Question about Zebra TLP 2844-Z Thermal Label Printer
Trying to setup a Zebra TLP 2844-Z on serial port
I'm trying to set up a Zebra TLP 2844-z on a serial port. When connected through LPT1 it works fine. I removed it and tried to connect it using a serial port (NOT usb). But Install Wizard doesn't seem to detect the printer on either COM port (6 ports listed). At startup windows detects the new hardware and launches the install Wizard, it "sucesfully" installs the printer but when information is sent to print through Zebra Design Pro it does nothing.
What should I be doing then?
    Scholar:
  • 45 Answers
Two possibilities are the port configuration and the type of serial cable.
The printer has a feature that will try to match itself to the PC's configuration. Press and hold the feed button until the green status led flashes three times. While the led flashes send a ZPL format to the printer (hopefully you can do this through Design Pro by trying to adjust the printer or print labels, but the labels will not print). When the printer and PC are synchonized, the led changes to solid green.
If you can synchonize but still can't print, the problem might be the serial cable; not all serial cables will work. You should use a full null model cable (all pins connected except 1 and 8).
Posted on Sep 20, 2008
I'm not getting communication from the RS-232. Is there a setup I need to do or something?
To setup connection first find serial settings by:
Hold feed button whilst switching on label, will then print configuration and do a calibrate.
from the configuration print find settings for serial port format is something like " Serial port : 9600, N, 8, 1 "
set your PC to the same settings. This should work just fine.
Jun 18, 2011 | Zebra TLP 2844-Z Thermal Label Printer
Hi , We're trying to print the file to TLP 2844 using DOS commend : copy test.txt LPT1 , but the printer does not response . We installed the out-box driver and make the driver pointed to LPT1, It...
the only thing I see missing is the ":" after lpt1
ie - command should be copy test.txt lpt1:
you could also try using print test.txt
or type test.txt > lpt1:
Mar 18, 2011 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLC2844 wont print at all
Try to make the self-test first:
Power OFF
Press "FEED" and keep it pressed and turn the power ON again.
Did it print?! if Yes... There must be a cable problem or port.
Is it USB? Serial? Parallel ?
Let's say it's Parallel, go to the command line and type:
"dir >lpt1"
without the quotes and assuming it's connected to 1st parallel port
did it print?!
on serial would be "dir >com1"
or, if it shows up in "Printers", pre-define it and just type: "dir >prn"
Still doesn't work!?
Try with a different cable, or other computer.
You can use it even without installing the drivers...
Sep 14, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Unable to upgrade Zebra TLP 2844-Z printers firmware
What is the problem if this works?
May be there is a problem on the boot rom!
Jun 24, 2009 | Zebra TLP 2844-Z Thermal Label Printer
How to print to zebra tlp 2844 using vb6 through usb port
You need to use a printer driver or use ZPL commands to print.
Jun 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844 problem "AUTOFR"
Comment est que voue envoyer des commandes?
Est que vous utiliser USB?
COPY file USB??? quelle est la syntax? pas de LPT1 sur ma machine...
donque COPY file LPT1 /A ne marche pas
May 14, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra printers & MS Word
HI Les1810,
You should be printing faster with Zebra fonts.
Which driver are you using? Version?
I strongly recommend the Zebra Designer V1.3.08, available at Zebra.com
To isolate the problem, capture the output to a file.
Define a local port as C:\output.txt and set that as the port in driver properties.
Now print your document. The printer commands will be in C:\output.txt.
Send c:\output.txt directly to your printer.
For LPT1, use the DOS copy command to send the file. (Copy C:\output.txt LPT1)
For serial connections, use Hyperterm to send the file.
For network connections, use ftp.
No easy USB method is readily available.
Does this print faster than printing the original document from Word through the driver?
If yes, then update your driver.
If no, debug your communication to the printer (LPT1, serial, network, etc.)
Sep 24, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Help me with Zebra TLP 2844
The printer only understands EPL code. (Eltron Programming Language) If you are trying to print text from DOS it wont understand (interpret) the txt codes.
To verify that the printer is working.
Open a DOS box, start the dos editor. Type Edit. Dos editor will open.
Type a single capital letter U. and print. Send to printer. The printer will print a configuration label.
EPL code to reset printer is
^default.
If you want to print a text file. use the Zebra Universal Driver. Zebra TLP2844. Open any windows application. E,G, Notepad. type text and send it to printer. Print as normal.
Jul 24, 2008 | Zebra LP 2844 Thermal Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
1,867 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
