Question about HP DeskJet 3745 Printer
Knocking motor I have a 96 Chevy Silverado that wants to knock when you first crank the vehicle and when it has rpms put to it even in park. I dont know where to start .
  • 32 Answers
Hi Im buying a vehicle that has a knock in it. Since the body is in excellent shaped I decided Im going to get a new motor or a used one with a warrenty. Good luck.
Posted on Mar 26, 2009
  • HP Expert
  • 141 Answers
This must be the largest portable printer in the world! HAHA!!
Seriously though, i believe you may have a bad wristpin or crank journal bearing. you weren't specific on engine type so i am making an assumption that the motor is high mileage. Good luck!
Posted on Sep 19, 2008
Will broke motor mounts cause a miss fire on 96 5.7 vortex truck
Yes a broken motor mount can cause any vehicle to miss fire.
Feb 23, 2017 | Cars & Trucks
Best way to check the knocking on the lower end of the motor 4.3 GMC do I take lifters off and check down through there
you wont see anything from there --lower knock usually called rod knock caused by a bad bearing or wrist pin [piston pin]to inspect the lower end is by the oil pan you can inspect the crank and rods from there
Jul 31, 2015 | GMC Cars & Trucks
Have a 96 geo prizm that won't accelerate very well and is making a knocking sound any ideas?
knocking is a big thing, its a cry for help.
can be minor to horrific
knocking parked? or only driving.
in neutal or park?
knocking hot block, or cold block or both? at what RPM>/
only real oil pressure gauge works, not the idiot lamp
when the lamp comes on at 3-5psi, the war was lost.
my 96 makes 55psi cold just cranking, want a video of that?
find the knocking first.
if can ,be knocked , parked.?
id check oil pressure. real.
use a $5 stethoscope. find it.
drop all belts. to see if an accessory device knocks. (5min test max cold to start, yes, water pump dead)
PS/AC/ALT dead too.
still knock>
listen at valve cover. coming from there.
is the timing belt is old over 60k thy all shard and some knock load hitting that cover, it a for sure thing, skipping the 60k mile service point,
exhast header collerctor fange gasket , bad, allowing bang band bang as the 2 flanges pound themselves to death.
the top of the engine, see induction pips. (AIR) those mounts for sure can bang away, bolts missing.
knocking:
1 overheated the engine so bad its pinging? knocks up hills?
2: say exaclty when and not you get the knocks.
Dec 03, 2012 | 1996 Geo Prizm
Motor knocks, sounds like lifter , at startup??
I bought a new silverado in 2001 and took it to 3 differnt chevy dealers for the same thing and got the same answer from all they claim its a cold start knock one said it had somthing to do with wrist pins they used and said it was normal and i told him that im not ASE certified but have built a few motors of my own and when it knocks that aint normal but he said it was nothing to worry about and so far mine has knocked since it was new with no problems yet.
Jul 03, 2011 | 2001 Chevrolet Silverado 1500
How can i manually reset the computer on my 99 chevy silverado 1500 4x4? my oil pump is weak and it has a dry start and when i started it this mornin i think it kicked the knock sensor and shut my motor...
The knock sensor will not cause a no-start. The knock sensor only retards the timing when the engine is running. If the starter is not working we need to check the battery voltage, battery cables, starter, engine ground, neutral safety switch, ignition switch, security system. These are the only things that can cause a no crank.
If you really have the urge to clear your computer disconnect the negative battery cable for 10 minutes.
Mar 10, 2011 | 1999 Chevrolet Silverado 1500
Replace knock sensor on 2001 chevy 4.8
You have two knock sensor's, both sit under the in-take magifold on top of the engine, you will have to remove injector rail and in-take.
Apr 11, 2010 | 2001 Chevrolet Silverado 1500
Engine Knock on a 98 Isuzu Rodeo
Most likely it is a rod bearing and motor would have to be dissassembled to diagnose, you might want think about installing a low milege used replacment since it was run 5 quarts low on motor oil.
Nov 26, 2008 | 1998 Isuzu Rodeo
HP DeskJet 3745 Printer Logo
47 people viewed this question
Ben Johnson
