Question about HP Photosmart 4180 All-in-One Printer
STARTS PRINTING WITHOUT COMMAND. HOW TO CANCEL PRINT?
HOW TO STOP PRINTER?
    Master:
  • 638 Answers
Just off the printer.remove the usb wire from the back of the printer .then. click start ---then settings------go to printers and faxes.-----open your printer you have loaded in that option.and then delete the printouts.
thanks.
Posted on Nov 08, 2008
How to stop and cancel printing on brother Hl-2240d printer on a Mac Pro computer
Most printers can be stopped by going to your control panel and selecting printer and then find the command that cancels the printing job. Try this teaching video:
https://www.youtube.com/watch?v=YXIM_17IIl0
Feb 28, 2015 | Brother Hl2240d - Hl-2240d Laser Printer...
Keep printing old docoments / will not print current docoment / printing seem to be strunt
Follow these steps to fix your problem :
Method A :
Press the cancel button or use the cancel menu command on the printer
The most obvious way to cancel a print job is to find a cancel button or a cancel menu command on the printer and to press it. So, if you have not already done this, try this method first.
If this method worked for you, you are finished with this article. However, you may want to read the "Prevention tips" section to avoid this problem in the future.
If your printer does not have these items or if this method did not work for you, try Method B.
Method B:
Turn the printer off and on
Next, try turning the printer off and then on. With certain printer models, this cancels the print job.
If this method did not work for you, turn your printer off, and then try Method C.
Method C:
Use Control Panel to cancel printing
This method is a bit fancier. We will use Control Panel to try to cancel printing.
But what exactly are you trying to do? Are you trying to cancel printing only a single document, or are there other print jobs that you want to cancel? And are all the print job yours, or are there print jobs that other people have sent to the printer? If you have to cancel documents that other people have sent to the printer, you must have Computer Administrator status or you must have permission to cancel the print jobs. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
To cancel one or more print jobs, follow these steps.
1. Click Start, and then click Run.
2. In the Open box, type control printers, and then click OK.
3. Right-click the icon for your printer, and then click Open.
* To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
* To cancel all print jobs, click Cancel All Documents on the Printer menu.
Note If you cancel a print job that you did want to print, make sure that you send the print job to the printer again.
If this method did not work for you, make sure that your printer is turned off, and then try Method D.
Back to the top
Method D: Stop the print spooler and delete all spooled files
If you tried Methods A through C and you were not successful, Method D should work for you. If you came to Method D immediately only to delete a print job, some of what we say here might not apply to you, so please bear with us.
Method D is somewhat more complex and will require a bit more work than the other methods, but don't worry. Method D looks much more difficult than it really is.
First, in case that you don't know how printing works, here is a short explanation. Print jobs are sent to the printer as spooled files. This means that the files are put in a temporary location so that the printer can access a print queue and print jobs at its own speed. If you stop the spooler and its files, most of the time, you both cancel printing and delete the print job.
Note To use this method, you must have Computer Administrator status. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
Step 1: Start Notepad
To stop the print spooler and its files, we will have you create and run a script file that will automatically stop the service. This sounds difficult, but it really isn't. Just follow these steps carefully.
2. In the Open box, type notepad, and then click OK. Notice that a blank Notepad document opens.
Step 2: Copy a command script to Notepad
Now we will have you copy and paste some commands to the Notepad document.
1. Carefully select (highlight) all the following text:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
2. Right-click the text that you selected, and then click Copy.
3. In Notepad, right-click in the blank document, and then click Paste.
4. Carefully select (highlight) all the following text:
C:\DeletePrintJobs.cmd
5. Right-click the text that you selected, and then click Copy.
6. In Notepad, click Save As on the File menu.
7. In the File Name box, right-click, and then click Paste.
8. Click Save.
Step 3: Run the command script file
Now that you have created the command script file, you will run it. To run it, you will copy and paste the name of the command script file in the Run box.
3. Click Start, and then click Run.
4. In the Open box, right-click, and then click Paste.
5. Click OK.
6. Notice that the Command Prompt window opens to run the command script file that you created. Notice also that this window closes automatically when the command script file has finished running. If you do not see the Command Prompt window open, check that you saved the command script file by using the correct name and that you entered the correct command script file name in the Run box.
