Question about Creda W100FW Front Load Washer
Creda front load washer. Small stackable made for Europe usage.
The front door began to not want to open and after you jiggled it a bit it opened but this time it did not open and a bit of water leaked out around the door. I tried juggling at times for 2 days and the last time the handle came off but the door is still shut. Is there a way to get it open and the handle put back on? Please give me some help as the last tentant took the manual with her so I have nothing to look at. Thank you. Joy Url
joyurl@yahoo.com
4 Suggested Answers
  • 139 Answers
SOURCE: creda eco washing machine won't spin
it is the carbon brushes in the motor. there cheap and easy to replace. go on give it a go
Posted on Dec 11, 2007
barkencoa
  • 3463 Answers
SOURCE: Manual for Creda Excel 1200 W120VW
In your browser bar type in:
HOTPOINT USER MANUAL and follow the links.
You will find what you are looking for.Although it says Hotpoint, just type your model in the box, and it will come on screen, then you can save it, or download it to your printer
Plz rate my solution.
Thanks
Posted on Dec 16, 2008
  • 5 Answers
SOURCE: door won't open at end of cycle Creda 1000 ecowash front loader
Hi Jenny. Do you have the model No. available?
Most common cause of this problem is
1. A faulty or broken door catch.
2. A faulty interlock. This is the part that the door closes in to.
Some older models have other devices that will prevent machine opening if it has not pumped out fully, or mechanical devices that check for drum rotation that can be knocked during the spin. Could really do with age and model No. of machine.
Posted on Apr 04, 2009
What is the issue with LG washer
LG WM2277HSW XL Front Load... Repair Questions - Fixya
www.fixya.com/.../p95436-lg_wm2277hsw_xl_front_load_stackable
Recent LG WM2277HSW XL Front Load Stackable Washing Machine questions, problems & answers. ... My frontloader washmachine will not turn on ยท LG ...
LG WM2277HSW XL Front Load Stackable Washing ... - Fixya
www.fixya.com/search/p95436-lg_wm2277hsw_xl_front_load.../open
LG WM2277HSW XL Front Load Stackable Washing Machine, open related issues. Get free ... Wait 5 secs after turning off door release should open. If this does not ... OE error message won't open door, won't spin out water What is filters & open it are my problemsDue to that I cann't ... Where is it sticking and how do I fix it?
LG Tromm WD 12270 RD washer and dryer 'LG ...
Dec 19, 2015 | LG WM2277HSW XL Front Load Stackable...
Get door open on whirlpool stackable washer
Hello, and thank you for your question. I have links for troubleshooting, a link to manuals, ordering parts as needed, and scheduling service if needed. I hope this is helpful.
http://bit.ly/zkfnZd
http://bit.ly/112Lu7q
http://bit.ly/yLv4Z5
Aug 19, 2013 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
The door on my Jackson-Creda washing machine will not open after completing the cycle? I left it for several minutes before trying but without success. The only indication of a model No. is J1000 on the...
You must make sure there is no water left in drum,
try lowering the drain hose down to floor level to drain any water that is left, with luck, the door should then open.
Nov 04, 2010 | Creda W100FW Front Load Washer
There is wash in the washer and the dcor is locked but the cycle isn't going
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 04, 2009 | Kenmore HE2 Plus Front Load Washer
Door won't open at end of cycle Creda 1000 ecowash front loader
Apr 04, 2009 | Creda W100FW Front Load Washer
Blocked outlet
Power off the wall. Get user's manual, look for blocked filter. Open up the filter, usually front bottom right side, clean, refit. Be prepared for much water to come out. The filter requires periodic cleaning according to usage.
Jul 31, 2007 | Creda W100FW Front Load Washer
Washing machine creda front loader
I had the same Problem on a 17112e Creda, I took the top off and using a torch located the red plastic door release mechanism, I then pressed a white button in the centre of it and the door released. I believe that the washing machine was overloaded and auto cut out. I reloaded the machine with fewer items and it is now working.
Mar 20, 2006 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer Logo
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
