Question about Whirlwind FH-778 Air Conditioner
Air conditioning top off?
I have a 30 # cylinder of R22, I have the gages, how do I get the R22 from the 30# cylinder to the condenser and no I don't intend to put 30#s of refrigerant in the air conditioner, PLEASE, forget the EPA laws, the possible leaks, the fines and all the possible ********. Please just answer the question above. Thank you
  • Ken Bledsoe May 11, 2010
    What makes you think you need R-22 added?
  • Dennis Boxerman May 11, 2010
    Let me suggest something here. You probably will not get any help due to the EPA laws. No one will put their name on the line for this. They could loose everything. Your problem is doable, but you may want to repost and word it differently to get someone to help ya out.
    Good Luck and much success.
  • 163 Answers
Connect to the bottle and then connect to the low side (blue usually) to the low side service valve. You want the bottle to be warm. If its not warm it will be harder to charge. Don't heat the bottle just put it in the sun or put hot towels around it.
Posted on May 08, 2009
  • May 08, 2009
    Don't forget to bleed the air out of the lines.
Charging an air conditioning system
R22 systems should run a 68# to 70# suction pressue. If you look at the suction guage at 68# that is a 40 deg evaporator coil temp.
Nov 18, 2012 | Ruud Central System Air Conditioner
On a Carrier 2006 Model 38CK036350 is it an R22 or R410A condenser refrigerant?
Hello, There are a few ways to tell, you csn usually find out by the compressors model # or they have a tool that is called a refrigerant " identifier" on the market.
Jul 19, 2012 | Carrier 38CKC060 Air Conditioner
Can you use a 410 AHU with a r22 condensing unit
Yes you can if the 410 a/h is new just put a r22 txv on it I have personally done hundreds of them mainly carrier they even sell the conversion txv.
I'm a 15 year hvac sub contractor and I know my sh##
Apr 09, 2012 | Carrier 38CKC036 Air Conditioner
My mother had a ruud furnace/air conditioning system installed 8/2003 - the installer now says the condenser is gone. She died in 2/2010 so the system was used only 9 years. Do condensers go that quickly...
Hello
Usually there is a 1 year warranty from the installer and a 5 year from the manufacturer.
It may not be the Whole condenser is bad.But the compressor in the condenser is bad.Ask your repairman about that.R22 units are getting hard to get now as they will soon be gone.
9 yrs is a little short but it depends on how often it was used and maintained.
You certinly can try Rudd and see if they will do something.
I doubt they will. I know lennox does not.
Jul 21, 2011 | Ruud UAMB030 Air Conditioner
How to add freon to central air conditioner
dear sir
if you have some knowledge about air conditioner system then first connect hose with suction side of aircon pipe conector(valve) with Gage and second hose with cylinder and GAGE .during of this you must remember don,t forget to open valve before START this job then make your ac unit vacuum it should be 18-20 micron after vacuum fill freon (approxmatily 60-65 pci)
and check your aircon system,s evaporator all pipe has been cold not and any pipe is getting ice on it .if its reach pressure 60-65 psi AND YOUR AIRCON BLOWING COLD AIR then it,s good the close by cup nut on the connecting point and remove hose from connector and disconnect Gage from system .
(but please don,t do if you have not proper knowledge it can be dangour)
warning: if you don,t have knowledge to do this please don,t try
thank you
hope answer the question
Aug 22, 2010 | Whirlwind FH-778 Air Conditioner
I had a Heating and Air Conditioning Service my A/C unit in my home. I was wondering what is the going rate fro the Freon per pound?
A 30lb bottle or R22 Refrigerant your cost would be $650. As a Licensed Refrigeration Mechanic, I would charge 4 hour minimum for leak check and repair. The hourly charge is $75 and the Refrigerant which is extra to the price is $35 - 40 per pound. As the price of R22 Refrigerant goes up in price as it is being phased out per Government Regulations, you will see $75 - $100 per pound +. As for my pricing, my fellow workers say I charge too cheap. If you take $650 and divide it by 30, it would be $22/pound, but it can only be delivered to you and charged into your unit by a Licensed Refrigeration Mechanic...then the labor comes into effect for all of this. So in an nutshell, if you were charged $30 - $75 / pound , I think you did well.
I hope this clears it up.
Jul 14, 2010 | Whirlwind FH-778 Air Conditioner
Who to added R22 freon to my a/c condenser unit and what hose on my gages need to be connected to hight pressure and lowe pressure
the red hose connects to smaller line...usually 3/8's....the blue connects to larger that has black insulation. The yellow to tank of freon. The unit must be running to put in blue hose. If unit nit running put in red hose. Must be done by someone with EPA 68 license
May 10, 2010 | Whirlwind FH-778 Air Conditioner
Need special fittings to hook up gages. Repair mans standard gages won't fit on compressor unit. Where can I get fittings to adapt to your machine?
It may be a 410a unit. regular R22, R134 gauges will not work. You will need 410a gauges as it has much higher pressure in the system.
Apr 12, 2010 | Amcor Aire UCHW-H09AF2 Split System Air...
why would you need to add refrigerant ?
If you need to ask which hose goes where,you are not qualified.
Apr 06, 2010 | Whirlwind FH-778 Air Conditioner
Heating & Cooling Logo
112 people viewed this question
Top Whirlwind Heating & Cooling Experts
AJMAL KHAN
Dennis Boxerman
Bill Long
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
