Question about Canon FAX-L800 Plain Paper Laser
Canon Fax-L700 I have an error message that reads "Check Paper Cover" What do I do. I have removed the paper tray and reaarranged the paper and I have opened all access doors as well as turned the machine off and on. Still the same message. Can anyone help?
  • 4 more comments
  • tay26132 Sep 20, 2008
    There are no cables and no thumbscrews that I can find on this machine. There is no external processor. Everything is self contained. I only have one paper tray which is letter size. The override tray is closed but also set at letter size. Problem still exists.
    Can someone please tell me what a "Paper Cover" is? Should I be looking at the scanning mechanism or the paper tray mechanism. I personally would not refer to either one as a "Paper Cover".
    That did not help either
    I have manually depressed the Paper tray seonsors (both of them) and also the paper tray bypass chute paper sensor. The problem still exists.
    I have check for paper jams, cleaned all the rollers with air and Rubbing alcohol and I have blown the machine out. I still have the same error.
    I have located the switch to replace. Thank you
    President:
  • 1,952 Answers
When the toner supply runs low, the fax saves the remainder of
the document into the memory. You can set the fax to continue
printing even after the toner runs low during printing. (
PRINT IN ORDER Set the order of printing.
OFF Arrange received document pages in reverse order.
ON Arrange received document pages in the order they were sent.
Printing does not start until all pages are received.
5.SELECT DENSITY Adjust the print density of documents you receive. LT (Light), STD
(Standard), DK (Dark)
6.TONER SUPPLY LOW Set the fax to continue printing even after toner runs low and the
CHANGE CARTRIDGE indicator lights and the REPLACE
CARTRIDGE message appears.
RX TO MEMORY Stop printing and receive the remainder of the document in the
memory.
KEEP PRINTING Ignore the warning and keep printing until the document is
completely printed.
Posted on Sep 20, 2008
  • mohammed marika thambi
    mohammed marika thambi Sep 20, 2008
    CHECK DOCUMENT A document page may be jammed or may not be fed correctly in the automatic
    document feeder (ADF). Remove the document and try again. (Q15-2) If the
    document does not feed correctly, clean the rollers. (Q15-22)
    CHECK POLLING ID Your attempt at polling receiving failed. The polling ID may be incorrect or your
    subaddress/password does not match the subaddress/password set on the polling box
    of the other party’s fax unit. Contact the other party and make sure you are using
    the correct polling ID or subaddress/password. (Q11-3)
    CHECK PRINTER Printer malfunction. Press STOP. Unplug the fax unit from its power source, wait a
    few minutes, then plug in power cord again. If the fax is connected to an
    uninterruptable power supply (UPS), unplug the power cord, and then plug it into
    an AC outlet. If message remains in the LCD display and the fax unit can not return
    to standby, call for service.
    CHECK PRINTER COVER Check the printer cover, right cover, and exit cover and make sure that they are
    completely closed. Make sure a toner cartridge is installed under the printer cover.
    CHECK SUBADDR/PASSWD You attempted sending or polling receiving with an incorrect subaddress/password.
    Contact the other party and confirm that you are using the correct subaddress/
    password.
    COMMUNICATING PLEASE
    WAIT
    You tried to use direct sending while the fax was sending another document. Wait
    until the transmission is finished, then try again.
    DOCUMENT TOO LONG The document is longer than 1 meter. Cut the document into smaller sheets. Reduce
    them on a copy machine if necessary. Then paste them on standard letter or A4-size
    sheets for scanning.
    HANG UP PHONE The transaction has completed but the handset is not sitting completely on its
    cradle. Make sure the handset is sitting completely on its cradle.
    MEMORY FULL The memory is full. If the document has been received in the memory, print the
    document. (Q8-2)
    If documents have been received in confidential mailboxes, print them. (Q10-7)
    If documents have been received in memory boxes, print them. (Q8-23)
    Check the content of the memory and if there are documents in the memory that
    you do not need, delete them from the memory. (Q8-8)
    If you tried to send a document with “SUPER FINE” or “TEXT/PHOTO”, try
    sending by direct sending, or set to “FINE” or “TEXT” and send by memory
    sending.
    MEMORY FULL
    PLEASE WAIT
    The memory is full. Wait until the current document transmission has completed
    Guru:
  • 558 Answers
Have you check the Device manager?
Please can you do reinstall the printer with the installation CD.
If your printer is a USB printer then do the following:
First of all please remove the USB Cable from your PC completely.
Restart your PC without connecting USB cable back to your PC.
When PC boot up properly then fist install Software or drivers for your USB device (Wireless Mouse or any other USB device).
After doing the installation or updation if it asks for Restart then go ahead and REBOOT your PC else close all the running programs and ShutDown your PC manually.
Now connect the USB Cable into the USB Jack from both ends and start your PC.
Your PC will automatically accept this USB Hardware driver.
After doing above steps please reboot your PC finally and let us know the result.
Thank you very much for being so co-operative and patient, which I appreciate most. And dont forget to Ranking me.
Regards
ELLIN
    Genius:
  • 2,035 Answers
This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located ...........................
Good luck....
