Question about Harman Kardon Audio Players & Recorders
My AVR 354 HDMI outputs. So when I fast forward on my DVR and press play I lose picture but still keep audio. Or I go to previous recordings and select the 1 I want to watch and the screen goes green. Why is this What am I doing wrong?
5 Suggested Answers
SOURCE: None of my taped programs are playing...even ones I've watched before
I called Time Warner!
Posted on May 12, 2008
SOURCE: DVR won't play
I hae a Motorola 6412 that had this problem. I turned it off, then unplugged it for 30 seconds. After turning it on I had to wait 1-2 minutes before I could acces the DVR, but it work now.
Posted on Oct 19, 2008
  • 119 Answers
SOURCE: HDMI output from AVR-4806
You say your connected from the DVD to the Denon with an HDMI cord and the Denon to the TV with an HDMI cord and you get no DVD video? can you get the Denon setup menu? if so change the res. output on the DVD to 480p, 720p or 1080i but not 1080p
Posted on Feb 25, 2009
  • 3 Answers
SOURCE: connection problem with HDMI cables on Denon AVR-589
Hi dmsgolfer22,
If your Time Warner Cable box is old enough that it has a DVI output it may have HDCP (copy protection issues) with the receiver. If you are having to use a DVI to HDMI adapter to connect to your receiver (output from Cable Box to input on Receiver) then it's very likely your cable box may have may not output the signal because it detects the HDMI repeater in the receiver.
The two best options to correct this are:
1. Connect the DVI to HDMI cable directly to the input on the TV, you lose the convenience of the video switching in the TV, but it will solve the problem. Then connect the digital audio output from your cable box to the receiver, although you've probably already done this.
2. Contact your cable provider and check into the possibility of them swapping out your cable box for a newer model that would have an HDMI output. This would be the best option since the HDMI output on the cable box would give you both the Digital Audio and Video through a single HDMI cable.
Let me know how it works out for your, or if you have any questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Posted on Feb 28, 2009
SOURCE: Direct TV DVR sound/no picture or pict. no sound
My Direct TV has no sound or picture but does show channel info at the top. Any help is appreciated.
Posted on Mar 31, 2009
Connecting
did you check this out yet? (from the owners manual)
IMPORTANT NOTE: If the AVR's video output resolution
is set higher than the capabilities of the actual connection,
you will not see a picture. If the best available video connection
from the AVR to the TV is composite video, press this button
and change the resolution to 480i.
Oct 06, 2012 | Harman Kardon AVR 3600
I have a Denon avr-3808ci. I have a Dish Network DVR and a Sony KDS-60A2020 tv. If I connect the HDMI cable on the DVR directly to the tv, I get picture and sound through the tv. If I connect the HDMI...
You are correct. I feel your pain. This will not work.
HDMI is a pure digital signal and the providers require the content coming over the Dish DVR to be COPY PROTECTED. So it will not work unless the HDMI cable goes directly from the DVR to the TV. This is to stop people from being able to make their own recordings of Dish shows, or making copies of your DVR recordings. If you really want to run things through your reciver, you're going to have to use the "component" or "composite" video feeds, not the HDMI. Sorry.
Sep 18, 2011 | Denon AVR 3808Ci Receiver
Dish HD-DVR connected to a Denon 3808ci via an HDMI cable. Problem is periodically, the screen goes black for a split second and then comes back. Rewind and play again the blackout doesn't repeat. When...
Your'e losing digital data from Dish or the DVR. Since even live TV is through the DVR it is always a potential problem when anything glitches. That it doesn't repeat on immediate rewind/playback says the data made it to the hard drive ok.
The Denon is only defaulting back to an analog audio feed upon loss of the digital (preferred) one.
If it affects the video AND audio simultaneously the cause is something common to them.
I'd look at HDMI cabling into the Denon from the DVR.
Don't blame the Denon just yet.
My $.02:
I'd skip the video right past the Denon to the TV/Monitor even if it means using component cables instead of HDMI, but keep digital audio coming in from the DVR. Added cabling and connections never improve anything. Plus, HDMI cables are expensive.
It would be interesting to see if the problem comes back and affects only the audio or the video.
If you use optical cable make sure it has smooth flowing curves and no small-radius bends that would lose light power.
http://www.retrevo.com/support/Denon-AVR-3808CI-Receivers-manual/id/3124dj391/t/2/
Feb 06, 2011 | Denon AVR 3808Ci Receiver
I just purchased a denon avr-1610 receiver and I cannot get picture back to my tv through the hdmi. I have a starchoice dvr which is dvi to hdmi, I come out of my satelite into sat/cab then out of my denon...
