Question about Nokia 6120
Message icon and alert
I have a nokia n73 and when i receive a text message, the alert does not appear and the vibrate/tone does not sound. even on the display, the little envelope icon does not show up. it is onlly when the phone is on sleep mode or if i go to the inbox when i can see if i have unread or new messages. can you please tell me what might be the problem and what can i do? my phone does the same. when i used to receive a text message a display saying "1 new message" would come up on the screen, now it doesnt do this and doesnt show a little envelope which signifies an unread message... to see the message i have to continually check the inbox!!
    Brigadier General:
  • 7,752 Answers
You will need to contact your mobile provider and explain it to them and have them correct that on their network.
Posted on Oct 15, 2008
2 Suggested Answers
  • 111 Answers
SOURCE: message icon and alert
this should do the trick...press star, call button(the green one), three, and power button all together while powering up your phone..
Posted on Jan 27, 2008
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
Where or how can you turn your ringer volume up or down
Hello Hank,
When you make call use the left and right square key for increasing or decreasing volume.
Apr 15, 2011 | Nokia 2600
How do you change ring tone for a text message on a blackberry tour 9630
Go to the sounds icon in the upper left corner of your main Home screen (the one that looks like a speaker with sound coming out of it). Scroll down the list that appears and select Set Ring Tones/Alerts. Click Messages, then SMS Text. Select the ring tone and volume that you want for text messages, as well as any other options (like vibrate) and then exit out and save your changes.
Jun 11, 2010 | RIM BlackBerry? Tour 9630 Smartphone
The text message sound alerts on my Glyde phone arent working
Nokia phones call them "profiles" , a set of preset modes where you can have different volume levels and tones for different occasions i.e General, meeting, loud, silent etc. I was suggesting trying a different preset mode If available to see if it worked for you.
Jan 14, 2010 | Samsung Glyde SCH-u940 Cellular Phone
Boss moans at the VOLUME of my message alert
Try to go to Userprofiles --> General --> Customize --> Tone setup --> Message tone.
Thanks,
Mar 26, 2009 | Nokia N73 Cellular Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
Nokia 6600 no new message received display
HI Qrasengan,
1) Open the menu, and go to profiles.
2) Enter the general option, and click on personalise.
3) after that, several option appears.
4) some of them are ringing tone, ringing type, ringing volume, message alert tone, vibrating alert, etc.
5) Go to message alert tone and change the tone u want to listen when message is received.
NOte :Only wav or midi formats are accepted as ringing tone. MP3s are not accepted as ringing tones in NOKIA 6600. U need to install a software "mp3 as ringing tone" or "mp2wmaogg.codec" to make mp3 as ringing tone.
If u want that software, send me feedback or reply.
And I will deliver u as email in ur email id.
Sajan(sajwhat_2003@yahoo.com)
May 03, 2008 | Nokia 6600
Jan 25, 2008 | Nokia N73 Cellular Phone
Nokia N73.Incoming message alert gone..No tone,vibration,message envelope
Follow this steps in the given order -
1) Switch off your phone
2) Remove memory card
3) Switch on your phone
4) Ask a friend to send you a message. Now you will hear the tone
5) Switch off, insert the memory card & switch on again
6) Ask someone to send a message again. It will work
Nov 07, 2007 | Nokia N73 Cellular Phone
Nokia 6120 Logo
247 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
