Question about Sony KDS55A2000 55" HDTV
Four Blink Code on SONY KDS-60A2000 Rear Projection TV
My TV is actually the KDS-60A2000. This web site did not allow for that exact model number. Anyway. This is the story regarding 4 red blinks of the power light.
First time this happened and the TV would not power on I thought it was the bulb. I removed and re-installed the bulb. A total no brainer. Anyone! can do it! even your Cat or Dog?
The TV did work for a while, however a couple of months later the 4 blinks returned.
I googled the problem and narrowed it down to the cooling fan for the bulb.
Don't call Sony.
You'll get India or the Phillipines and get no where!
I ordered the fan directly from Sony part number 883586031 it was around $30.00 including shipping.
If your a little handy you can install the fan yourself.
MOST IMPORTANT MOST IMPORTANT
BEFORE YOU REMOVE THE OLD FAN!!!!!!
Make sure you see which direction the writing is facing on the fan blade. i.e one side of the fan is all black the other side of the fan blade has writing on it.
If you put the fan into the housing backwards the air will be blowing the wrong direction.
This fan is located on the lower left side of the TV. very near to the bulb.
NOT the little fan dead center of the TV. The fan you are dealing with is hard to see, actually almost impossible to see, until you get the back off the TV.
1. Unplug the TV and remove the side cover to the bulb access where a screw is hiding.
2. Remove all the other screws that hold the (lower back panel) to the tv.
3. Carefully unplug the plugs that will allow you to remove the box that contains the fan. Two or Three.
4. Remove the metal chasis bar that attaches the top half of the TV to the bottom.
5. Carefully remove the whole box that contains the fan.
Please Take Careful note of where everything was. a digital picture before your start works wonders!
Re-install in the reverse order.
I saved $400.00 bucks.
If you prefer not to deal with the fan on your own. I found that once I got the TV operational with the old fan installed. I was able to go into the settings menu with the TV's remote and set the fan speed to high.
I think it is less likely to stop running in that mode. This fan we are speaking about sits right behind the light.
Perhaps a gentle tap on the back of the set, may jiggle the fan enough to get it running. Once running and the set lights up, you can then change the settings mentioned above and perhaps get more mileage out of the fan.
I will update this message, if my fix was not the problem.
  • brandong16 Feb 21, 2009
    I had the same problem and came across your blog and your a life saver!!! Thanks, you hit that problem on the head.
  • Karen Lee Pelletier Sep 28, 2012
    I know this is like 4yrs after the question was answered, but just wanted to say THANK YOU! I was in the middle of a show and my TV shut off. I saw the blinking and google'd it. Your answer was the top hit! Took me about 1hr (usually my husband would do this but he was at work) and I'm back in business.
I took a can of compressed air and blew air into the larger openings. A nice cloud of dust and several puffs of air later, the tv turned on.
Posted on Aug 05, 2009
  • 10,594 Answers
Fantastic job you did. I will appreciate coming updates.
Posted on Sep 20, 2008
SOURCE: sony kds-60a2000 has a green tint to picture
I have had the same problem for about 6 months, and never paid much attention to it. I also noticed that when trying to change the menu color, the colors do not show up correctly.
Now it seems to be getting worse, and so I started doing some research, starting with the Sony site. That is when I found out there is an extended warranty for the KDS series (50a2000, 55a2000, 60a2000, r60xbr2, and r70xbr2) TVs because of an optical block issue, until June 30, 2010, no matter when you bought the TV.
You can see the recall here: http://esupport.sony.com/US/perl/news-item.pl?news_id=277&mdl=KDS60A2000
It seems they are extending the warranty, but not doing a recall. In other words, they aren't telling anyone, but if you happen to find the information, they will replace the optical block, if necessary. The closest I could find to the green hue issue is a purple haze on the screen.
I don't know if this is the problem, but I have scheduled an appointment to have the optical block changed. I will repost after the optical block has been changed and inform whether this is the fix to the problem.
