the Whirlpool LER5620KQ1 model. Is there a manual available that shows exactly how to do this?
If the model number you listed this question under is correct, changing the drive belt and reinstalling the tensioner involves the following steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior. Release the belt tension, by pushing the idler pulley (tensioner) to the right (away from the belt) and remove the old belt from around the drum.
If the belt has broken, this may sometimes cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt and re-install the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and push the wheel to the RIGHT while pulling the belt over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for WHIRLPOOL and refer to diagram H.
Replacement parts (if required) can be ordered on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
For future reference, the part number for a replacement belt is 341241. All these sites offer great service with competitive pricing, so shop and compare. The first three sites I have listed also include helpful exploded view diagrams that can help you locate and properly identify the parts you may need. you can view a diagram of the belt and tensioner under the "Cabinet Parts" section.
NOTE: If you still have the Teflon glide type tensioner (does not have a wheel), Whirlpool recommends you replace it with a conventional roller type idler pulley. The Teflon type tensioners caused premature wear to the drive belt. The part number is 691366.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assistant may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run.
Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them. If you have any questions about this repair, please post back and let me know. I hope this helps you.
Oct 18, 2010 | Whirlpool LER5636P Electric Dryer
Model LE5705XPW1 replacing broken belt and have no idea of proper pulley position--any clues?
Replacing a dryer belt on the model dryer you have listed involves the following steps:
If the belt is broken, this may cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt (if required) and re-install the pulley, follow these steps:
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for WHIRLPOOL and refer to diagram H (This model Amana is manufactured by Whirlpool).
repairclinic.com
The part number for a replacement belt is 341241. All these sites offer great service with competitive pricing, so shop and compare. The first three sites I have listed also inlcude helpful exploded view diagrams that can help you locate and properly indentify the parts you may need. you can view a diagram of the belt and tensioner under the "Cabinet Parts" section. The belt is listed as item 56 and the tensioner is listed as item 53.
NOTE: If you still have the teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The teflon type tensioners caused premature wear to the drive belt. The part number is 691366.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
Aug 12, 2010 | Whirlpool Dryers
Stopped spin
This is commonly caused by a broken dryer belt. If the model number is correct, you can access the belt by performing the following steps:
3. Unplug the door switch conector plug and any ground wire that may be installed on the casing.
You should now have complete access to the dryer interior. If the belt is broken, this may cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt (if required) and re-install the pulley, follow these steps:
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
You can also view a diagram of your dryer here:
http://pcappliancerepair.com/model-display.php
NOTE: If you still have the teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The teflon type tensioners caused premature wear to the drive belt. A replacement pulley can be ordered on line at any of the following websites:
repairclinic.com
The part number for a replacement belt is 341241 and is listed as item 56 in the drawing I provided. The part number for a replacement idler pulley is 691366 and should look this one posted here:
http://pcappliancerepair.com/cgi-bin/detail.cgi?item=691366&brand=WPL
NOTE: You can view helpful exploded view diagrams at the first the 3 sites on the list.
If you have any questions about this repair, or if your model number differs from the one you have this question listed under, please post back with your correct model number and let me know. I hope this helps you.
May 13, 2010 | Roper RGX4634KQ Gas Dryer
How do you tension the dryer bet on a Kenmore 80 series dryer
you will have to loop the belt through the roller first then while you are installing the belt around the drum it will have tension. two people will need to install this since you have not done this before I assume. One to hold the drum up for you
Feb 24, 2010 | Dryers
The pulley and brcket fell off it's position laying in the bottom of the dryer don't know how it goes ?
If you are referring to the tension pulley that keeps the belt tight on the drum, just follow these steps to reinstall:
1. Make sure the drive belt is looped around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum).
NOTE: If you still have the teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The teflon type tensioners caused premature wear to the drive belts. A replacement pulley can be ordered on line at any of the following websites:
repairclinic.com
The part number is 691366 (if needed).
If you have any questions, please post back with your MODEL NUMBER (located on a nameplate around the dryer door opening) so that I may be able to confirm your dryer configuration. I hope this helps you.
Feb 13, 2010 | Whirlpool Dryers
What is the routing of a dryer belt? It's a Roper dryer model GL6050VLO
You can also refer to pcappliancerepair.com for some excellent exploded view diagrams of your dryer. Just type in your model number as "GL6050VL0" (the last digit is a zero, not the letter O), and go to the "Bulkhead" section.
NOTE: Roper is manufactured by Whirlpool, so these instructions will apply.
If you have questions, or require additional assistance please let me know. I hope you find this information helpful.
Oct 17, 2009 | Dryers
Belt drum replacement
If this is a Whirlpool manufactured dryer (which inlcudes Kenmore, Roper, Estate, Kitchenaid, and Frigidaire), just follow these steps:
a. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
b. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
c. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and locate diagram H.
NOTE: It is normal for the idler pulley to come loose when there is no belt tension.
If your dryer is not manufactured by Whirlpool, or if you simply aren't sure, please post back with your model number so I can give you more accurate information. I hope you find this helpful.
Sep 01, 2009 | Dryers
Whirlpool model WGD5300SQ dryer belt is off, roller is laying loose, is there a diagram?
If the belt slipped off, this will cause the idler pulley to come loose. This is normal with no tension on the pulley to hold it in place. To re-install, follow these steps:
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H. If you still have questions, please let me know. I hope this helps you.
Jul 18, 2009 | Dryers
The Belt Tensioner came off of my Whirlpool WED5300SQ0 Dryer
Jul 14, 2009 | Dryers
Dryers Logo
73 people viewed this question
Top Dryers Experts