One possible reason is the HDCP (copy-prevention)-encoded signal from the DVR, which will transmits through to one device (the receiver) but not to a second (the TV). As an experiment and a possible solution, try reconnecting the HDMI cable from the DVR directly to the TV (provided you have an extra HDMI input on it), and using the component-video or S-video plus either digital or analog audio outputs to connect your DVR to the receiver. If this works, I think that the HDCP is the problem and this is the only solution.
It may be a little inconvenient to remember to switch inputs on the TV as well as the receiver, but you could probably program your remote with a macro to do both. The component video (or, more likely, the S-video) is also the best possible video signal you can use for dubbing to any DVD recorders, if you have one connected to the same receiver. You can still keep the HDMI connected from your PS3 (or other BD/DVD) player to the receiver, and from there to the TV, since that does seem to work -- if you don't mind turning on the receiver every time you want to watch a BD or DVD. My recommendation, however, is to connect all your video signals directly to the TV via HDMI or component, and use the receiver only for audio, or for switching of lower-level video signals like S-video that you can use for dubbing. That way you can always check the DVR or BD or DVD quickly without powering up your receiver, which takes a few seconds and much more power.
Feb 13, 2010 | Audio Players & Recorders
How can i connect Nintendo wii to avr-590. Have
To connect a Nintendo Wii to an AVR-590, I am assuming this is a Denon Receiver, you will need to connect the Nintendo Wii to the TV, then connect audio out from the TV to the AVR-590 Receiver, and select the receiver to be in Pro Logic. Depending on the TV, if you have fiberoptic output on the TV, you would hook a fiberoptic out from the TV to the AV Receiver, but you will still not get true Dolby Digital, just Dolby Pro Logic. This will be the most effective way to solve the problem. Hope This Helps
Geek Squad
Dec 28, 2009 | Electronics - Others
I lose my audio often for non-hd channels with dish 622 dvr
The problem could lie in youir HDMI cable, this is a common issue. if you swap HDMI cables and still have the same problem then bypass your A/v rec and connect your 622 direct to your tv and see if the problem persists, it it does, then your DVR needs to be replaced, you can call dish for addition troubleshooting if it is in fact your DVR.
Nov 10, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Denon AVR-4306 + Motorola DCT-6416 Blanking
Hi Jim,
I tried connecting my dvr via component and optical to see if it was my hdmi or my dvr. Ended up being a bad hdmi plug in back of my amp. I was fortunate enough to have both style connections on my dvr. Hope this helps
Turk
Oct 13, 2009 | Denon AVR-4306 Receiver
Connection/configuration issue: I have a Denon
Just confirming my understanding of your connections :
1). The DVD1800BD output HDMI is connected to AVR3808's DVD-in HDMI.
2). The DVD/VHS recorder output HDMI is connected to AVR3808's DVR-in HDMI.
3). The DVD/VHS recorder input (S-video and L/R Audio) is connected to AVR3808's DVR-out(SVideo and L/R Audio).
Right?
What other inputs have been connect to your AVR3808?
Does the recorder have Component Video inputs?
Please also connect DVD1800BD's output(Component video, S-Video and L/R Audio) to AVR3808s' DVD-in similar inputs and try recording onto your recorder.
Actually, its possible that you may be having a HDMI HDCP communication issue(High-Bandwidth Digital Content Protection) with the source product (DVD1800BD). First check with the source equipment manufacturer for any updates to their products.
If HDMI video is not passing through your AVR3808, you can connect it thru the alternate connection method I have mentioned above.
If the connections/recording still does not happen with the added anolog cables, then let me know , we can trouble shoot it further.
I hope the above helps.
Please do rate this solution and thanks for using FixYa!
Mar 06, 2009 | Denon AVR 3808Ci Receiver
No dish network sound through denon 1609 receiver
check the setting for the HDMI connection at the Denon you may have to assign the HDMI audio setting also on the front of the Denon while in the DVR mode press the input mode button on the front of the Denon to select auto and if that doesn;t give you sound you will have to connect a cable from the DVR optical.coaxial or analog audio output to the Denon and setup for that type of audio connection
Jan 19, 2009 | Denon AVR588 Receiver
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