Either way, the optical block seems to be an issue and would get it replaced whether you need it or not.
Posted on Aug 23, 2009
  • 239 Answers
SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
Posted on Mar 04, 2009
  • 668 Answers
SOURCE: I have no picture and light flashes 5 times
If you pull the right side out (as you look at the front), get you ear down to the fan exhaust area and turn the set on. If you do not hear the fan turn or feel air being blown out, then you have a defective fan. It is a common problem.
Hope this helps,
Skyassoc
Posted on Jun 22, 2009
  • 135 Answers
SOURCE: the picture appears to have a green tint to it
The optical block is failing. Contact SONY for a replacement. They have extended the warranty or replace the sets
Posted on Jan 31, 2010
Testimonial: "I had no idea that Sony had extended the warranty, thanks a lott! "
welcomejee
  • 10594 Answers
SOURCE: I HAVE A SONY KDS-60A2000
3 times red light blinking indicates that Lamp Cover has not been fixed in its location properly after lamp replacement.
Please make sure lamp cover (its first thing that was removed to replace lamp) is installed securely.
Thanks.
Posted on Mar 11, 2011
I need help troubleshooting
Hello, How many times does the red light blink and repeat? Are you sure all the covers and doors are correctly in place?...tks
Apr 16, 2015 | Sony Grand Wega Kds-60a2000 60-inch Sxrd...
Tip
Sony KDS-60A2000 Service Manual
Download Sony KDS-60A2000 HDTV Service Manual
Models: KDS-50A2000 / KDS-50A2010 / KDS-55A2000 / KDS-60A2000 / KDS-60A2010
Have you misplaced your Sony KDS-60A2000 HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Sony KDS-60A2000 HDTV Service Guide?
Follow this link (& click FREE) to download a pdf version of the Sony KDS-60A2000 HDTV Service documentation.
I hope that helps.
__________________________________
on May 08, 2010 | Televison & Video
Tip
I hope that helps.
on May 08, 2010 | Sony KDS-60A2000 60" HDTV
My sony is turning on and off when I turn it on. The picture and sound appear and disappear. What is wrong and do you have the part..
The most common cause of picture disappearing and returning in a Sony LCD Rear Projection TV is a faulty bulb. Replacing the bulb is the first step in troubleshooting this type of problem in KDS-60A2000 and all other Sony Rear Projection LCD TVs.
Sony Lamp Gallery
shows all Models and Lamps for Sony Rear Projection LCD TVs. KDS-60A2000 uses XL-5200U Lamp.
easyab
May 06, 2011 | Sony KDS-60A2000 60" HDTV
My power light is flashing red three times on and off. sony kds-60a2000 is the model, what do i need to do?
The 3 blink code indicates that the lamp door is not secure. If you havent removed the door then its probably the switch for lamp door sensor.
I would remove the lamp door and then reinstall it. Do this with the set unplugged then plug it back in and check operation.. Basically sometimes the lamp door switches become dirty and by removing and reinstalling the door it usually corrects the problem..
If this doesnt work then you will need to either have the set checked out by a tv technician or you can try replacing the switch yourself. But as I said normally just removing and reinstalling corrects the problem.. Good Luck!
Nov 18, 2010 | Sony KDS-60A2000 60" HDTV
Sony xsrd projection model KDS-60a2000.......yellow tint on screen in several areas. tom
You need a new optical engine.Sony still covers this model for your problem under warranty.Call customer service at Sony and they will get you started.
Nov 04, 2009 | Sony KDS-60A2000 60" HDTV
Sony rear projection tv picture going on and off
change the lamp is is too weak to operate properly.
Sep 20, 2009 | Sony KDS-60A2000 60" HDTV
Sony model kds-55a2000
Go to projectorlampexperts.com
Jun 11, 2009 | Sony KDS-60A2000 60" HDTV
hope this helped
please rate well
Mar 04, 2009 | Sony KDS-60A2000 60" HDTV
Sony KDS55A2000 55" HDTV Logo
8,501 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
