Question about PC Chips (M925G) Motherboard
ECS M925 MoBo onboard graphics
I'm facing troubles with the onboard graphics, (I think)it starts a while later after putting on the computer. On the monitor it stars flashing like receiving electric jumps and right way monitor goes black showing "No signal". The question is: Is it a problem with only the onboard graphics chip or the problem goes to the very motherboard. Can I put a AGP graphic card and solve the situation?
Any help will be appreciated.
  • fc_net Sep 20, 2008
    Thanks a lot for your help...I'll try it asap. Tell u later.
  • fc_net Sep 22, 2008
    Pattods, my friend
    You were right, it is an overheating problem. I opened the comp case and due to the room temperature (AC unit) the electric jumps on the monitor decreased but still showing up the black screen. I'll try to put a PCI graph card to see if the problem goes off. Thanks a lot anyway.
    Novelist:
  • 116 Answers
Well it all depends on if the onboard is fried. Usually, that's a sign of overheating. I'd toss in a case fan. Maybe try running the system with the side of the case off of it. If it still does this try putting a fan beside it to give it a massive rush of airflow. If it stables out, then it's a heat issue.
You can put an AGP card into that motherboard, which is always beneficial to the performance since the processor and RAM isn't being used by the video. However, you'll need to disable the onboard video system in the BIOS before you can really use an AGP card to it's ability.
I hope this helps bud.
Posted on Sep 20, 2008
I have a Dell Dimension 2400 desktop. It needs a monitor. I tried new ones from Best Buy and Office Max but they say no signal when I hook them up..I tried this computer with monitor in the following
Thank you for replying,
As per the diagnostic LED's, it is an issue with Video initialization failure. Your computer has onboard Graphics which is built into the Motherboard.
Video Initialization failure could happen if there is :
Unseated AGP card
Bad AGP card
Bad motherboard
As per your Svc Tag your system doesn't have AGP Graphics Card, Probable issue with MOBO.
This computer doesn't have a AGP Slot (Graphics Card Slot) to try connecting Graphics Card.
Need to repair/replace MOBO.
Thanks.
Feb 25, 2014 | Dell Dimension Computers & Internet
7200 rom corrupt
There is no virus for a mobo BIOS in the past 10 years. There is no software that can check a GPU BIOS for a virus.
If you really think you need it the only place you get it is by contacting the MFG of the card and ask them.
Apr 07, 2013 | Nvidia GeForce 7200 Graphic Card
I was given a tower, it wont boot up it says monitor in power saving mode, the agp brown slot is empty, do i need a graphics card or is it onboard in a K7SEM motherboard
Hi, you can download drivers and a manual here:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=342&CategoryID=1&MenuID=24&LanID=0
It has onboard vga and that the only graphic is has.
You can put a graphic card in the agp slot for better resolution.
I think the harddrive is dead since it will not boot.
Sep 04, 2011 | EliteGroup K7SEM Motherboard
Hello, I just bought my ECS Geforce GT430 (Model: NGT430C-1GQR-F). I put it on the PCI-E slot, conected the crt cable and turned de PC on, he GPU chassis fan started normaly, but there's no image on...
First off all please make sure that your crt is connected to your graphics card directly not your onboard crt port.
after this please go to your bios and choose your pcie card as your default video card.
Once done please save all sitting and restart your pc.
Hope this solve your problem.
Regards: Kartikey
Apr 14, 2011 | EliteGroup ECS NGT430C-1GQR-F GeForce GT...
I'm looking for Bios update and drivers for a board that is hard to find. Its a ECS M925 1.0 board. chipset: via p4m266 (vt8751). southbirdge: via VT8235. Bios: American Megatrends Inc. v.0700T date...
Hi Jenkins21448,
I believe your mean PCChips M925. ECS didn't make a M925 board.
So you can find the PCChips bios and drivers HERE. If you download the manual there is a drawing of the motherboard for you to compare, to make sure you have the right drivers. But, you may be right that that board you have is extremely rare. I've never seen or heard of ECS making a M925. Check out the picture to be sure.
Thanks
Mark
Mar 04, 2010 | Computers & Internet
Green lines in black/grey screen (only vista, xp runs normal)
It's the onboard video try removing the CMOS battery and placing it back in after serveral hours, if that doen;t work it's the onboard Video replace it with a PCI Express Video Card.
Jul 27, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
Can't use two of 512 ddram in ecs m925
Check the following:
The fsb are the same, if this differs it could couse instability.
( do not use 266 ram with 333 ram and 333 with 400 , or any other mixture of thease).
try this: pull out the rams and put back the first to the second's socket and the second to the first's socket.
Good luck.
Dec 15, 2008 | PC Chips (M925G) Motherboard
Video card problem
this is probably a setting in the BIOS-setup you need to change. look within system/miscellaneous configurations for an option that defines which graphics adapter should be used as default. in normal circumstances there should be an auto-detect option...
Sep 03, 2008 | EliteGroup ECS P4M900T-M2 Socket 775...
Mother board not seeing my pcix card
Hi crazieedd, the answer to you're problem is this. Go to ECS's web site. Click on this link for you're GeForce6100SM board.
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=685&DetailName=Bios&MenuID=7&LanID=9
Another user I tried to help did have the same problem as you. Though ECS does not mention there is a fix for this issue. ECS did email the user to update the bios file. (I looked at the last 2 bios updates & there is no mention of how to run the PCI-E & disabling the onboard video fix mentioned. According to ECS you are to upgrade the bios file to its most recent. That said, once the bios file has been flashed. (Preferred option is to use a floppy disk). You are to go into the bios to Advanced Chipset Features
Than to, Onboard GPU set this to read, [Enable If no Ext GPU]
Save & exit the bios.
Having this set to, Enable If No Ext GPU & using a PCI-E card plugged in to the system automatically disables the onboard video card. (Don't you just love it when the Mfg does not list this type of major fix)?
Please keep in mind the other user was not running Vista. No one has mentioned to you how bad Vista (any version) is! You may not have any troubles with Vista. Let's hope it stays that way.
Good Luck crazieedd!
Have more questions? Please feel free to ask.
Mike
May 31, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
PC Chips (M925G) Motherboard Logo
251 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
