Question about D-Link AirPlus DI-614+ Wireless Router
Setup Have just tried to install the DI-614+ At step where you enter admin the system stops and goes no further
Are you using a wireless connection to do this, you should really need be hard wired to do this (i:e ethernet connection.). If you apply changes it will cut off to change to a new configuration, thus losing internet and connection to the router.
brusky
Posted on Oct 09, 2008
    Problem Solver:
  • 40 Answers
In the back there should be a small button you need a pen to click. Try to hit that. It will reset all settings of the router. It will be like you jsut took it out of the box. Any settings you made will be lost.
Posted on Sep 20, 2008
Setup di-614 ip192.168.0.1 without manual. i bought from garage sale
You can download the manual from here: http://www.dlink.com/-/media/Consumer_Products/DI/DI%20614plus/Manual/DI614ManualUS.pdf
Feb 20, 2015 | Computers & Internet
Password protect wireless access
You'll need to access the administrator web page for your router, and then set a security key (password) for wireless users.
For step-by-step instructions for setting up security on the D-Link DI-614 router, see:
http://technicallyeasy.net/2010/10/how-to-secure-d-link-di-614-wireless-router/
Sep 04, 2012 | D-Link 2.4GHz Wireless Router DI-614
How do I access the router control panel?
The factory default User name is admin and the default Password is blank (empty). It is recommended that you change the admin password for security purposes. Please refer to Tools>Admin to change the admin password.
You need to download the user manual. ftp://ftp.dlink.com/Gateway/di614+/Manual/DI-614+_manual_06292005.zip
May 01, 2011 | D-Link AirPlus DI-614+ Wireless Router
Hello, I can not access the router configuration. The IP address in not the correct one.
If the password has been installed, and you cannot remember it, look for a recessed button usually located by the power input plug and press and hold it for about 10 seconds. Then pull the power out and plug back in (to restart) This action will wipe all settings back to factory. Which means you will have to setup wireless password and any ISP (Internet Service Providor) settings needed to access your service.
Feb 08, 2011 | D-Link AirPlus DI-614+ Wireless Router
When i run wisard it ask about old passworld
This FAQ is for the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624M, DI-624S, DI-774, and DI-784.
Step 1 Open a web browser and enter the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter.
Step 2 The username is admin and the default password is blank (nothing). Click OK.
Step 3 Click the Tools tab and then click Admin to the left.
Step 4 To change the administrative password, enter a new password in the Admin section.
To change the user password, enter a new password in the User section.
Step 5 Click Apply then click Continue to save the settings.
Note: If you forget your password, you can reset the unit to factory defaults.
Click here for instructions.
Nov 02, 2010 | D-Link AirPlus DI-524 Wireless Router
I can not connect to 192.168.0.1
To configure the DLink wireless router with the IP configuration address, connect a LAN cable from the computer to the DLink, then open IE browser and type http://192.168.0.1 login = admin and PW = blank (just press Enter - if you had not changed the default PW)
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 12, 2009 | D-Link DI 514 Wireless Router (DI-514)
Can not open wizard
You can reset your router.
To reset your router, use the following steps (from http://technicallyeasy.net/2008/02/how-to-reset-d-link-di-524-wireless/):
  1. Press the reset button [the tiny button on the back of your router, marked Reset] for 10 seconds. You can use a small object, such as a paper clip to hold down the button.
  2. Do not power off the unit while the router is being reset.
    The unit should now reboot, and once the WLAN light stops blinking the router should be reset.
  3. Open up your Web browser and enter 192.168.0.1 in the address bar.
  4. For the login, enter admin as the ID and leave the password blank.
The router has now been reset. Follow the steps in Securing D-Link DI-524 Wireless Router to secure your router.
admin username: admin
Default admin username: admin Default admin password: <blank>
Aug 16, 2009 | D-Link (DWL-2200AP) 802.11g/b Wireless...
D-link DI-614 won't reset and the password stays same
For problem that you have posted, you can try doing a hard reset on the device by taking a paperclip and perform a hard reset. With unit on, use a paperclip and hold down the reset button on the back of the unit for 10 seconds. Release it and the router will recycle, the lights
will blink, and then stabilize. After the router stabilizes, open your browser and enter
192.168.0.1 into the address window and hit the Enter key. When the
password dialog box appears, enter the username admin and leave the
password blank. Click OK.
Please let us know if that was helpful enough.
Good Luck & Thanks
Shiv.
Aug 12, 2009 | D-Link AirPlus DI-614+ Wireless Router
Router configuration
you need to open the configuration page of the ADSL router and enter the configuration settings manually.
into your browser type http://192.168.0.1 >> username: admin >> password: admin
then in the setup page...enter the correct setting provided by your ISP...like encapsulation...multiplexing..VPI / VCI etc...call them if you have to...then enter your username and password for your internet account (you need to contact your ISP also for this.)
if ever you still cant enter into routers setup page...you can reset it to factory default...at the back of the router...there is a small hole..(usually in red border).....
turn on router >> then push a stick into the hole (small stick enough for the hole) for about 5 secs...then try again http://192.168.0.1 >> username: admin >> passoword: admin
if you need further info...please post back. good luck
Feb 09, 2009 | D-Link DI 514 Wireless Router (DI-514)
Configure DMZ Host
enter username admin and password blank (nothing), i got 401 Unauthorized messege 3 times reset the routher DI-524
Feb 16, 2006 | D-Link DI-704P Router
D-Link AirPlus DI-614+ Wireless Router Logo
57 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
