Go to control panel>add remove programs>add remove windows
components. The very first box is "accesories"- make sure the box is
checked, and add it. If it is already checked, uncheck it, let winows do
it's thing, go back and check it to add it back; hopefully you'll be
back in business. I don't know if the latest updates are balling things
up, but I've noticed alot of people losing windows components lately.
Any doubts you can contact a technician through the website
www.thebestpcdoctor.com
Toll Free: 877 407 8229
Using
a microphone with computer
To use any microphone with your
computer you will need to enable it in control panel. The following
instructions are for Windows XP but are broadly similar for Vista
and Win7
Click START, CONTROL PANEL, SOUNDS
& AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices
Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure
that there is not a check-mark in the MUTE box against microphone in the list
of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't
checked before closing the window.
Now click the VOLUME button in the
SOUND RECORDING BOX. Here SELECT microphone as an input source for recording
(as opposed to un-checking mute in the playback controls).
NOTE if your microphone
is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES
on the tool-bar and place a check against microphone in the list
entitled 'show the following volume controls' and then click OK. Same
applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume
as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust
slider to suit.
You might put a check mark in the box
to show the volume control on the Task Bar so you can go straight to it to make
adjustments in the future.
In addition to the instructions below you may need to make sure you have selected the right sound source (normally WAVE) in your recording program
Using
and Win7
& AUDIO DEVICES
Click VOICE
That should be it.
slider to suit.
Probably need to enable in control panel as per instructions below.
You may also need to check you have correct input device (wave) selected in your recording software
Using
and Win7
& AUDIO DEVICES
Click VOICE
That should be it.
slider to suit.