    Sergeant:
  • 264 Answers
It could be an issue of Paper Jam as well. Remove all the papers and thoroughly clean the paper pickup rollers and the feed rollers.
Another cause may be that the paper cassette tray is worn and may need attention to areas where the paper catches and sometimes the tray needs to be replaced.
All The Best
Sammy
    Master:
    Sergeant:
  • 449 Answers
Hi!!
check the paper sensor cover
that the only thing that say"Check Paper Cover"
or something might have been stuck in the sensor of the
paper cover
go check it!!!
  • 1,800 Answers
Try to chek the door sensor.
that gives the signal to ur unit that the door is locked maybe its faulty or the sensor is wrecked or unscrewed.
best regars
plz do rate this post
    Brigadier General:
  • 6,966 Answers
The error message "Check Paper Cover" of course would refer to the cover being left open or incorrectly closed or the machine is erroneously sensing that it is open. This is often a hardware problem, specifically the switch that is triggered by the paper cover.
Initially, pls visually check the paper cover and determine how it triggers the switches. A generic method would be a tab that fits into a small hole/slot where the switch is hidden/located. In some other instances, it could be a small button. You may want to exercise the switch or button by repetitively pushing/trigerring it in the hope that it is just a glitch. If it were a mechanical misalignment, then the unit has to be opened up.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Sep 20, 2008
    Might below images help?
  • Louie  Role
    pls try opening and closing repeatedly or closing with a snap.
    Genius:
  • 1,550 Answers
There is a cable that runs from the scanner to the processor. Looking from the front, its on the left side of the machine, on the back, it is a fairly large connector.
Unscrew the two thumb screws, then unplug it and plug it back in with the machine ON.
It will force it into a reset and may boot.
The problem is caused by a software glitch .
Check the tray settings and ensure that paper size guides are set to the appropriate paper size, then power off/power on the machine.
SAM ANDERSON
How to reset error 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, <OPEN COVER> and <SEE FIG. 1> <!!CHECK!! 5100> are displayed on the LCD.
Note
You do not need to unplug the fax when clearing document jams.
* When <OPEN COVER> and <SEE FIG. 1> are displayed alternatively
1. Press [Stop].
Important
Do not pull out the jammed paper manually at this point.
2. Hold down [Start/Copy] for a few seconds.
* The document will be fed out automatically.
* If the document is not fed out, gently pull the document out of the fax.
* When <!!CHECK!! 5100> is displayed
1. Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2. After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, <CLEAR PAPER JAM> is displayed on the LCD.
1. Gently pull any jammed paper out of the fax as shown, then press [Stop].
* Pull it gently in either direction.
* If you cannot pull the paper out, continue with the steps below.
2. Open the Printer Cover.
3. Gently remove the jammed paper inside the fax.
4. Press [Stop].
The fax returns to standby mode.
Sep 24, 2013 | Canon FAX-JX200
Jammed paper
There are 3 places to check for jammed paper.
Turn off the fax machine, then remove the tray and open the back cover, and open the front cover to remove the drum and toner (cartridge) and look inside machine.
After you find the jammed paper put the cartridge and tray back in machine and close all the covers.
Error message should go away.
Apr 06, 2010 | Brother IntelliFax-2820 Laser Fax
Error message saying "supply rec. paper"
There is a small side tray on the right side of the machine,check if there are paper loaded in.
Jun 30, 2009 | Canon LaserClass 9000L Plain Paper Fax
Canon super g-3 copier
need to know what kind of fax this is
Sep 22, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Error message
when you look at the front of the fax. above the paper cassette there is a gray,blue cover where the paper comes out when receiving or coping , that cover needs to be seated properly there is a mag switch that will shout down machine till it is in place.
Never have I seen this sensore go oit just the cover is out of position,
hope all will be OK
Jul 23, 2008 | Sharp FO 5700 Plain Paper Laser Fax
Canon 710i
Can you look into the paper tray and actually see if the feed rolls are turning? You may have either a bad paper feed clutch, or the solonoid that releases the feed rollers is bad.
Also the paper tray should move up and down when the paper feeds to move the paper against the rollers. Up to feed down to eliminate paper drag. One of those fingers that raise the tray may be binding against the bottom of the tray not allowing proper movement.
If you can get a flash light and observe what is going on. Then let me know.
Mar 21, 2008 | Canon FAX-L1000 Plain Paper Laser
Check cover/cart
Two possible solutions remove the top cover (Two screws on top after oepening the cartridge door and two push in black nylon screws in either side). and check the activation lever that activates the cover switch is not riding on top of the switch. Second if this happened your toner cartridge make sure this new cartridge is the correct one for the fax and not a HP modified recycled printer cartridge.
May 31, 2007 | Canon FAX-L350 Plain Paper Laser
Canon laser class 2060p super g3 fax machine
The error keeps flashing and the machine will not work. The error reads, "check cover/cart". We put the cartridge in and out about 10 times and the same error message keeps flashing. the fax machine is still not working. Help!
Apr 24, 2007 | Canon LaserClass 2060P Plain Paper Fax
Canon FAX-L800 Plain Paper Laser Logo
331 people viewed this question
old marine
old marine
Corne Viljoen
