Akai LCT3201AD 32 in. LCD Television Logo
Anonymous Posted on Sep 19, 2008
Has no power.
I tried several outlets. HELP
olayoju victor
Level 2:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 191 Answers
  • Posted on Nov 10, 2008
olayoju victor
Expert
Level 2:
Night Owl:
Answers
191
Questions
0
Helped
71134
Points
328
Toshiba Regza 52rv535u will not turn on
Try different power cord. Try a different outlet.
Take it to a repair shop.
Battery charging shows quick green light
Ill try to help you, I think the slow flashing green lite is when you first plug it in the longer its on it will flash quickly when almost finished mine blinks untill full then stays on try to wear your battery all the way down then try to charge again good luck
Unit sometimes takes several minutes to several hours to turn on
Check power outlet and ensure proper voltage is present, if you know how to handle power, and have a measurement meter. Try connecting the TV to some other power outlet, where another equipment is working fine. If problem persists, the defects could be due to dry/leaky capacitors, dry solders in the PCB etc. and might require attention by a qualified service technician.
I have a 2004 Toyota Avalon. The 115v power outlet (in back seat area, bottom of back side of center console) does not work. I have tried several fuses - no luck. Help
The exact fuse for the power outlet. That would be inside the car, the lower finish panel by your left foot, a 15 amp fuse marked on the cover "Power Outlet". -------- check out that fuse.also you can connect additional 12 volt power source to the 115 v power outlet to make it work. Its bit of modification that has to be done.Click this link for its procedure:--- http://howtobyme.blogspot.com/2011/06/115v-power-outlet-in-center-console-not.html --------------- This should help.thanks.Helpmech.
2answers
Problem turnining computer power on
your power supply is going bad, its an easy thing to replace and less than sixty dollars to replace for about a 450 watt power supply
1helpful
Epson Stylus CS5800F Printer will not power on. Plugged into known working outlet, but no luck.
I had that same problem with my CX5800F. I tried it in several working outlets and shut down/started up many times. Tech support couldn't figure it out so they had me sent it back for a replacement. Several days later, before I packaged it up for shipment, I decided to test it out one more time, and it powered on! I sent for a replacement anyways. Since it's still under the 1-warranty, I'd suggest sending it back for a new one if all else fails. Good luck!
Print axis server error
check online to see if there has been any new update for that print server.
clear the job and try again.
make sure the print sever is plug into different outlet And the sever or the pc in different outlet.
good luck.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
