Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Lawn mower motor
Gasoline in crankcase is this motor rouine?
No it's sounds like the float in carb is stuck I've had 3 motors do this I put a fuel shut off in the line after I cleaned the carb out and rebuilt it. The problem is the gas breaking down an gumming up the float in carb. Drain the oil and an run some oil thur it to get the old gas out make sure you clean the carb out to.
Posted on Sep 24, 2008
98902-2065-B1 briggs & stratton oil:petrol ratio pls
This is a 4 stroke engine which requires an sae 30 weight oil in the crankcase and straight gasoline (petrol) in the fuel tank
Jan 19, 2013 | Briggs & Stratton Garden
Oil in carburetor
Make sure your air filter is clean, if it gets dirty and or plugged then it causes it to **** oil out of the crankcase through the pcv valve
Oct 06, 2012 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
I have Gas in my oil sump and sprays mixture out exhust when trying to start mower
what has happened is the rubber seal on the needle and seat has dried out and fuel is leaking passed then the carb overfills and then the gas flows into the cylinder and crankcase
Sep 03, 2012 | Craftsman Garden
My Lawn mower seems to be produced by ALKO, but has the Briggs and Stratton emblem also. It is the 40b model and having just inherited it, I am trying to find out if I put just petrol in or whether I need...
Hi scottcoles5...
The easy way to find out if the motor is 2 or 4 cycle is to check to see if the engine has oil in the crankcase...if it does it is a 4 cycle and you will NOT have to mix oil with your gas. 2 cycle engines do NOT have an oil in the crancase and depend on the oil you mix with your gasoline.
You can also check the color of the gasoline in the tank, most 2 cycle oils contain a colorant to color the gas to let you know there is oil in the gas...
Free Answer...Please take time to rate me
May 31, 2011 | Briggs & Stratton Briggs Stratton...
Does toro lawnmower need oil/gas mixture or does it take plain gasoline?
It depends, Toro made 2 cycle and 4 cycle Mowers......Look and see if there is a oil dipstick,If so it is a 4cycle , If no dipstick or plug at crankcase to check oil then it's a 2 cycle
May 02, 2011 | Toro Lawn Mower With Toro Power Tools
I have put two stroke oil in my four stroke lawn mower. What should I do
If you put the 2-stroke oil in the crank case you will need to drain the crankcase oil and refill with the appropriate oil. If you added the 2-stroke oil to the gasoline, you can siphon a gallon or so out of the tank and replace with fuel only to dilute the oil. It might smoke a bit will be OK.
Good luck.
Feb 13, 2011 | Garden
BOLENS, 4,5 HP Model # 90012 PN# 11a-084c163 SN: 10293-31672 We are looking for a manual to know what type/kind of oil and when to do the oil change. We would like to know if we should use only gasoline in...
use 30hd oil in the crankcase about 20 oz., change it about once a year. but check it every time you refuel.
it is a 4 cycle engine so it uses regular gasoline in the fuel tank.
good day.
Nov 18, 2009 | Garden
Gasoline in the crankcase
If, inside of the carburator the needle and seat does not close (dirt in carb) the fuel will slowly keep pushing through the carb,through the intake into the cylinder then into the crank case.
Do not run this engine until the carb. is rebuilt. The float in the carb.also needs checked to be sure it still floats and its at the exact factory setting.
Also have a new inline fuel filter installed.
Check for dirt in fuel tank.
Keep the air filter clean and in good condition.
I hope this helps you.
Sep 19, 2009 | Mtd 22" Yard Machine Push Mower
What is the oil to gasoline ratio for a 3.8hp mtd push mower?
Most mowers are four stroke machines and don't need oil put into the gasoline, it has a crankcase to support the lubrication. If you mower sounds like a chainsaw when it's running it's two stroke, if it sounds like most othe mowers it's a four stroke.
If by chance it is a two stroke (which I doubt) use 3oz of "two stroke engine oil" for each gallon of gas.
May 16, 2009 | Mtd 22" Yard Machine Push Mower
Gasoline fills the crankcase
Yes it is. The float needle and seat are leaking and need to be replaced. I'm assuming it it a Briggs and Stratton engine. Just replacing the rubber tipped needle usually will not stop the leakage, the pressed-in brass seat also needs to be replaced and pressure tested. This would really need to be done by a shop. Not a hard job, just requires specialized tools to remove and install seat and pressure test..........
May 16, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
156 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
