Replace Main On/Off Switch of ur machine...Check the DC Controller PCB (In The Back Side Of Machine)Connector on DC PCB J712.check Is Proper connected or replace DC Controller PCB....
Basicly, a E224 is a scanning lamp error code. Here's a question for you??? Will the scanning lamp turn "ON" at all? If so, then the problem is with the scanner power cable. If the lamp will not turn "ON" you may have a blown lamp & or thermal fuse on the scanner unit. You can not clear the code until the problem is fixed. Good Luck
The copier comes ON then it turns it's self Off , Correct? Turn the copier back ON and hold the Main power switch ON and the display will show a error code. Read it and let the copier turn Off. You most likely have a dead AC short. The error code maybe a E0202 or E000 . One of the lamps are blown or broken and shorting out. You probly have a blown scanning Lamp or fuse. You may also, have a shorted out Scanner Power Cable. It's black and powers the scanner lamp > sometimes the cable crack's and exposes the AC wire. That is a fun job. It may just be a blown fuser lamp.. Good Luck
I don't think it would take 3 hours to warm up? It's a anolog copier, it does not have a hard drive. Also, it would of coded out after about 10 minutes. If I were you, I would put all the orginal parts back into the copier and turn it On and see what Error code is showing. I would also, take the drum out & transfer roller and see if it warms up. What was the copier doing before this? I would look over the work you did before and maybe look for a loose connector or pinched wire or a short. Need a little more info.
E codes are usally associated with copy jams check all paper drawers for paper jams and display panel indicator to see what area is lit and then check that area for trapped paper.
