Question about HP Designjet 110plus nr InkJet Printer
Designjet 110 Plus
I cannot find an electronic module (part # C7796-60149) ANYWHERE !!! HP has it on backorder and I was told (quietly) that no vendor order has been or will be placed for it.
ANYBODY HAVE A SOLUTION? THANKS !!!! Steve in Albuquerque
    Problem Solver:
  • 12 Answers
DesignJet 100 Series
C7796CR, C7796C, C7796DR, C7796D, C7796ER, C7796E
C7796-69149 CAD E-MODULE ASSY SV-RC 280.00$
I am working in HP service center and have problem like that HP change database numbers :)
Posted on Oct 01, 2008
  • HP Expert
  • 141 Answers
Contact TSA world. they should be able to help. Good Luck!
Posted on Sep 20, 2008
Amount of ram Hp designjet 500 plus 24 inch and amount of ram support for Hp designjet 500 plus 24 inch.
According to the service manuals there is no memory upgrade for the 500 and standard memory is 16mb.. The 800 and 510 only have upgrade capability.
Apr 05, 2015 | HP Office Equipment & Supplies
Hp designjet 110 plus prints jagged lines instead of continuous smooth lines. How can I fix this?
This could be a hardware problem, there is no safe way of manually doing it yourself so i would advice to take it to the nearest hardwire repair store.
Oct 27, 2013 | HP DesignJet 110 Plus InkJet Printer
HP Designjet 110 plus does not print yellow
if the cartridge is full or empty, try another cartridge. If the cartridge has ink in it then run the cleaning program in its software and a test page from the control panel>printers> HP icon
Feb 15, 2013 | HP DesignJet 110 Plus InkJet Printer
What is system error 0B0006 on Hp design Jet plotter? I have replaced the power cable but no luck
The Trailing Cable has been incorrectly connected OR the fuse in the Electronics Module has been burned.
Corrective Action: Turn the Printer OFF and disconnect the trailing cable. Check that the ends of the Trailing Cable are flat and are not damaged or bent. Reconnect the Trailing Cable correctly, making sure it is pushed in firmly. Do the resistance test. Power ON the Printer and check if the Error Code disappears. If the Error Code continues, replace the Main Logic Board
Note: The logic board is a direct replacement for the Designjet 1050C Plus and 1055CM Plus. If the plotter you are repairing is the Designjet 1050C (not Plus) you will also need to replace the memory and the firmware.
If you are repairing a Designjet 1055CM (not Plus) you will have to replace the Hard Disk Drive also. The firmware is identical for the 1050C Plus and 1055CM Plus
Note: The aerosol fan is not used in the Designjet 1050C Plus or 1055CM Plus. Coil the cable out of the way or completely remove the fan.
WARNING TAKE CARE WHEN CONNECTING THE TRAILING CABLE TO THE ELECTRONICS MODULE OR CARRIAGE. INCORRECT INSTALLATION WILL BURN THE FUSE IN THE ELECTRONICS MODULE, CAUSING THE COMPLETE FAILURE AND REPLACEMENT OF THE LOGIC BOARD. 100 OHMS OR HIGHER MUST BE SEEN AT THE TEST POINTS. CONSULT THE SERVICE MANUAL FOR CORRECT PROCEDURE.
Continuable and Non-Continuable Error Codes
Some of the Error Codes are continuable, which means you can press Enter on the front-panel and continue working with the Printer. Non-Continuable Error Codes do not allow you to continue working with the Printer, in this case power the Printer OFF and ON again and see if the System Error disappears. If the Error Code reappears, then the Printer requires service in order to resolve the problem.
System error codes are hexa-decimal based numbers generally caused by internal system errors. Only try one recommended action at a time and check if the error code has disappeared.
thanks and regards
kindly rate this solution
Feb 12, 2011 | HP DesignJet 1050c InkJet Printer
Hp designjet 110 plus with a system error 86:11
The 86.11 is a carriage movement error. Unplug the unit for a minute then power it up again. If there is still an error code check for obstructions in the carriage path. Make sure that the carriage moves freely. Also check the carriage for free movement and the printheads are properly seated.
Hope this helps.
Aug 25, 2010 | HP DesignJet 110 Plus InkJet Printer
HP DesignJet 110 Plus NR InkJet Printer is not printing black
Hello
Have a look at the link below, it should assist you in solving your problem.
Click HERE.
Kind regards
Michel
Jun 23, 2010 | HP DesignJet 110 Plus NR InkJet Printer
Color is stripey instead of solid
Run the "clean printhead" from your computer's printer utility.
It could also be that you're printing using "draft" or "low" quality settings
Apr 02, 2010 | HP DesignJet 110 Plus InkJet Printer
HP Designjet 110plus nr InkJet Printer Logo
499 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
