Question about Poulan Garden
Clearance Specs For ignition module to magnet on 25cc engine.
What are the clearance specs between ignition module and magnet?
  • 163 Answers
.010"(.25mm) you can also use an index card or manilla folder
Posted on Nov 30, 2008
Buffalo tools 7000 watt 13hp ohv 4 stroke valve clearance
if you cannot get the specs from on line or from a service agent , generally the following apply:-
water cooled engines
inlet hot .010"--exhaust hot .012"
for air cooled engines inlet hot .012"-- exhaust hot .014"
Aug 30, 2015 | Buffalo Tools Electrical Supplies
Whats tappet clearance for nissan d21 td 2.5 engine
You are going to have to get the Haynes manual for the vehicle to get the valve clearance specs. Remember a cold engine adjustment is slightly less than the final or hot engine adjustment as the metal expands.
Jun 16, 2015 | Nissan Cars & Trucks
Where to find a free service - repair manual for a Yamaha sz16. That has the specifications for engine valve clearance adjustment. Valve clearances in thousands of an inch?
Clearance might be in mm micrometers. How do you know clearance needs adjustment? Google your question. Leave out the "free manual" ask about the specs for your year and model.
bet you get a better answer.
Feb 26, 2015 | Yamaha Motorcycles
What are the valve lash specs for 2007 Honda Accord V6?
There is a specific procedure for setting valve clearance . I highly recommend getting a repair manual for the correct specs & procedure. The engine must be at TDC with the #1 cylinder on the compression stroke , that will allow you to adjust ONLY certain valves , then you have to turn the engine one turn to TDC again only now #1 will be on the exhaust stroke & the rest of the valves can be adjusted . it's important that you know the difference between the two !
Jan 08, 2015 | Honda Cars & Trucks
Toque specs on a 1971 in line 6 mercury comet's rod bearings and the clearance between the bearing and crankshaft
TORQUE SPEC FOR ROD BEARING BOLTS 19 - 24 FT LBS TORQUE SPEC FOR MAIN BEARING BOLTS 60 - 70 FT LBS, CRANKSHAFT PULLEY BOLT 85 - 100 FT LBS. MAIN BEARING OIL CLEARANCE .0005 - .0022 CONNECTING ROD OIL CLEARANCE .0008 - .0015 / SHAFT END PLAY .004 - .008 / AND ROD SIDE CLEARANCE IS .004 - .011 HOPE THIS HELP THIS INFORMATION I GAVE YOU IS INLINE 6 -200 AND INLINE 6 - 250 ENGINES
Nov 11, 2011 | Cars & Trucks
What are the valve clearance specs for a 1996 Toyota T100 v6?
you should get haynes auto repair manul for your particular car that way you will have the correct information about that. you can get the manul at autozone or any autopart, all you need is your car info, to pick the right manual for your car, good luck
Jul 15, 2011 | Toyota T100 Cars & Trucks
Valve clearance 4hj1 isuzu engine
This is the specs for the 4H Diesel engine:
Intake valves clearance cold 0.4mm(.016inches)
Exhaust valve clearance cold 0.4mm(.016inches)
Jan 28, 2011 | 1995 Isuzu Pickup
What is the difference between hot and cold vavle clearances
When it is stated that valve clearance should be set when hot, you first adjust the clearance on the cold engine after assembly to the hot setting specs if they are the only ones given, then let the vehicle warm up to operating temperature. Then adjust the clearances again.
If it is just a tune-up(undisturbed engine), let the engine warm up to operating temperature, then adjust.
The reason is that metal expands as it heats up, which affects the valve clearance.
Dec 05, 2010 | Toyota Land Cruiser Cars & Trucks
Garden Logo
303 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
