Question about Bosch SHU9950 Dishwasher
Shu9950 white plastic shims
After removing front cover two white shims fell out. where do these things go. after putting it together
  • Anonymous Oct 06, 2008
    I just had the same problem. I have a Bosch SHU 4306 model (8 years old) and when I removed the front door panel to replace the control module, two shims dropped off the bottom of the door panel. I usually am pretty sharp with mechanical things, but where these shims go is beyond me.
  • jchome Jan 13, 2009
    As of this morning, I have the same problem on my SHU9955UC/12 (aka SHU 9950). I suspect they are somehow placed near the bottom end of the door, at the sides where there are rectangular cutouts in the insulation. They are probably some sort of vibration or noise dampening device and therefore not critical to the DW's function. As I await my part, the black On/Off button, I've reassembled the door, and it all goes back together fine without the shims, or whatever they are.
    Maybe my local Bosch dealer will give me a hint, even though it means losing a service call
    Problem Solver:
  • 5 Answers
Hello Folks.
Just spent the last 45 mins on my back under the SHU 9950's door, with a kettle of (cold!) water sitting just above the soap dispenser - the door will spring back up with the front removed. Basically there are three "components" to the shim: the flat side, the short comb side and the longer comb side. The way that worked for me was, with the door elevated about 20 degrees, I slotted in the top five flanges, having already placed the shim in the middle of the insulation cutout area on the door-front, flat side against the door, long comb closest to the door-front's side. You should push the short comb flush up against the insulation, so that the shim will be clear of the two door pieces when you fit them together. The shims seem to serve 2 purposes: preventing the door from torqueing as well as allowing the door to open perpendicular to the unit. Good luck!
Posted on Sep 17, 2010
How to put a thread cutter in husqvarna viking desinger se sewing machine
I believe the plastic cover (gray?) toward the end of the arm (left of the needle plate) is removable by prying (gently) on the front edge and sliding toward you. Unless the cutter is broken, you should be able to figure out how itall fits back together.
Dec 21, 2012 | Husqvarna Sewing Machines
My l6 fell and now the screen is blank what should I do
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
What you have to do is simple.
1. Remove the battery cover, battery and SIM
2. Use the screwdriver or tweezers to gently pry off the RF grommet located on the antenna cap (below)
  • Removing the antenna cover:
    3. Carefully use the flat end of the tweezers to release two latches on the top end of the antenna cover, then carefully lift the antenna cover away from the phone.
  • Removing the transceiver PC board shield:
    4.Using the T5 screwdriver, remove the 6 housing screws from the phone. Set the screws aside for re-use (see Figure 10).
    5.Lift the metal shield away from the phone.
  • Removing the housing:
    6. Insert the plastic shim between the front housing and the chassis assembly. Slide the plastic shim around the phone between the front housing and the phone to release the housing catches along the sides of the front housing
    7. Carefully lift the bottom end of the front housing over the phone. The earpiece will still be connecting the front cover to the rest of the phone at the top of the phone so be careful
  • Removing the earpiece speaker from the front housing:
    8. Use the plastic shim or tweezers to separate the earpiece speaker from the front housing
  • Removing the LCD screen:
    9. Use the tweezers to release the display module assembly latch located at the side of the display module
    10. Lift up the top edge of the display module
    11. Carefully thread the display flex cable through the slot in the chassis assembly and lift the display module away from the chassis
Replace the old screen with new an
d reverse the whole procedure for reassembly
Take care
Jun 18, 2010 | Motorola Mobility L6 Cellular Phone
Do you have any schematics to put the front plate back on
They go in the lower section of the door panel to prevent it from bowing and popping. If you look at how the insulation is cut you will see, I think they face sideways. You may also have an imprint on the sheetmetal of the door about 4" up from bottom if I recall
Sep 06, 2009 | Bosch SHU9950 Dishwasher
Front passenger side seat
all you need to do is take the 2 14mm bolts off on the front.. and remove the little plastic covers on the back side (same place on the frame as the front) you might be able to shake it out but if not there is a couple of wires that you need to unplug one is 16 pin plug. that runs the power just pull the clip off and unplug it by pushing the tab and pulling it out.. and remove the yellow clips.. by pushing them together then pulling like one of those asian finger things... BUT BE CAREFUL the yellow ones are ABS make sure the car is off and the key out of the ignition... if you make all the way to this point take the seat out and turn it around and shake it out there might be come covers that you need a phillips screwdriver to get out... but don't be scared it's really easy to put back together just take your time and try not to bend the plastic clips... email me if you have anymore questions..
Aug 15, 2009 | 2007 Honda Odyssey
Fridgidare Model #LTF2940ESO won't start Error Message DDO
The code means the detergent door is open. There is a magnet placed inside the detergent door cover housing that has probably fallen out. This magnet completes a circuit when the door is closed. It usually happens when cleaning the compartment and can usually be found stuck somewhere on the washer metal body itself or somewhere on the path you took while taking it to wash it out. Take the detergent tray out and dissamble it by pushing open the plastic tabs that hold it together. Look for the small 1"long magnet. If there isn't one. take your tray assembly to a repair dealer and have them put a new one back in. It is just a few dollars and your problem will be solved.
Mar 20, 2009 | Frigidaire Washing Machines
Bosch Dishwasher on/off
It could be the switch. If the black plastic On/Off button comes all the back up into cutout in the top of the door, you must remove the front of the door (10 little screws; two shims will probably fall out; good luck figuring out how they go back) and then the plastic top (4 little screws) that contains the On/Off and the wash mode buttons. Now you've exposed the real on/off switch, which has a reddish/brown stem (at least on my unit). Test the switch; if the DW doesn't stay on when you depress it, you need a new switch. If it stays on, then goes off when you depress it again, the switch is likely good and maybe you have a problem with the black plastic cover button.
May 30, 2008 | Bosch SHU9950 Dishwasher
Bosch shu 9950
Take off the front panel (10 little screws, two shims will fall out) and you'll see the two handle bolts on the inside of the panel. Tighten 'em; reinstall the panel (good luck figuring out how the shims go back...)
Feb 17, 2008 | Bosch SHU9950 Dishwasher
Access controls
screw driver hex#15
Oct 27, 2007 | Bosch SHU9950 Dishwasher
Soldering 'Card Cover Open' Switch Closed
I had the same problem after a little plastic trigger thing fell out of the hole above where it says push to eject. After poking around for a while I took the camera apart (remove 7 screws) which made it much easier to see, with a magnifying glass and lamp, what the problem was. A damaged wire that needed to be connected to something. Only the very end of the wire was visible, inside a small white plastic box thing. The plastic box thing eventually fell apart with my attempts to put in bits of wire of varying shapes. When it came loose I was left with a short stiff bit of wire. I took a strand of copper wire (from an old piece of electrical wire), twisted it so I had a small loop at one end, looped it over the end of the stiff bit of wire, and then curved the rest of the wire (about 3 - 4 cm long) so it was resting on a silver piece of metal just below where the white plastic box had been. Put the cover back on and the camera worked. Needless to say, it won't let me know if I've left the cover off, but then it won't work unless the cover is on, so it doesn't seem to matter. Saved about $100.
Aug 13, 2007 | Olympus FE-130 Digital Camera
My screen keeps showing card cover open error.
Nov 17, 2006 | Olympus FE-130 Digital Camera
Bosch SHU9950 Dishwasher Logo
270 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
