Question about Dell Latitude C610 Notebook
Dell latitude c610 touch pad left button problem
No left buuton works, only right ones. Tapping touch pad does not work, but moving curos viia touchpad does
  • 1 more comment
  • Golamur Rahman May 18, 2013
    I had same problem in DELL Latitude 6400. The cursor moves from the touch pad, but click does not works, even by attaching external mouse also click does not work. So what I did is, from run typing msconfig and from the startup tab, I deselect the tick mark for dell touchpad programs. Then it is working. Best Regards, Golamur Rahman
  • Anonymous Mar 13, 2014
    Cursor does not move from touch pad f9 key is on
  • Anonymous Mar 19, 2014
    My granddaughter turned off touch pad. How do I turn it back on. Must be a simple button
  • Dell Master
  • 998 Answers
Will your laptop work properly with an external mouse? If so, check your touchpad settings in "Control Panel" by selecting "Mouse". Here you can reassign your Buttons. Try setting your Right Button function to "Double Click". If the "Double Click" function works on your Right Button then chances are you have a problem with your Touchpad Assembly which means it will have to be replaced. Dell refers to it as a "Palmrest" which they will replace if still under warranty.
Posted on Oct 17, 2008
Can't right or left click on inspirion 1501, touchpad is fine.
It would appear that the left/right touch pad buttons have failed. You will have 3 options at this point in time.
1) Use an external wireless mouse such as a Logitech Wireless Mouse M505 for roughly $39.99
2) Use alternative features on the laptop. Left click is typically simulated by tapping or double tapping the touch pad itself and right click can be simulated, in most cases, by single tapping the icon and pressing the pop-up menu button, typically located between the right alt and ctrl buttons.
3) Search for a replacement component online and replace the component. Touch pad replacement will require you to remove all casing screws from the laptop and then remove the case. You will then expose the screws and cabling for the touch pad. I can not give more detailed instructions as this varies per laptop model.
Sep 21, 2011 | Dell Inspiron 1501 Notebook
I have a Dell Studio laptop and the left click has stopped working. I can still select by tapping the touch pad, and the right click still works - but nothing happens when I push the left. Thanks!
The touch pad might need to be replaced which can be a hassle and quite expensive. If you go into the touch pad settings you can switch the left and right and also make some other adjustments. Check that one of those isn't the cause of the problem.
Mar 31, 2011 | Dell F3534 Touchpad
How to use touch pad dell latitude D610
The touch pad on a Dell Latitude D610 works much the same as with other laptops. You can move your finger around the pad to simulate the movement of a mouse, and it will cause the pointer to move across the screen. You can also tap on the touch pad (gently) to "click" on a file, folder, or other item. The touch pad on a D610 doesn't have a hardware switch like some other laptops do so that you can turn it on or off -- it's just always on.
Aug 08, 2010 | Dell Latitude D610 Notebook
I have Dell laptop and the buttons on the touchpad sopped working
I would just install a usb mouse through one of you usb ports
Option 2 is to spend a lot of money to have both switches cleand/repaired
Nov 21, 2009 | Dell F3534 Touchpad
Both my keyboard mouse buttons act as right clicks
Hi
Access BIOS settings and search for mouse / peripheral settings, you may find one to activate left and right mobo clicks.
Cheers cbacer
Aug 12, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Cursor Shift
This could be either a driver glitch or the touch pad is going out, both are common on these models. Start by uninstalling the drivers for the touch pad (some times referred to as the synaptic pointing device), then restart the machine. The machine will find the touch pad and reinstall the drivers automatically. If it's a simple glitch, this will fix it. If it persists, then the pad is failing and will need replaced. The only other thing you might try is to adjust the cursor speed or touch pad sensitivity from the control panel. This will sometimes help to dampen the effect, but usually won't get rid of it entirely.
Sep 04, 2008 | Dell Latitude C610 Notebook
Touch pad not working
That's a sign that the synaptic touch pad needs to be replaced. Eventually they wear out.
Jun 13, 2008 | Toshiba Satellite A105 Notebook
Mouse cursor moving by itself
i have latitude c610 and same problem happens with me too. i think that happens when i finish my brakfat and without cleaning my hands start using the touch pad. what happens according to me is that small particles of food(eg bread/dust particles) stuck in the corners or the body wall where the touch pad ends and keeps pressing the touchpad, thus causing the mouse to move to one direction. when i clean the corners and sides of the touchpad, it starts working ok !!
thanks
Johal
Dec 12, 2007 | Dell Latitude C610 Notebook
Dell Latitude C610 Notebook Logo
2,452 people viewed this question
Alun Cox
