Question about Kirby G6 Bagged Upright Vacuum
My Kirby turns on, but when I try to go forward, I have to actually push it forward. It still has suction and the belt is not busted. But, it's much harder to vacuum.
What could be the problem?
  • 120 Answers
Make sure the lever it the very back of the machine is in the on or drive position, make sure the height is up high enough ( the higher the better as long as it is still cleaning - lower is not better ) and change the belt even if it isn't broken they can stretch out in less then a year of use.
Posted on Sep 22, 2008
My kirby g5 is not picking up, there is no blockage, but suction has dropped significantly, what could be the problem?
Not to question your description of the problem, but are you sure the suction has dropped? Kirbys don't usually lose suction unless there is a mechanical or electrical problem. When you turn the machine on does it fill with air and expand? If so, then you probably have enough suction. If the bag doesn't fill and expand and your machine is extremely noisy then the fan may be broken and need to be replaced. If you see excessive sparking near the bottom of the handle then you may have a motor problem like stuck or too short carbon brushes or a bad armature. On rare occasions, with Kirby owners who live close to a beach area and vacuum large amounts of sand, the sand actually wears down the vanes of the fan enough to make it useless. To check the fan; first unplug your Kirby from the electrical outlet, remove the brush roll nozzle, slowly spin the fan/belt pulley while observing the surface of the fan, look for cracks or breaks. The fan vanes should be about 3/4 of an inch deep.
If none of the above fixes your problem, look at the brush roll and belt. If your belt has not been changed in the last 12 months, install a new belt. If this is the original brush roll, install a new brush roll.
May 18, 2010 | Kirby G5 Bagged Upright Vacuum
Kirby g6 will not pic up dirt. Belt is on and bag
check for blockage or impeller if vacum makes loud noise the impeller is the part that gives it suction
Oct 15, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby generation 3 won't vacuum. It runs and
You may have suction but if the belt is worn the roller brush won't spin and therefore won't pick up anything. You can get a replacement belt here:
Oct 10, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Kirby ultimate g
Vibrating – that usually happens on some short fiber or very dense carpets. When nozzle goes against the carpet fiber Kirby starts jumping. Try vacuuming the same place while facing opposite way.
Belt – red arrows means DISENGAGE. When you install the nozzle on the Kirby unit while green arrows match you will not be able to turn it on red. You must follow sequence (starting from nozzle off the Kirby, green arrows match, Kirby front lifter all the way up by pressing one of the pedals):
1. Turn Kirby knob to match red arrows. You will feel some tension and hook inside of the nozzle is supposed to catch the belt and stretch forming a loop for the Kirby shaft.
2. Put the nozzle on the Kirby and lock it on with the latch.
3. Twist the knob back to match the green arrows. YOU ARE DONE
Go to Kirby vacuum online manual. There are some small details that you may want to pay attention to if you have removed the brush roll to install a new belt. Also there are some pictures that will help you understanding the process.
Sep 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
How to change kirby vacuum belt?
Here's a video where we show you how to replace the suction fan on a Kirby Generation vacuum cleaner (also known as the impeller blade). I hope this video helps;Chris Jones
Jul 20, 2008 | Vacuums
Kirby sentria
you have to make sure the green light is on.. in the corner .. and if it is that means its working properly. If you have no suction then it is usually the belt and or the bag. so make sure your bag is not full , make sure everything is attatched properly and the green light is on.... The Kirby is the best vac out there and little suction should never be a issue for us.. I am a proud owner of the sentria..Love it..
Jul 05, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby 3g
Here's a link on how to adjust the transmission on the kirby...the kirby pictured is a G4 or 5 but it is the same transmission as the G3
Hope this helps!!!
Mar 09, 2008 | Kirby Generation 3 Bagged Upright Vacuum
My kirby has no suction
Even if you have a new belt, do everything this guide tells you to do. The seller may have the power nozzle assembled improperly. If the brushroll is in wrong or the base plate is not on correctly, it may cause these symptoms.
Hope this helps,
Nov 10, 2007 | Kirby G6 Bagged Upright Vacuum
G2000 Kirby HELP
I'm not familiar with this type of vacuum, but if it's like most kirby's the powerhead gets all its motion off the tapered spindle underneath the powerhead. IF the belt is installed backwards on this spindle then all motions are reversed. there should be an arrow stamped into the blower housing. the belt should be installed so it is nearest to the arrow in the direction of the arrow on the housing.
Aug 22, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate won't clean carpet
when you install the hose connector it trips a switch that switches the vac motor into high speed because the vac path is longer using the hose. check the belt after you remove the front. make sure the direction of rotation is in the direction of belt travel stamped in the impeller. try adjusting the head height
Aug 13, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
100 people viewed this question
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
