Question about Canon NP 6050 Copier
Dark horizontal line on canon np6050 copy
Hi, I have one horizontal dark line about 1/2" wide and about 1" from the botton of the copy.
Any ideas what may be causing this?
Thanks,
Brian
  • huntsvillebp Sep 22, 2008
    Hi Cogz,
    Thanks for your suggestion.
    I have tried running the wire cleaning and what happens is the copy will be cut off at the bottom about a half inch and if you run the wire cleaning again it will not be cut off, run it again at it will be cut off.
    The black line is allways not there when you first run the machine but as you run more copies the line gets darker and darker.
  • Canon Expert
  • 1,326 Answers
Did you try to run the wire cleaning funcation in the add. funcation mode? It could be that a wire cleaner got stuck in that spot and if you Run Wire Clean it may move it bake to Home Position and out of the way... Good Luck
Posted on Sep 20, 2008
  • Chris Coughlin
    Chris Coughlin Sep 24, 2008
    The problem is that the cleaner is getting bond up and gets stuck. Also, you proble need the corona wires replaced (6) there are a over looked item that need to be replaced. It's just that your tech may not know how to replace them...... Good Luck
What is causing dark lines on all copies?
probably the drum unit needs to be replaced,but first I'd clean optic,mirrors, glass,developing unit ,fixing unit...
Oct 01, 2014 | Canon NP 6230 Copier
Image distort when copying and horizontal lines
Getting caught? Loose paper shred inside feeder?
Mar 28, 2014 | Canon D320 imageCLASS Digital Copier
Copying very dark lines down page.
hi just clean complet scanner mirrors and charge and transfer crona wires if solved ok if not solve just replace the drumcleaning blade.
thanks
May 14, 2010 | Toshiba 1370 Black and White Copier
Black stripes on copies using a Canon D1120
Do you use the Doc. feeder? Try to make a copy off the copy board glass. Is the line there? Now make a copy with the adf. Is the line there? If so, you need to clean the small glass under the doc feeder. It looks like a glass ****, about a 1/2 inch wide. Clean it with windex and that should solve your line problem...
May 11, 2010 | Canon CLC 1140 Copier
Copier is making copies super dark and with a white line in the botton of the page
Hello sir; Check the exposure lamp, is out or weak it make dark copy.
Aug 17, 2009 | Canon Office Equipment & Supplies
Black smudge on middle of each copy
defective toner cartridge. Replace it.
Please rate solution :)
May 26, 2009 | Office Equipment & Supplies
NP6050 false paper jam at doc feeder
When you put documents in the feeder and you push start do you see 2 black arms swing out to count the number of orignals? If yes, dose the doc tray begin to go down and then jams? If yes, you can try something.... OK, turn the copier off and move the 2 paper guides of the doc tray toward the middle. You need a #2 philip's head screw driver. Remove the 2 silver screws that will be sunk in a bit on the top of the doc tray. Once you remove the screws, remove the top part of the doc tray and you will have one connector toward the front. Unplug it and replug it back in and see if that works, if so return the 2 screws and you should be OK.
Dec 12, 2008 | Canon NP 6050 Copier
Wide lines and dark shadows on some pictures
There was an issue with some of the A650 IS cameras that bright light or sunshine could sometimes enter the case and create such symptoms as you're describing:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=183&modelid=15658&keycode=2112&id=39151
Although your camera is not an A650, recommend contacting Canon, especially if your camera is less than a year old, to have it repaired under warranty service. Even if older, recommend contacting Canon anyways to argue free repair if your symptoms match that of the above link. Call 1-800-OK-CANON.
Jun 28, 2008 | Canon PowerShot A710 IS Digital Camera
Panasonic DMR-EZ47V Fuzzy horizontal line in VHS mode
Dirty heads or the recording was from a different brand VCR and the Panasonic cant get the right tracking. Try manual tracking just a little in either direction to you get the right one.
May 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Horizontal lines when printing in color from Canon printer
* check wheather cartridge is fine
*see any loose connections in printer
Apr 03, 2008 | Microsoft Troubleshooting Your Web Page...
Canon NP 6050 Copier Logo
126 people viewed this question
old marine
old marine
