Question about Kenmore Elite HE4 Electric Dryer
Dryer heat when I turn the dryer on it will heat for a short time and then will cool down the control panel seems to work fine, the control panel will continue to count down and the heat setting will be on the selected temp(usually at med heat). I suspect a thermister switch is the problem if so where is it located and how do you recommend checking. if not do you have any suggestions.
  • AHSILA Sep 20, 2008
    DRYER RUNNING FINE, BUT NOT HEATING
  • 943 Answers
Hi. thanks for the question. Was the venting checked .If not clean out the venting to the outside. This could be the cause
Posted on Sep 29, 2008
Dryer drum moves about quarter turn/cycle then stops. please let me know the potential problem.
Your motor is probably going bad and it will run short time until overheated then after setting a little bit and cooling down it will run again for short time.
Aug 04, 2015 | Dryers
Auto cycle does not work timed cycle works fine
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Apr 15, 2015 | Kenmore Dryers
Dryer works fine on timed cycle does not work on auto
Gas dryer does not dry in "timed Dry" setting
Mar 06, 2015 | Whirlpool LGB6300 Gas Dryer
Whirlpool dryer, when set for auto dry low heat, or timed heat, then dryer runs fine, when set on auto dry high heat timer doesn't move, what could be the problem? does it have to be the timer?
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Feb 10, 2015 | Whirlpool Dryers
I have a frigidaire gallery series dryer that will run on low heat setting just fine but when I set it on medium or higher it shuts off after a minute or so. ..I replaced the thermistor but it didn't help....
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Nov 04, 2014 | Dryers
My dryer works fine...heats tumbles the timer just doesnt advance once it starts therefore the dryer wont turn off on its own
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 11, 2014 | Whirlpool LEB6200 Electric Dryer
Samsung dryer won't turn off
Do you habe wrinkle guard turned on. If so try turning off the option. If not the timeing sirsuit on the control board is faulty.
Jan 29, 2014 | Samsung DV5471AEP/XAA 7.4 cu. ft. Capacity...
Whirlpool dryer model LGQ80000JQ4 starts to heat and runs then stops heating, but rest of dryer seems to run fine
Hello, This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Sep 18, 2009 | Whirlpool LGQ8000JQ Gas Dryer
Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Feb 28, 2008 | Kenmore 64952 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
44 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