If this method does not work the first time, or if you cannot print anything after you use this method, restart your computer, and then try again.
Nov 20, 2010 | Lexmark X2500 All-In-One Printer
How do i cancel a print job?
Method A: Press the cancel button or use the cancel menu
loadTOCNode(2, 'resolution');
Method B: Turn the printer off and on
Method C: Use Control Panel to cancel printing
printing.
steps.
    • To cancel individual print jobs, right-click the print job that you want to
    • To cancel all print jobs, click Cancel All
If
future.
files
us.
it really is.
print job.
loadTOCNode(3, 'resolution');
    net stop spooler
    del
    del
    net start spooler
    File menu.
    then click Paste.
    Note Notice that
    this file name differs from most other file names that you might have seen. That
    is because this file is a command script file.
  8. Click Save.
    click Paste.
  5. Click OK.
    Run box.
Note If this method does
Oct 08, 2010 | Pitney Bowes AddressRight DA300 Printer
HP Laserjet 1320. Will not stop printing and not showing up in the Que. I have unplugged overnight, I have cancelled all jobs in the Que and will not stop printing. How do I cancel the job
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone.
Alternate method,
Click START
Click RUN
Type CMD ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
Type
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show Status ready with 0 document
Jul 07, 2010 | HP LaserJet 1320 Printer
If printing and toner runs out can I delete job in process?
Yes you can
Open Control Panel - from START button
Open Printers and Faxes Folder
Highlight the Printer icon - Right click and click on Cancel All documents.
If this does not cancel.. try these steps below
Click on Run
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
Type
Open Printers and faxes folder - Refresh the Window - the printer will show STatus ready with 0 document
Jul 01, 2010 | Ricoh Aficio SP C410DN Laser Printer
How do I cancel an order to make it stop printing and clear it out of the system
Click on Run
Alternate method,
Click STart
Click RUN
Type
Jun 23, 2010 | Zebra 105SL Thermal Label Printer
Can't cancel print from spool
Try forcing the spooler to stop and restart. In the command prompt (Start > All Programs > Accessories, right click and choose run as administrator with Vista and Win7)
Type "net stop spooler" <enter> without the quotes; on the next line type "net start spooler" <enter> again without the quotes. Once another prompt comes up, restart the computer.
I hope this helps.
(without the second command, the phrase "go get a cup of coffee after the reboot" becomes a part of the routine. These commands have worked since Win95.)
Apr 18, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
Cannot delete print jobs in queue
Instead of restarting, try this:
1. Start
2. Run
3. Type this in the box: services.msc
4. Hit ENTER
5. Scroll down to PRINT SPOOLER
6. Right-click on it and choose RESTART
This will clear out your print queue without having to restart. Good luck!!
Aug 22, 2008 | Lexmark Office Equipment & Supplies
Prints without a command
it might be because of two reasons,
one is , check ur printer buffer, it might be restarting some old prints..
but, the prob might be the second as explained below
u might have installed some software , which might be running in the backround, and in tat , if some button or key is being assigned to print screen, then, when ever ur pressing tat key by mistake, or unknownling, the problem is occuring, so check ur backround softwares...or even installed softwares..
Pls, let me know, i f it works...
Jul 16, 2008 | HP Officejet 5610 All-In-One InkJet...
Hp printer will not effectively cancel print
Solution by www.freaksmania.org,
We cannot turn off HP printers when the printing job is going on or it runs out of paper,Paper Jam or Cartridge runs out of Ink or any other reason,ie power failure.
To Cancel printing easily,
1)First plug out the Power Cable(the System tray icon will now disappear).
2)Plug out the USB Data Cable
3)Reconnect the power Cable and turn the printer on.
4)Turn the printer off again and Connect the USB Data Cable.
5)Turn on and then your existing printing Job will be Cancelled.
Solution provided by Team Freaksmania
http://www.freaksmania.org
http://www.freaksmania.org/forum
http://www.freaksmania.org/coderz
http://www.freaksmania.org/graphics
Nov 08, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP Photosmart 4180 All-in-One Printer Logo
Seeker5211
Seeker5211
